How to replace wiper blade rubber insert on 2012 v?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Krellan, Apr 6, 2014.
  1. Krellan
    Krellan Junior Member
    16
    Castro Valley, CA
    I have a 2012 Prius v Five. I have new wiper blade rubber inserts from the dealer, that I picked up while waiting for service. Can't figure out how to install them, though. How do you access the rubber, and separate it from the metal? There's no obvious screws on the assembly that I can find. Am I missing something obvious here?
    Toyota part numbers:
    85214-47061
    85214-47051
    I found instructions online but unfortunately they were for a regular Prius (not v) and they've changed the design.
    Much thanks!
    Josh
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    No screws.
    I find that if I try to replace the rubber while the metal arm is attached to the car I lose patience. So I detach the arm and sit down comfortably at a table in the house. Then it is clear and easy.
    Do keep in mind that you have to reuse the metal strips.
    This is what I wrote for myself some years ago. See if it helps:
  3. Guill
    Guill Member
    165
    23
    Italy
    I agree with SageBrush, first remove the wipers from the car ... much easier this way. I just replaced the wiper blade rubber inserts on my v this last weekend--very easy. There is a notch on one end of the insert ... look at the notch on the new insert and you'll see that it obviously has to be inserted into the metal bracket in one direction ... just pull the insert in the opposite direction to remove.
