1. Offline
    LenP Member
    Start a Conversation
    Oct 17, 2011
    253
    66
    Morris County, NJ
    Your Vehicle Year:
    Every time I think I understand my PIP it surprises me again. I was driving in a very hilly area and had 2.5 miles of EV charge left, or so the battery estimator showed. I was going down a hill and coasting when the car changed to HV! Then it stayed in HV mode until the ICE heated up. At this point I drove the car harder and my battery charge went up, it showed 3.5 miles left. Next I see the PIP is back in EV mode with more range then before. At the end of my trip I still had 1.6 miles left on the read out. Why it dropped out of EV mode going down a hill is a mystery. The speed was under the threshold, there was still adequate battery charge, and no heat was being called for. Too bad the read out isn’t state of charge rather then an estimate of what the computer thinks you should get. Always interesting and versatile, I love my PIP
  2. Offline
    john1701a Prius Guru
    Jan 6, 2004
    6,767
    1,444
    Your Vehicle Year:
    It settled down at 9.9 within a few miles, then stayed there.
    I've seen that settle happen several other times now, enough to suggest a pattern.
    1 people like this.
  3. Offline
    LenP Member
    Oct 17, 2011
    253
    66
    Morris County, NJ
    Your Vehicle Year:
    I'd just charge it when needed, and enjoy your PIP. In the long run the battery will probably last just as long with your lite use. I drive the same way, and some days I charge it twice a day, and others I top it with only half a charge before I go. That's why I got a 220 V level 2 unit, it's fast 45 to 90 minute charging time.
  4. Offline
    7,997
    895
    South OC So Cal & the Flathead Valley, MT
    Your Vehicle Year:
    I wonder it that's in anticipation of 'warmup' . . . since the ICE has to run a limited amount of time at start up anyways - maybe the 17%-18% space gives an efficient place to dump the juice created during warmup / ICE spinning.
  5. Offline
    tom_farr New Member
    Aug 30, 2005
    SoCal
    Your Vehicle Year:
    Thanks 9G,
    Sorry I didn't include the extra info. I began driving with a fair amount of EV range, but I think I depleted it by the time I got on the freeway. By 'leaving it in EV mode', I meant I toggled to EV and it showed on the display, but I never toggled it off nor toggled 'ECO' or anything else on. The EV did of course go away on the display. So yes, I let it switch to whatever mode it wanted as we drove. (I assume 'eco' is the same as HV?). I drove ~70 mph on the freeway.
    So from the posts after yours, I get the impression that if I left some electrons in the EV 'battery', I could switch back to EV mode when I got off the freeway. And that it would charge if I kept a low speed (?).
    It's starting to make sense....
    Tom Farr
  6. Offline
    pfile New Member
    Dec 28, 2005
    312
    33
    bay area, ca
    Your Vehicle Year:
    understood... believe me, i understand, i also own a leaf. :) but i do have a scangauge hooked up and while i did not take notes, i'm relatively sure the SOC went up.
    it does sound like john has discovered that the PIP does seek a certain battery level while in HV mode and my experience would at least correlate with that. i've only done the experiment once and it sounds like i happened to intentionally switch to HV mode right near the SOC level the car likes.
    1 people like this.
  7. Offline
    HillCountryEVer New Member
    Mar 2, 2012
    75
    Kerrville, Texas
    Your Vehicle Year:
    I totally agree...sure wish Toyota would make it an option...
  8. Offline
    pfile New Member
    Dec 28, 2005
    312
    33
    bay area, ca
    Your Vehicle Year:
    when bayleafs had the big engineering visit from the leaf design team, the idea of a SOC meter came up. the engineers were very concerned with exposing this information to the driver because 1) the SOC is just an estimate until the car is power-cycled (SOC can only be determined when the battery is open circuit) and 2) they observed some SOC variations (characterized as 'mystery' variations) and they were afraid to present this raw data to the customer because it could alarm them.
    i don't know if toyota has a similar rationale, but i'm sure they realize that 99% of their customers would probably be confused by this information rather than informed :)
    i wonder if the SOC on the scangauge has been conditioned or not? i have not watched it carefully enough to see if it monotonically decreases or increases, but it sure seems that way.
