How to unlock all the doors automatically
Discussion in 'Prius v Accessories and Modifications' started by darinf, Jan 5, 2012.
  1. longshot
    longshot Junior Member
    68
    Holding both unlock and lock down on 2013 Prius 2 worked as well, thanks!
  2. shawn.c.lyon
    shawn.c.lyon New Member
    Baden, Ontario
    2014 Prius v wagon
    I have the 2014 V Luxury (In Canada) and I couldn't find settings on my nav display in vehicle settings for the door unlock, so I tried the remote thing and it worked. I sat in the car with the engine and everything off, and pressed the lock and unlock at the same time, and held them until the car chirped, then I got out and tried it. It now unlocks all doors with the drivers handle, not just the driver's door.
  3. shawn.c.lyon
    Baden, Ontario
    2014 Prius v wagon
    This worked for my 2014 V Luxury (Canadian)
  4. BruceWonder
    BruceWonder New Member
    Orange County, CA
    2014 Prius v wagon
    I have a 2014 prius V3 and the remote method works great. Thanks. No more double clicking to tapping the unlock button on the door to let my passengers in. Now the key fob can stay in my pants
  5. PriusvGW
    PriusvGW Junior Member
    Sacramento, CA
    I set my 5s with the key fob. Somehow, the setting was reset back to default ( All door OFF). It's my third time changing the setting again. Anyone knows what's going on?
  6. bisco
    48,945
    i can't think of any reason for it to do that, except 12 volt disconnect.(n)
  7. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    If you are changing the settings on the vehicle's center screen it is easy to forget to press save before returning to main screen. That would explain the illusion of the setting returning to previous state, but also mean that the setting never changed. Were you in a rush and didn't test that the setting took effect?
  8. like2bike
    like2bike Junior Member
    Melville, NY
    2014 Prius v wagon
    I just changed my v5 to unlock-all-doors-from-the-driver-door using the key fob method. I think the nav display menu setting is gone for 2014 and they didn't update the manual. I have to say I'm very disappointed in Toyota if this is the case. I don't remember finding an error like that in a manual for any other car I owned and this is my first Toyota.
  9. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    hey chazz8, your pdf doesn't load anymoye. can you post it again?
  10. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
  11. PanthersFan
    PanthersFan Junior Member
    55
    17
    South Florida
    2013 Prius v wagon
    I just did this with Carista! One of the settings is to unlock all of the doors with just one press of the unlock button on your fob/remote. There are cheaper Bluetooth dongles but I bought Carista's for $40 on Amazon and paid $20 for the in-app upgrade. I also disabled the constant reverse beep (it's now just a single beep). Totally worth it.
