Hybrid battery -- Warning lights - Brake, Hybrid, Master, and Check Engine
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TommyG, May 3, 2011.
  1. spitinuri
    spitinuri Member
    317
    Latest: I got the car back yesterday. Once they replaced the inverter coolant pump all was good. The water pump was fine and not leaking. I did have the drive belt changed. Total: The non-warranty work was $124.
    I believe it helps....and this site helps. I walked in with a good understanding of what was going on. I would have questioned any other outragious repair offered (ie traction battery replacement).
  2. JohnnyCTPilot
    JohnnyCTPilot New Member
    Tom,
    I just purchased a 2008 Prius last week. I wish I had bought it years ago! I am really liking it so far, but trying to get up to speed on some topics.
    I purchased an extended warranty from the Toyota dealer where I purchased my "Certified Pre-Owned". Just trying to do a little "after the fact" homework to make sure I didn't get taken for a ride on anything. After reading your blog, I thought the folks you mentioned might give it to me straight.
    I would love the name of the MA dealer you referred to.
    Thanks!
    John
  3. NAsh072388
    NAsh072388 New Member
    Warren
    i can repair the battery for around 500 at my shop.... we service these cars all the time... im located in Michigan if that helps
    48,936
    what exactly do you do for $500.?
  5. NAsh072388
    Warren
    i replace the faulty cells in the battery.... depending on how many cells are bad is how much it costs but its roughly around the 500 mark.. once all cells are good everything works great... i just did one today llol.