    1 people like this.
  9. Online
    9G-man Active Member
    Jul 2, 2005
    1,230
    142
    Atlanta, GA
    Your Vehicle Year:
    Your PiP did what was expected on your trip. You used up your EV range, it automatically switched to HV mode and stayed there. In HV it seeks a certain SOC (state of charge) and basically maintains it, for the rest of your trip.
    Then you at some point would recharge your PiP with the plug, and have EV range again. And it would start off in EV mode, and begin the process again.
    That's the basic way the PiP works.
    Now if you want to get creative you can begin to strategically switch into and out of EV & HV modes. That will allow strategic use of EV range, and even strategic regen to increase EV range.
    Thats what the experienced guys are experimenting with and discovering now in these posts.
    Have fun!
    Ok, ECO.....
    This is one seriously confusing thing in a GenIII Prius and PiP.
    The ECO indicator above the HSI is an indication of being in HV mode. So is the centerline in the HSI. The indicator is simply a visual feedback of low to moderated ICE demand. A little reward for a light foot.
    Not to be mistaken for ECO mode, which is selected by the ECO switch and controls how sensitive your gas pedal responses are.
  10. Offline
    mikenewmediary New Member
    Feb 23, 2012
    92
    Bridgewater, Ma.
    Your Vehicle Year:
    Not ever owning a prius, and waiting for mine at port, my head was spinning from this thread. 9Gman pretty much summed it all up.
    I guess ill be able to come up with my own methods once I get the car.
    Thanks to all, this is a great thread...
    Paradox, wish you would chime in, you seem to have mastered the regen on the EV battery from empty to full....
    -Mike
  11. Offline
    Jan 6, 2004
    6,767
    1,444
    Your Vehicle Year:
    That's elegantly simple and works superbly. Then I confuse matters by pointing even more HV/EV observations...
    Today's commute was just a single charge. I got to my parking spot with 7.0 miles remaining. Upon the "big climb" on yet another route home, I had switched to HV and was down to 5.8 miles remaining. At the top, it had risen to 6.0 miles. And since this particular drive brings me higher than needed, there was rolling regen opportunity on the way down. 6.2 miles was the EV capacity by the time the ground had leveled out.
    Then after some suburb driving in EV, it was back to HV for some 55 mph cruising. Capacity was down to 3.8 miles. Stoplight a few miles down the road. Capacity shot up to 4.2 miles from braking regen. Another stoplight a mile down the road required brakes again. It grew to 4.4 miles.
    The light turned green, I drove a bit, then it was finally HV depleting EV capacity on a long 30 mph stretch. I thought that would be the end of the story. I'd leave the store I had just driven to in EV, using up the last of the capacity. Turns out, the most exciting hadn't happened yet...
    Right before I used up those final electrons, I pushed the HV/EV button one last time. It didn't make any difference. That 0.1 value vanished and I was back to oridinary hybrid driving... or so I thought.
    EV capacity returned and increased as I drove. Huh? I certainly wasn't expecting 0.8 miles by the time I had reached my driveway. Having pushed that button at the last moment had quite an effect. My 2010 most definitely wouldn't have generated electricity like that.
    75 MPG overall from 36.0 miles of driving, with EV still remaining. That's fantastic from a 4.4 kWh battery-pack without recharging.
    Now I'm more curious than ever how the system will perform in the winter. The interplay between battery, engine, and motors is proving to be extremely well thought out.
    2 people like this.
  12. Offline
    ukr2 Active Member
    Feb 5, 2007
    803
    136
    Victor, NY
    Your Vehicle Year:
    Yesterday, Tuesday, was a normal trip to and from work.
    Based on John's suggestion, today, Wednesday, I used HV early in my trip to and from work. I used the GPS and switched back to EV when the miles to Destination was less than the miles left in the Battery.
    Here is the data for the 2 days.
    [IMG]
    Do you see ANY advantage of Today over Yesterday?
  13. Online
    Jul 2, 2005
    1,230
    142
    Atlanta, GA
    Your Vehicle Year:
    Having pushed the EV/HV switch one last time, put you in what selected mode? If it was HV, then what you experienced was not unlike how a post-warm-up works. Giving back EV capacity that it takes.
