How to unlock the trunk
Discussion in 'Gen 3 Prius Main Forum' started by edgardotcom, May 12, 2014.
  1. edgardotcom
    edgardotcom New Member
    When I use the sensor in the door handle, all doors open except the trunk, how can it be open automatically using the sensor?
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    On the lower trim Gen III Prius the Auto door unlock only works from the driver side door. You can customize the unlock feature to unlock all doors. As always the manual has the details.
  3. xraydoug
    xraydoug Active Member
    571
    176
    Roseburg, Oregon
    good advice, but I don't think he has a trunk:ROFLMAO:
  4. BZzap!
    BZzap! Senior Member
    1,607
    877
    Push the unlock bottom on the key fob 2 times.
  5. xliderider
    xliderider Senior Member
    7,848
    3,102
    Honolulu, HI
    You should be able to open the hatch after unlocking all doors from the driver's door SKS. Or, as stated above, press the unlock button on your fob twice.
    SCH-I535
  6. edgardotcom
    I just read the manual, I now have an idea how, I will give it a try, it states to press unlock and lock keys from fob to unlock all doors or just one door
  7. edgardotcom
    Thank you guys for your fast response, problem solved page 72 in the manual
  8. xliderider
    7,848
    3,102
    Honolulu, HI
    That is to change the setting, from one unlock mode to another.
    SCH-I535
  9. edgardotcom
    Yes indeed, my original question was wrong, only the drivers door was opened and not the rest including the trunk.
