Hybrid Interface 2013
Discussion in 'Prius PHEV Plug-In Modifications' started by NortTexSalv04Prius, Jun 9, 2013.
  1. planetaire
    planetaire Plug in 20 kWh 85 km/h or > 208km range
    190
    139
    France
    Ho ! I think you will appreciate the attached file ;)
    • bms2.zip
      File size:
      107.6 KB
      869
    mrbigh and lopezjm2001 like this.
  2. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    Thats great. We can now start building some BMS2s.
    Thanks.
  3. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    Very cool, thanks for saving these! Glad that Norm put them out there before closing up shop, but still sorry to hear he's done.
  4. elman1
    elman1 Junior Member
    spain
    Do you know anyone who could manufacture a BMS+/2 ?
    I would be a buyer !
  5. lopezjm2001
    1,146
    407
    Sydney Australia
    No, but you can do the following DIY:
    1. Download the zip file http://priuschat.com/attachments/bms2-zip.72472/
    The zip file contains four files as shown below:
    2. Download the free software from the website ExpressPCB - Free PCB layout software - Low cost circuit boards - Top quality PCB manufacturing, as shown below.
    then install the programs ExpressPCB.exe and ExpressSCH.exe.
    3. Run the program ExpressPCB.exe and then open the file BMS2.pcb. It should look like below.
    4. Order the PCB online using the program ExpressPCB.exe . Select "LAYOUT" in the drop down menu. Then select "Order boards via internet..." as shown below. Just follow the prompts.
    5. Once you receive the PCB by mail you just need to order the list of electronic components from Digikey, they are listed in a file called BMS2basicparts.xls. As shown below.
    6. Use some soldering skills to solder the electronic components onto the PCB. The finished PCB should look like below.
    7. Buy a metal box (included in parts list from DigiKey) to house the PCB. Then it should look like this:
    The grey plug inlet is for uploading the Hex code using the Silabs USB programmer.
    The black plug inlet is for a plug to wire into the Prius Canbus wires at the OEM battery ECU at the rear of the car next to the OEM battery. As shown in photo below. This plug also powers the BMS2.
    The red 6 dip switches 1 and 2 are used to select which processor (BL or BR) to upload Hex code into BMS2.
    Switch 1 - BL Sw1 up and sw2 down to upload BL hex code.
    Switch 2 - BR Sw2 up and sw1 down to upload BR hex code.
    Switch 3 - P1 - Standalone end voltage 200-214v(J9 open) or 210v-224v(j9 closed).
    Switch 4 - P2 - Standalone end voltage 200-214v(J9 open) or 210v-224v(j9 closed).
    Switch 5 - P3 - Standalone end voltage 200-214v(J9 open) or 210v-224v(j9 closed).
    Switch 6 - P4 - OEM pack/Lithium pack, Up - Lithium (uses set end voltage) Down - OEM pack.
    j7, j8, j9 - jumper 7, jumper 8 and jumper 9 are located together at center of BMS2 PCB.
    More detail of the rear terminal block can be found here blank
    The black round inlet is for a power plug from a DC power supply. It must have a DC power plug of type 2.1mm x 5.5mm, center positive, rated at anywhere between 8v to 18v, 100mA or higher. You will need this DC power supply to upload the Hex codes, should only be used when BMS2 is not connected to the Prius.
    8.Run the program called ExpressSCH.exe and then open the file BMS_harness.sch drawing to wire the BMS2 into the CANbus wiring. As shown below.
    Also see this http://priuschat.com/attachments/installation-of-a-bms2-pdf.74408/?temp_hash=54d602b27fa5965f148cee6f35341824
    9. Upload the HEX code (BL and BR) into the BMS2 (same as V4) as described here: CAN-view Downloads
    Need to buy a USB Programmer (US$40.32) from Digikey, part # 336-1182-ND to upload Hex code into BMS2. This will function on all newer laptops and desktops. They also have a free software program, UtilDLL.exe which you can download from their website: here
    Actual HEX code files are here: http://priuschat.com/attachments/bmsplus-bms2-codes-zip.72471
    For BMS2 use the two Hex code files BL2oct242.hex and BRapr029.hex
    10. Read the introduction to BMS2 here blank
    For more info read a archived copy of Norm's website before it closed down - CAN-view index
    #25 lopezjm2001, Jan 13, 2015
    jc.maquet, planetaire and miscrms like this.
  6. mrbigh
    3,686
    699
    Long Island, NY
    Easy enough to have a brand new BMS2
  7. elman1
    spain
    what was your final cost for your homemade bms2 ?
    care to build me one ?
    ..open question to those who successfully followed instructions.
