1. Offline
    catsbox Member
    Start a Conversation
    Apr 17, 2005
    296
    Bellevue, WA
    Your Vehicle Year:
    In my generation 2 and 3 Prius, the Nav allowed me to program several destinations along the route of a trip. I can't figure out how to do the same thing with the Prius V. Does the new Nav in the V not have this capability?
  2. Offline
    parnami Member
    Jul 8, 2009
    204
    32
    Philadelphia (ugh)
    Your Vehicle Year:
    It has the ability. It took me some time to figure it out, and I'm not sure I can do it from memory, but, I'll try and see if I remember. With a route already set, click the select a destination button, then the "waypoint" tab. You can then add the waypoint from your saved destinations, from a points of interest menu, or whatever. You'll then be asked where in the route the new destination should be placed. It works, and, once you get the hang of it, is not too troublesome to use. Overall, the nav system is not at all bad. It just takes some time playing with it to become familar and begin to appreciate it's capabilities.
    catsbox and Quentin like this.
  3. Offline
    owayneo New Member
    Jul 1, 2012
    Your Vehicle Year:
    I'll second that. At first, I thought I'd just keep on using my smartphone nav, but now I use the built-in one, it even has a nicer voice than the one on my smartphone.
  4. Offline
    Adam H Junior Member
    Jun 3, 2012
    60
    Your Vehicle Year:
    Along the same lines, say I'm someplace--how do I set a waypoint at that place?
  5. Offline
    syscon Member
    Jan 14, 2012
    271
    16
    Edm. Alberta
    Your Vehicle Year:
    The current GPS is missing current coordinate feature. Showing driver its current GPS position: latitude and longitude.
    Unless I missed it somehow.
  6. Offline
    parnami Member
    Jul 8, 2009
    204
    32
    Philadelphia (ugh)
    Your Vehicle Year:
    lol...I believe that's there too....buried somewhere.."advanced" maybe? I know it's possible to save a location by entering map coordinates. There's also a button to provide info regarding elevation. Off hand, the only way I know to save a current location would be to also click "advanced" then select a position from the map. Zoom in the map as close as possible and touch your current position. You should then be provided the screen allowing you to name the coordinate.
    Again, I'm working from memory and not sitting in the car and it's been a while since I pressed all the buttons to see what they did, but I'm pretty sure I'm fairly accurate if not totally accurate, though I do stand to be corrected if I'm not?
  7. Offline
    Jun 3, 2012
    60
    Your Vehicle Year:
    Yes that's what I've been doing. I take a stylus and press over the current location. It then gives me an option to rename it and save it.
  8. Offline
    sURFNmADNESS Prii Family
    Jul 22, 2012
    78
    Omaha, NE
    Your Vehicle Year:
Share This Page
