How to Replace the Hatch Opening Switch
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Patrick Wong, Apr 2, 2010.
  1. allsmiles277
    allsmiles277 New Member
    I recently purchased the part to repair my hatch mechanism with black gooey deteriorated supposed rubber. I used an offset Phillips screwdriver to get the 2 screws out. I scraped the black gooey substance off as much as I could. I took the new inner mechanism out of the new part and replaced black gooey piece. I put the new black rubber piece on with hex bolts for future ease of access. The hatch mechanism works like it is new. The part cost me 45 dollars and Toyota refused to fix it free for me. Toyota will NEVER see a dime from me in the future. I refuse to do any more business with Toyota since they would not help me.
  2. Patrick Wong
    18,199
    6,464
    That is your choice.
    Considering your car is 8 years old, please provide a list of auto manufacturers who you expect would help you given similar circumstances?
    I think Toyota has actually been quite generous to Prius owners overall, considering the variety of special service campaigns and limited service campaigns that the 2G Prius has benefited from over the last several years.
    stonerider and Yakoma like this.
  3. Mitchrodee
    Mitchrodee Junior Member
    Wheaton, IL
    The plastic garnish on the hatch of our 2007 Prius has given way. Actually, I believe the cause is the two hydraulic support lifts on the hatch have lost their ability to lift the weight of the hatch, causing us to pull harder on the garnish. So, I've replaced the two supports and am now awaiting a new garnish. I'm thinking it must be possible to craft a handle of some sort, one that could be attached to the hatch using the two license plate bolts. It has to big enough to allow a set of gloved fingers to slip through and reach the hatch release button. My goal is to not put the new plastic garnish under any stress, if possible.
  4. Yakoma
    Yakoma Active Member
    470
    122
    ATL-ish
    This garnish failure also happens on the Scion tC. An aftermarket company came up with a metal replacement. Perhaps we can convince this company to tackle the Prius garnish.
    Others have suggested this alternative handle to avoid stress on the garnish. For the Gen II, it will require drilling two holes in the hatch that would match up with the bottom holes on the license plate.
  5. Dookin
    Dookin New Member
    Columbus, OH
    I just did this the other week. I replaced it with an inner tube made for a bicycle, cut to the proper size.
    SFO and nh7o like this.
  6. nh7o
    nh7o Off grid since 1980
    1,686
    338
    Hawaii
    That is more my style. I'm about to do this as well.
  7. Dookin
    Dookin New Member
    Columbus, OH
    I followed this YouTube video.
    He says to use a 7/16 deep socket to remove the bolts, but the Prius uses metric, not standard.
  8. stonerider
    stonerider Member
    107
    Lompoc, CA
    What a miser! Being penny-wise and pound-foolish, the OP fits the very definition of a narrow-minded ignoramus.
  9. BobR38
    BobR38 Junior Member
    Chandler, AZ
  10. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    I did the same and ran another push button to the dash next to the dimmer switch
  11. alanew
    alanew Junior Member
    Albuquerque NM
    A few weeks ago I used this tutioral to replace my sticky latch 2007 Prius Hatch Latch REPAIR
    it took some time to clean up. It's been working great with no issues or problems. best part, a lot cheaper than a new part.
  12. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    Mine is a 2008 and the hatch switch rubber was going bad; the first ever failure on our 2008 with 150K miles on it. It was not bad to the point of being gooey rubber like the 2007 owners complained of. Perhaps my 2008 was the tail end of the bad batch of chemicals. I replaced it today, a pretty easy job. It was good to preview the steps to changing it which made it much easier than doing it myself without prior guidance.
    I paid $47.69 on Amazon for the 84840-47020 part number which does not come with the square "Lock" button. So I had to splice in and solder the wires. No big deal.
    My 2006 4Runner has a similar switch and the rubber on that is in fine shape. It sits outside, usually covered, in the hot California sun all of the time. The Prius is garaged. This isn't a heat problem. Our summer temps in Redding CA are over 100 for much of the summer.