  8. mrbigh
    3,686
    699
    Long Island, NY
    No, I never built one from scratch. I receive Production/test prototype number 1, a loooong time ago
  9. miscrms
    2,076
    523
    Phoenix, AZ
    Playing with the ExpressPCB software a bit, its estimating $106 shipped for 2 boards on their standard budget process (no silk sceen, no solder mask). On their protopro option, its estimating $180 for 4 boards shipped with the fancier (and perhaps easier to assemble) silk screen and solder mask steps.
    Rob
  10. elman1
    spain
    do they also offer assembling service, providing you send them parts list ?
  11. lopezjm2001
    1,146
    407
    Sydney Australia
    No.
  12. lopezjm2001
    1,146
    407
    Sydney Australia
    I calculated a price estimate of US$288 & delivery for doing this project as shown below:
    planetaire likes this.
  13. whereswally606
    whereswally606 Junior Member
    uk
    So I have really liked what planetaire did with his prius second gen.
    I looked into getting a bms+ which led me here and then I got annoyed that the original pcb files were stuck in proprietary expressPCB format.
    After a lot of tinkering I think i've managed to extract the bottom top and silk gerbers from them so that you can use your own preferred fabrication house which should be a lot cheaper or just make the boards yourself.
    I don't know however about the drill map so that's a potential issue
    this process I roughly followed was from another website but I can link so here is the content
    Open your ExpressPCB file and Print, selecting the new PS printer.
    I chose TOP and BOTTOM layer only.. it will ask you to name a the File.
    Now using CadLink 5; //(I used linkcad 9 trial)
    Import > POSTSCRIPT Export > Gerber RS-274-X
    NEXT
    select "Treat White areas as holes"
    NEXT
    under "Geometry Settings" I changed 0.001 to 0.02 default line width //didn't need to do this
    NEXT
    locate your PS print file and OK
    then complete the sequence of naming and saving.
    but used linkcad 9 trial to process from ps file to gerber format.
    There was a bit a tinkering needed to get a suitably aligned print from the original but this should now be more accessible to the home gamer crowd. I found the silkscreen objects contained the hole pads and this meant ungrouping and deleting silk object individually, expressPcb made it sufficiently tedious to reverse engineer their pcbs that I wont make a habit of it. Also the silk screen objects hanging of the left hand side of the board pushed the print out of alignment so I deleted any overhanging lines to fix that.
    my situation is that I own a Honda insight mk1 hybrid and my wife has a leaf, but we are about to have our second child and the insight being a 2 seater is not going to fulfil the remit of holiday/long journey family car. the Leaf is a 2011 jap import one but its not got amazing range so travelling the 200miles required is not going to be probably on the odd occasion its needed.
    If I can get a cheap 2nd hand 2nd gen prius and do what planetaire has done I will tick a lot of my required boxes.
    Please find attached the new gerbers. this are untested use them at your own risk.
  14. bisco
    48,962
    welcome! please keep us posted on your progress, all the best!(y)
  15. whereswally606
    uk
    So I had a go at solving my drill file dilemma. I have something probably workable in that they are all in the right places, but I didn't manage to align the drill file with the pcb copper and silk layers. I'm hoping that the PCB fab shop can do this without much bother.
    Anyway a quick look on line shows 5 boards for $42 delivered. Hope somebody can make use of this. the other big cost in this project is that $35 hex flashing dongle.
    planetaire, lopezjm2001 and bisco like this.
  16. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    Im sorry guys, for asking probably a "stupid" question.
    I wish someone can explain what this new bms2 does. Is it something that bypasses the stock BMS, and controls another battery installed on the vehicle?
    Thanks
  17. whereswally606
    uk
    Not a stupid question and one I'm not sure I know the answer to but...
    I think it does what the bms+ did and then a bit more but I don't know what more and I'm only really bothered about the bms+ functionality to replicated what planetaire did on his 129mile ev only miles prius gen 2. I think the point for me is to allow the car to use more than the stock ah in the nimh battery that limits you to adding meaningful range with an auxiliary extra battery.
    In other news I found a brilliant program called gerbV, not to beconfused with gerbview, GerbV has allowed me to align the drill map gerber with the rest of the copper in the silk screen so I think I may now have a proper set of files to be able to send to a fabrication house of your choosing or role your own. But as always, this isn't tested, do your own checking before blaming me please.
  18. whereswally606
    uk
    Lastly this is the fullset of gerbers with a solder mask layer top and bottom (which is the same). clearly there are only a couple of smt parts on the board so this should suffice. I've sent the design off to pcbway to see whether they will produce it and how much for. if anyone else is interested I should have 4 left to sell.
  19. whereswally606
    uk
    good news, the pcb passed audit. If people are interested please message me. I only intend to cover my costs as I don't need 5 boards. Also I haven't bought the prius yet so I wont order the boards till I have 4 interested parties or when I buy the car (whichever comes first)
  20. lopezjm2001
    1,146
    407
    Sydney Australia
    Sounds like a good deal. $8.40 each plus delivery? Shame I already have one. Thanks.
