Hybrid Battery from 8 to 1 bar instantly
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sigmundSlo, May 4, 2015.
  1. sigmundSlo
    sigmundSlo Junior Member
    Ljubljana, Slovenia
    Hi Prius owners
    This is my 1st post here. I'm from Slovenia (sorry about my English) and reading PriusChat.com for two years already. I own 2nd hand Prius II (the 1st owner was my father). It's 10 years old now and it has almost 150kKM (95.000 miles).
    I kinda searched about my issue but didn't find nothing...
    2 days ago it happened something strange.
    I was going home with my family from the sea side. I was driving downhill for a while. The battery indicator just turned on the last 8th bar. I was using B as the hill was somehow steep.
    At the end we stopped for 10 minutes and then continued driving home.
    After 5km the road started to climb. All the time a had cruise control locked on 110kph (70 mph). After 2 miles suddenly the ICE went wild. I was a little bit confused, but then I noticed that the battery was empty - only 1 bar. Then I drove 80-90kph (around 50mph), beacause the climb is quite long - 10km (6 miles) and it rises about 500 meters and I didn't want the ICE to suffer". Then it took around 10 km more to charge the battery to 5-7 bars.
    Yesterday and today there's no strange behavour. Driving and using battery power as normal.
    Another owner of the Prius said to me he noticed similar thing at his prius several times through the years. He is guessing it could be the battery charge miscalculation...(?)
    Does anyone ever had such a problem?
    Any advices?
    TNX&BR
    sigmundSlo
  2. Patrick Wong
    18,198
    6,463
    What does "ICE went wild" mean? Do you mean that engine RPM dramatically increased?
    If that is all you meant, then it is normal for the gasoline engine to have to work harder when the traction battery state of charge is depleted. You were wise to reduce vehicle speed from 70 mph to 50 mph. It sounds like your car is behaving normally.
  3. sigmundSlo
    Ljubljana, Slovenia
    Yes, the RPM increased dramaticaly.
    I'm concerned because it happened so suddenly - I mean the drop from 8 to 1 bar.
    All other times I drove the same road, on the top of the hill I still had 4 bars... and the car went upwards "like a rocket"... :)
  4. Patrick Wong
    18,198
    6,463
    It could be that your traction battery is starting to weaken.
  5. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    223
    Nature coast, Florida
    Three Touring
    Another thing to check is your battery cooling fan. It is possible that a passenger or items in the back were covering the intake located next to the passenger seat. This could have caused the battery to overheat... I removed the molding covering the fan and cleaned it on my Gen II at 60,000 miles. It is worth noting and making sure it is not covered in the future. Good luck!
  6. bisco
    48,942
    i think, at 10 years old, you'll be replacing the battery in the near future. how near? difficult to say, everyone's experience is different, but it might be good to start researching. all the best.(y)
  7. wjtracy
    wjtracy Senior Member
    11,311
    3,588
    Northern VA (NoVA)
    As above,
    It could be normal behavior for hill climbing...that's what hapens when your battery gets low, the ICE comes on and sounds like it is working hard. Sometimes you wonder why it got low, but that can have to do with A/C.
    You did not really convince us it was instant change in the state of charge, but if so that is one sign of a weaker battery. Member UART down in Australia has posted a lot about how his battery does something like this.
    uart likes this.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    I think you've more or less gotten the answer.
    At 10 years old, it might be an early sign of the hybrid battery weakening.
    But if for all other extensible purposes it is working OK now?
    Then I'd just keep driving and keep an eye on it.
    If it isn't anything...you'll continue to be OK.
    If it IS something...keep your cell phone with you. And you'll continue to get more evidence a problem is manifesting.
    Maybe not the most reassuring answer I could give you. But if it is nothing? It will be nothing. If it's the hybrid battery on the way out? More signs and eventually codes will happen.
  9. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yep. It sounds like a classic undershoot of the SOC, which mostly seems to happen after the SOC has been "maxed out", and is a sign that that the battery capacity is degrading. Undershooting from 8 bars down to 1 seems like a particularly bad case (mine typically undershoots from about 6 down to about 3 - after it's coming back down from full), but it may have been exacerbated by the particular terrain on that trip and the use of cruise control. If I am expecting the undershoot I can sometimes drive so as to avoid or minimise it.
    See my post about this issue here: Traction Battery SOC "Meta-States" | PriusChat
    wjtracy likes this.
  10. sigmundSlo
    Ljubljana, Slovenia
    Thanks guys for everything.
    On last regular service I paid for additional battery check for longer guarantee... I hope it's still valid even though now the car is just over 10 years. :unsure:
    Hoping for the best...:rolleyes:
    wjtracy likes this.