    And what are your conclusions now about how the PiP works? Is there something going on with selected HV vs. default HV?
  14. Offline
    Jan 6, 2004
    6,767
    1,444
    Your Vehicle Year:
    I was in HV. Pushing the button again would have toggled back to EV. My conclusion is there's actually another operational state, as I've noted with this:
    Buffer mode is turning out to be quite an unexpected bonus.
    I drove another 15.5 miles through the suburbs with a variety of power demands. Nothing caused the system to let go of that final 0.1 mile of EV capacity. 3 times I watched it go from almost gone to 0.9 miles. The second half of my evening drive yielded an average of 59 MPG. That's pretty darn good without any electricity from plugging in.
    The amount of generated electricity being passed back & forth between engine, motor, battery, and road is impressive. Following an inevitable depletion, I had anticipated the same behavior my 2010 would have delivered. Turns out, PHV has been configured to take advantage of the bigger & better battery.
    It operates in a way we hadn't considered. Of course, weren't sure Toyota would even provide a HV/EV toggle option. Turns out they they did and it's surprisingly easy to take advantage of.
    2 people like this.
  15. Online
    Jul 2, 2005
    1,230
    142
    Atlanta, GA
    Your Vehicle Year:
    Do you think it had anything to do with manually selecting HV mode? Or, not exausting your EV range completely in the beginning?
    Amazing, but it's gonna be really hard to communicate driving techniques now.
    But you know, in alot of ways it runs like a regular Prius with a bigger battery. Just like you'd expect it would. Just like a regular Prius, using up all your EV range in the beginning may not be so good.
    On another note...
    Every time the PiP is criticized for its "11 mile range", my response is ..... so what? a regular Prius has a 1 mile EV range, and look at what it can do, the success it is.
    Think of what 10~14 times that EV capacity will do. It's not about the 11 miles! The Pip is genious.
    4 people like this.
  16. Offline
    crewdog AARPrius User
    Jul 23, 2009
    280
    88
    Woodstock, GA
    Your Vehicle Year:
    To paraphrase a saying about dogs and persons,
    I wish I could be the driver my Prius thinks I am.
  17. Offline
    Jan 6, 2004
    6,767
    1,444
    Your Vehicle Year:
    It's from invoking HV mode prior to reaching depletion point, specifically within the last mile.
    If you don't push the button, then EV simply ends and you switch over to being a regular Prius.
    That's a great way of putting it! :rockon:
    1 people like this.
  18. Offline
    giora New Member
    Aug 28, 2010
    406
    79
    Israel
    Your Vehicle Year:
    Regular Prius will use regeneration opportunities to increase (HV) efficiency.
    Does this means that invoking HV mode prior to reaching depletion point will stack EV miles you gain in this HV mode for later use on the account of HV efficiency? (as compared to the efficiency you could have if you were not manually toggled to HV for the same drive?)
  19. Offline
    seilerts Battery Curmudgeon
    Mar 7, 2010
    3,296
    1,414
    Santa Fe, NM
    Your Vehicle Year:
    Ken, this is interesting data. How bad is the agony that you lack about 3.5 miles of EV range to make it all the way to work? :eek:
    If I read this correctly, on Day 1, you fully depleted EV miles, while on Day 2, you had the sum total of 4.2 EV miles left over due to switching over quickly to HV when starting out and switching to EV later. Day 2 shows lower MPG. I'm having a hard time reading your Day 1 MPG, but it looks like 189? While Day 2 is 116? This seems clear, that having 4.2 EV miles not get spent cost you almost another 0.1 gallon of gas.
  20. Offline
    Jan 6, 2004
    6,767
    1,444
    Your Vehicle Year:
    For most, no, hence the topic of this thread. EV will be replenished but HV will consume it.
    So, you will see an up & down and up & down within a short buffer. With my observations is 1 miles worth of EV, most likely because Minnesota has only small hills. It will go down to 0.1 almost disappearing (sometimes it actually does), then up to 0.9, then I run out of regen/charging opportunity and it starts downward again.
    We've had another say you can indeed stack. But that requires substantial terrain, like mountains.
    1 people like this.
Share This Page