  13. oxnardprof
    oxnardprof Member
    249
    17
    Oxnard, CA
    Thanks for this thread. My 2004 Prius is fine, but the 2008 Touring Edition has this problem. Extends past 2007, I guess
  14. JC91006
    16,470
    8,383
    yes it affects 2008s also, I replaced mine
  15. Prius Jeff
    Prius Jeff Junior Member
    Kansas City, MO
    I've had to deal with this issue for a couple years now, and am finally able to afford THINKING about a repair. What might be a 70-90 dollar part and then some DIY tool time for some is going to be more for me. After my wife and I struggled many times in the cold with it stiffening up, one of the plastic clips holding the garnish assembly broke, so the part for replacing the entire assembly is going to be somewhere around 250... I don't even want to entertain the labor costs from a dealer.
    I love Toyota for being the innovator in hybrid technology, and putting such a great gas / electric option out there, but this was an obvious manufacturing defect that they are simply not addressing. If your service department at a Toyota dealership does anything but play dumb I'd be surprised.
    Just thought i'd put these here:
    www.meyersonstrategy.com/2013/09/toyotas-sticky-2007-prius-hatch-problem.html
    www-odi.nhtsa.dot.gov/owners/SearchSafetyIssues (put 2007 Toyota Prius in the filter > Complaints > Latches/Locks/Linkages )
    2009Prius likes this.
  16. mueck
    mueck Junior Member
    Andover, MA
    I'm cheap, so I went looking for other 2007 Toyota's with the same hatchback opening switch housing and found a cheaper one for the Toyota 4-runner that's exactly the same except it has a different wiring harness connected to it. Like every other car manufacturer, whenever it can Toyota uses the same parts across it's various models. All I really wanted was the rubber cover anyway. Below are the descriptions I typed into eBay, both are from the same supplier and both include free shipping.
    $48.68 84840-47020 TOYOTA PRIUS BACK DOOR OPENER SWITCH ASSY
    $33.69 84840-35010 TOYOTA 4-RUNNER BACK DOOR OPENER SWITCH ASSY
    By far the hardest part was cleaning and subsequently dissolving off all the black tar on my existing switch - it was a rotten job that easily took well over an hour. However, after looking at the 4-runner switch when it arrived, I now see that I didn't have to do that. I could have just disassembled the new switch, removed the micro-switch inside it (attached to it's wiring harness) and just transplanted my car's existing micro-switch from inside it's switch housing into the new switch housing. That being said, I just transferred the new rubber cover onto my existing switch housing and then screwed it back on. Good as new.
    I also read about several people stripping the two screws holding in the switch assembly - that would be very easy to do if you didn't have the right tool. I was fortunate enough to have a 1" ratchet screwdriver and didn't have an issue. Forgot to mention, I didn't have to pull the door apart or anything - everything was done just by removing the two screws holding the switch assembly to the door. Don't forget about the washers on each screw either, they'll be impregnated in the tar. I've attached a few pictures that go with my text. Good luck.
    mark5211 likes this.
  17. mattdalton
    mattdalton New Member
    Newcastle, WA USA
    The rear hatch handle molding garnish on my 2007 Prius broke and I had to replace it. The replacement molding garnish came with a new switch, but the original part was still fine (guessing because I live in a milder climate), so I salvaged it. If anyone wants this part, it is yours for free, just send me a private message. I will cover the shipping, so USA only please. It's the least I can do to pay back this site for all the useful information it has provided me.
  18. acadiaphile
    acadiaphile Junior Member
    44
    Can somebody review the part number(s) for the items required to replace the rear "Garnish"? The plastic fasteners which attached the this part of our 2005 Prius broke and I'm hoping to replace the part myself. Is this what I should be ordering: GARNISH SUB-ASSY, BACK DOOR, OUTSIDE. DK. RED M.M.,3Q3
    Thanks for clarification!
  19. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    Use this site with your specific VIN to verify the part number.
  20. noelty
    noelty Member
    112
    Los Angeles
    I removed everything and have run into an issue regarding the lock switch. The cables to the lock switch are joined with the hatch cables. How do I seperate them so I can remove the defective release and replace it with the new one I ordered?
    Also, how would one open the hatch on a 2007 prius if they removed the handle and then closed the hatch while running into the house to get something :(
    This is not my proudest moment : /
    *EDIT* I think I ordered the wrong part number...I believe there is a part for cars equipped mith smart key :(
    #100 noelty, May 15, 2016
    blaisep likes this.
