1. Offline
    Linda L Junior Member
    Start a Conversation
    Feb 22, 2008
    35
    Your Vehicle Year:
    2002 Prius
    I was on my way home (a 50 mile trip on very rural roads) when my hybrid warning light came on. The car seemed to be operating fine, so I continued on. About 20 miles from home, the computer display lights flashed on and off and the car died. After coasting to a stop, I let it sit for a couple of minutes and turned it back on, and continued on. Warning light was still on. Probably ran about 7 miles or so and died again. This same scenario happened a couple more times, but I did manage to get home.
    My Prius is a 2002 with a little under 150000 miles on it, and it has never given me any problems since I bought it at 70,000 miles four years ago.
    I will be calling the Toyota dealer tomorrow, but I wanted to ask whether or not this sounds like a possible battery pack failure.
  2. Offline
    cwerdna Senior Member
    Sep 4, 2005
    11,802
    1,718
    SF Bay Area, CA
    Your Vehicle Year:
    Please tell us the codes the dealer/repair shop is able to retrieve.
    WendyJ likes this.
  3. Offline
    seilerts Battery Curmudgeon
    Mar 7, 2010
    3,296
    1,415
    Santa Fe, NM
    Your Vehicle Year:
    This sounds like the inverter pump.
  4. Offline
    usnavystgc Die Hard DIYer
    Jul 29, 2011
    1,358
    375
    Bowling Green, KY
    Your Vehicle Year:
    I agree. Classic inv pump symptoms. I just hope the inverter held out.
  5. Offline
    WendyJ New Member
    Jul 8, 2012
    Your Vehicle Year:
    2002 Prius
    Hi Linda,
    I am having the same problem at the moment with my 2002 Prius. Was wondering if you had your car fixed and what was the diagnosis? thanks.
  6. Offline
    Sep 4, 2005
    11,802
    1,718
    SF Bay Area, CA
    Your Vehicle Year:
    It would help to provide us w/the codes.
  7. Offline
    Avi's Advanced Automotive Independent hybrid repair shop
    Jun 28, 2012
    381
    126
    Your Vehicle Year:
    Inverter water pump and battery failures will sometimes allow you to re-start the car and drive a short difference. It is very easy to determine if the inverter water pump is working. You can find some info on it here: Luscious Garage | Blog | Gen 1 Prius code P3130: Inverter System Cooling Malfunction
    Usually the MFD will show a red square with a battery in it when the battery is the problem. Keep in mind, these are only the most common problems and you may have something else a fault.
  8. Offline
    ahmeow Prius Lover
    Nov 11, 2010
    288
    North CA
    Your Vehicle Year:
    Sorry for the happening. But a 150000 miles car can still let you drive home was a bless from God. We are waiting for the finding of your dealer.
  9. Offline
    Feb 22, 2008
    35
    Your Vehicle Year:
    2002 Prius
    It was diagnosed with inverter coolant pump failure. I also had the inverter fluid changed at the same time. The car has run great since then, and now has 152K on the odometer.
    usnavystgc and bwilson4web like this.
Share This Page
