1. Offline
    Jonny Zero Giggidy
    Start a Conversation
    Jun 22, 2012
    861
    166
    Austin, TX
    Your Vehicle Year:
    I was talking with Husky's customer service and they told me that they do not use the factory retaining system for the driver side, to avoid creating holes for water to leak down to. They told me because of the custom molding and the ribs on the back the driver side mat won't move.
    To those who have them in a Prius, can you confirm that they are secured? Thanks.
  2. Offline
    Jimbo69ny Active Member
    Feb 27, 2012
    597
    70
    Ithaca, NY
    Your Vehicle Year:
    They are not secured by the floor mat hooks. Some posters say that they slide around others say they stay put well. I havent had any problems with my Husky mats moving around. I think they are great mats.
  3. Offline
    Lordkifar Junior Member
    Jun 15, 2012
    53
    Your Vehicle Year:
    Mine do not move at all.....They do not secure with hooks but they do have these sharp pointy teeth on the bottom side and seem to stick well to the carpet lining the car floor.
  4. Offline
    Jonny Zero Giggidy
    Jun 22, 2012
    861
    166
    Austin, TX
    Your Vehicle Year:
    Has your car been back to Toyota for service? Did they say anything when they "inspected" the driver side mat fastener?
  5. Offline
    Jun 15, 2012
    53
    Your Vehicle Year:
    No no service yet as my car only has 4000 km on it...not for a couple more months....they can say all they want, I like those liners a million times more than the Toyota ones.
  6. Offline
    mainemanx Member
    Apr 5, 2008
    305
    32
    State O' Maine
    Your Vehicle Year:
    Have had Huskies going on 10 years in our 2003 CR-V, 2 years in our 2010 Pu-ri-u-su, all are titless (i.e., sans "sharp pointy teeth," as I clipped them off with a pair of dikes-diagonal cutters--long, boring winters here in Maine :).
    Never had a problem with any of them, and they don't leak! 'Love 'em!
    Personally, I think that accelerator sticky/jamie thing is totally bogus.
    P.S. Jonny Zero: a hook and a hole, "factory retaining system?"
    P.P.S. Clipped-off the "sharp pointy teeth" after trying to lift out the driver's side mat in order to dump the accumulated slush, snow, and water. When cold, those little tips are like icepicks! I was literally bleeding!
  7. Offline
    eseymour72 New Member
    Feb 26, 2012
    43
    Reno, NV
    Your Vehicle Year:
    I've installed them in mine since day one and these are the updated version for the 2012 Prius.
    They do move over time, maybe up to 1/2 an inch at the most. Like others have stated, they don't really move because they have points at the bottom and slots to fit over the OEM hooks but they do end up sliding forward over time as you are pushing on the mat getting in and out and I tend to move my feet quite a bit while driving.
    So no, they don't just move but yes over time you'll notice that they might move up about 1/2 inch or so but not enough that you'll notice.
  8. Offline
    wotcher Member
    Mar 24, 2012
    353
    73
    LA
    Your Vehicle Year:
    theyre fine for me. like eseymour said, they move about a 1in every once in a while. i dont think its worth an extra $100 to buy weathertechs.
  9. Offline
    car78412 New Member
    Jul 18, 2010
    266
    24
    Hudson Valley, NY
    Your Vehicle Year:
    I have 2 Prii in my family. One with Weather Tech floor liners and one With Huskey liners. The Husky are far superior to the Weather Tech. The Weather Tech leak through the holes on the bottom where the secure tabs are located and are not that easy to remove. The Huskey doesn't use them and the mats don't leak nor move. They are also very easy to remove and clean. Save alot of money and get the Huskey.
  10. Offline
    Fore Don't look back!
    Feb 1, 2011
    255
    43
    Virginia
    Your Vehicle Year:
    Save yourself some money, buy the Husky's!
  11. Offline
    striker308 Prius owner
    May 11, 2008
    214
    27
    Kenmore, NY (USA)
    Your Vehicle Year:
    mine slide about an inch or so forward and back but that's from getting in and out. they have rather sharp spkies on the bottom and stay put when you have your feet on them.
  12. Offline
    Sporin Prius Noob
    Dec 10, 2010
    326
    64
    Windsor, VT USA
    Your Vehicle Year:
    husky weatherbeater mats-pics | Page 9 | PriusChat
    I'll quote myself from March...
    I've just put them in for the year and they are already scooting. I've tried putting them on top of my carpeted floor mats and on the "bare" carpet floor. No difference. I'm leery of cutting holes to use the floor anchors as that will just be a drain for the water.
    I think I'm going to try and cut holes in the vertical part of the rear lip and zip tie them to the seat anchors.
  13. Offline
    Jonny Zero Giggidy
    Jun 22, 2012
    861
    166
    Austin, TX
    Your Vehicle Year:
    Good Lord! Sure am glad I don't live up North.:eek:
    I am still running the carpeted mats that came with the car. I am leaning towards WT. Since we don't get snow here often (a thin layer if it does), leaking down the holes is a non-issue and they sure look better. I have a Husky cargo liner right now.
  14. Offline
    Sporin Prius Noob
    Dec 10, 2010
    326
    64
    Windsor, VT USA
    Your Vehicle Year:
    Believe me, they don't look like that all winter, I try to clean them and vacuum frequently but they can get that way quickly when we have a few straight days of storms. But it's a great illustration of them not doing the job I bought them specifically to do.
  15. Offline
    May 11, 2008
    214
    27
    Kenmore, NY (USA)
    Your Vehicle Year:
    I can confirm the company is full of shit.
    I have to move mine back into position every time I get back in the car, and it's a lot more than they started slipping. What started as an inch or so is now more than Five or more.
  16. Offline
    Feb 27, 2012
    597
    70
    Ithaca, NY
    Your Vehicle Year:
    Ive had mine for about 5 months now and they are still perfect.
  17. Online
    somebody7 Member
    Jul 26, 2012
    117
    31
    Austin, TX
    Your Vehicle Year:
    I've had the weatherbeaters for about a week or two. I bought the front and second row and then I bought a weathertech cargo mat. Let me know if you want to meet up to check them out. Obviously we dont get snow (maybe once every 5 years) and it doesnt rain much here in Central Texas, so I have yet to really test them out. I'm still undecided if I like them. Feeling the thickness of the Husky and the Weathertech, I preferred the Weathertech. But I thought I'd give the Husky mats a try.
  18. Offline
    torr310 Junior Member
    Sep 24, 2011
    35
    Your Vehicle Year:
    I have Husky liner on my 2011 Prius 3. I was looking at the WeatherTech but saw a few complaints on this forum, so I gave Husky a try. It has been worked wonderfully. It is secured. For myself, I remove the carpet before installing the floorliner.
Share This Page
