1. Offline
    ES44AC C.A.U.S
    Start a Conversation
    May 7, 2012
    161
    Your Vehicle Year:
    I bought the car used with 8k on the clock. Apparently the previous owner wasn't too careful when cleaning the above mentioned plastic display screens. Probably used a dry rag or something!
    I will need to mask off the areas surrounding the screens to try and remove the minor scratches so whatever I use won't mar the grey plastic. But what to use? I don't need anything too abrasive and I surely don't want to make a minor problem a major one. But I don't like the looks of the scratches either. There is a plastic cleaner called Plexus but I have never used it and don't know if it's abrasive or what.
    Sad to think that a little care taken when doing the cleaning of the console could have prevented this, that's what tee's me off!
    If I do get them cleaned up I will cut some Venture Shield Ultra clear bra material and cover them once and for all. I don't think putting the material on top of the spiderweb is a great idea, it needs gone before I do it.
    Thanks in advance!
  2. Offline
    rrg Member
    May 18, 2010
    335
    78
    East coast - NJ
    Your Vehicle Year:
    I've always used Novous 2 Fine Scratch Remover on most plastics like my old cars head lights when they discolor and get foggy looking. I've had the same bottle for years. It's the red label and cost between $4-6.
    If your finger nail can notice the scratches it will take something different to fix it.
    my2cents.
  3. Offline
    ES44AC C.A.U.S
    May 7, 2012
    161
    Your Vehicle Year:
    Hi and thanks,
    No these aren't deep scratches at all just on the surface more visible than 'feelable'.
    I will look for that polish.
    Cheers :D
  4. Offline
    Jon Hagen Member
    Mar 6, 2011
    148
    48
    North Dakota
    Your Vehicle Year:
    I am also guilty of dry wiping dust off the radio and HVAC display and scratched them to the point they were hard to read in direct sunlight. I carefully coated the lenses with RainX glass treatment. It eliminated the scratches and in another two years of dry wipes, the scratches have not returned.
    Apparently the rainX coating is much more scratch resistant than the original plastic.:)
  5. Offline
    ES44AC C.A.U.S
    May 7, 2012
    161
    Your Vehicle Year:
    Hi Jon,
    I have used Rain-X for years but never on plastic so I am a bit dubious to try it. It seems like the Rain-X would attack the plastic and make a terrible mess. I have no other similar materials to try your idea on. I'm glad it worked for you however.
  6. Offline
    cmrj Junior Member
    Aug 28, 2011
    34
    Boise, Idaho
    Your Vehicle Year:
    I used to get very good results removing fine scratches and cloudiness from the soft plastic rear window on a BMW convertible using Meguiar's Mirror Glaze Clear Plastic Cleaner #17, Polish #10, and Detailer #18. #17 and #10 are a two step process for removing the scratches and polishing and #18 is for maintenance of the plastic.
    ES44AC likes this.
  7. Offline
    rrg Member
    May 18, 2010
    335
    78
    East coast - NJ
    Your Vehicle Year:
    Whatever method or treatment you use, be sure to mask off a little corner and try it first to see if you get good results.
    You don't want to attempt this in the middle of the plastic and discover it's softer plastic then we all thought.
    my2cents
  8. Offline
    ES44AC C.A.U.S
    May 7, 2012
    161
    Your Vehicle Year:
    I agree. The Rain-X manufacturer has warned me not to use the product on plastic, stating it is designed for use on glass specifically. I don't intend to jump in and do it all at once and the surrounding areas that aren't part of the LCD readout need to be masked off as well.
    Tnx
  9. Offline
    Jon Hagen Member
    Mar 6, 2011
    148
    48
    North Dakota
    Your Vehicle Year:
    I use an Airstream brand helmet with a filtered air supply in my work. The company that markets that helmet has always recommended RainX to remove small scratches and prevent fogging of the plastic face visor used on the Airstream helmets, so I never gave it a seconds thought that it might damage the plastic in the Prius.
    Yes, I guess I should have posted that RainX states it can harm some plastics. I learned that on another site where I mentioned that I used rainX to keep the rubber part of wiper blades clean and soft, so they wipe clean and do not chatter on a nearly dry windshield. Someone on that site said that he thought he remembered a warning on the rainx package stating not to use it on rubber parts . I checked and found no mention of rubber being damaged, but it did say that it could damage some plastics. I may have been lucky that it did not damage the type plastic on the Prius HVAC and radio display .
Share This Page
