How to start a Prius after long term storage (HV battery dead, replaced dead Aux battery).
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by edli, Aug 2, 2009.
  1. edli
    edli Love My Prius
    Irvine, CA
    Car was damaged in a front end wreck. Took me years to repair it myself. HV and AUX batteries dead. Replaced AUX battery. Won't start, but may have other issues (will deployed airbags and seatbelt retractors prevent READY LIGHT?). All dash lights will light up, but only the ABS and Airbag lights stay lit. Assuming the other issues are not preventing the READY LIGHT, do I need to charge the HV battery? What's the best way (I prefer to avoid the dealer if I can)?
  2. edli
    edli Love My Prius
    Irvine, CA
    PS - I know I need to have the brakes bled (by a professional, I assume I can't do this myself). My car is a 2004 base model with only 19k miles.
  3. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    After years the Hybrid battery is dead. You would need the special charger from Toyota to do it right, if it can be charged! If you are very knowledgeable in battery chemistries and high voltage electronics it might be possible to bring it back to life your self. I'd start looking for a late model salvage battery pack for 500-700 on ebay.
    Wayne
  4. Jon S
    Jon S Member
    185
    84
    The Aloha State
    why is this in the 2010 Prius forum???
  5. Voltan
    Voltan Junior Member
    47
    Niskayuna NY
    Although your car is out-of-warranty for most components, I believe the HV battery is covered under an 8-year warranty under emissions regulations. And, since you live in a CARB state, your emissions warranty is extended to 12 years. It's in the warranty booklet that came with your car. You should be off and running soon. Best wishes.
  6. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    You may have other problems. You need to be able to read the trouble codes. If you can do that, and report the codes, we can help you. Also, although the traction battery has not been used in a few years, it may still have enough charge in it to run. It depends on how much charge was in it when it was last used. My car sat for 8 months without being used, and the battery was still at 4 bars. You can run diagnostics on the battery to find out. You can search for it on Prius chat and get instructions.
  7. Patrick Wong
    18,199
    6,464
    Dear friends, this string is almost one year old. By now I assume the OP either figured it out or else sold his vehicle.
  8. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Wow this is amazing! :)
  9. Will N
    Will N Junior Member
    Southern California
    2014 Prius v wagon
    2015 Prius V, left for a year, used to recharge the 12 v and it would start, now it's just dead. What's the process I need to follow? Is it difficult? (I called a couple of Prius repair places but they didn't call me back.) Thanks
  10. bisco
    48,987
    start by having the 12v charged and load tested at autozone
