Hydrogen Highway's Dead End. FINALLY !
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by hill, Mar 6, 2008.
  1. Fibb222
    Fibb222 New Member
    1,499
    99
    I guess you missed all the recent studies showing that the CURRENT electricity grid could accept at least 70% of the cars today as plugins.
    The grid is not a problem, in fact it would be stabilized and made more efficient by plugins. It would also allow for the adoption of more intermittent power generation from wind and solar.
    The making, distribution and storage of H2 is expensive and will never be cost effective enough to compete with battery electrics in the transportation sector.
  2. Devil's Advocate
    922
    Las Vegas, Nevada
    Well go ahead and tell everyone that this summer when the grid goes down AGAIN, because everyone has their AC on. Or the people in Florida that lost power for days because of a grid failure. I'm sure the grid can, on average, take a considerable amount of charging from plug-ins, especially if done at night, but full scale recharging and at peak times?? It can;t handle the loads NOW. Link that study, I'll check it out though.
    Under todays tech, yes, but it wasn't long ago people said the same about batteries. Plus show me the battery pack that can muscle 60,000lbs of an 18 wheeler down the road for 10 hours. (or even one on the drawing board)
    Yes advance in battery technologies is important, and will be responsible for most of the future efficiency, but you still need a fast loading potential energy source. If batteries can do it, so be it, but I don't see batteries that can allow a car to drive 600 miles in a day and be rechargerd in under 5 minutes. As we now do with oil or another potential energy source.
  3. nerfer
    nerfer A young senior member
    2,505
    233
    28
    Chicagoland, IL, USA, Earth
    Well, you do a good job living up to your name!
    For the same price, they can. A basic fuel-cell powered car would cost multiple times that of a Tesla, which has a range of over 200 miles per charge. Recharge while you sleep at home.
    Today's commercially sold H2 comes from natural gas. Not real environmentally friendly either.
    Again, H2 is made from natural gas. We would have to import that, probably from Canada. Can't import H2, because it's a terrible transport medium - it's the smallest element in nature, can leak thru anything including steel - which it makes brittle as it does so. Leaks can't be visually detected. Ethanol or biodiesel can be retrofitted into existing oil pipelines.
    Same could be said for powering EVs.
    It would need to be considered. I doubt the grid would collapse, it would just be more utilized at night. It will take a decade to really make a difference on the makeup of the consumer fleet.
    Okay I won't tell you that. It could be done, but it's already largely done for other options, so why build something new for something that still needs breakthroughs in production, storage, and economic fuel cells?
    Even if you could make a fuel-cell powered vehicle for under $100K, it would still need a good set of batteries to handle the sudden power needs of acceleration. Fuel cells would be best suited for a serial hybrid layout.
  4. Fibb222
    Fibb222 New Member
    1,499
    99
  5. jimtompkins
    jimtompkins New Member
    Va
    Why not just electrify the Interstates. Drive and charge your battery at the same time. Use the battery for local. It works for trucks to. No new technology required.
  6. burritos
    burritos Senior Member
    4,946
    252
    Advancing fuel cell technology is too expensive compared to advancing battery technology. At least that's what my sister said who worked for 2 fuel cell companies.
    Yes. Biofuels is a loser in america. Too many people drive and we don't have the water to grow enough fuel.
    Fuels cells is not a source of energy, it's an expensive battery. There are not pools of H2 to be drilled and pumped into our fuel cell tanks. That'd be like saying that loaded springs is a good energy source except for the fact that we have to wind up the springs before we can use them. The energy to split the h20 to h2 and 02 will inevitably come from dirty fossil fuels, so you might as well combust the dirty fuels to get mechanical enery which would maximize your energy return INSTEAD of combusting them to convert into H2 which in turn you would chemically convert with 02 to H20 to extract electrical which you then would convert to mechanical energy.
    Are you saying we would be cleaner if instead of having large electrical facilities to make electricity for many, we each by our own individual gas powered electrical generator and install in every household. That just doesn't make sense.
    Well of course it wouldn't happen over night. As the demand increased then so would the supply. Limited fossil fuels supplies would drive up the price making green energy more competitive thus giving us the ability to green the grid.
    So you're saying that overnight(that's what 5 years is) we could implement a never used new technology infrastructure, but plugins would collapse an existing infrastructure because that couldn't grow?
    The other negative would be the exorbitant expense.
  7. Fibb222
    Fibb222 New Member
    1,499
    99
    Isn't ethanol too corrosive for pipelines?
  8. richard schumacher
    7,663
    1,038
    United States
    Artificial gasoline and kerosene, made from atmospheric CO2, would be carbon neutral and much easier to distribute and use in vehicles than hydrogen.
  9. Fibb222
    Fibb222 New Member
    1,499
    99
  10. chogan2
    chogan2 Senior Member
    1,066
    756
    Virginia
    There have been several good discussions of this in the distant past on PriusChat. In one of them, I looked up the facts on electrical generation and did some calculations. On average, day after day, in the US, the nighttime trough in demand is half the daytime peak. So there's a big hole that can be filled with car battery charging at night, without requiring additional capacity.
    If people would be disciplined enough (or if the chargers were set up to require) nighttime recharge, I estimated that nearly all US passenger car miles could be displaced by electricity before you would get to the point of straining the grid with the recharge load. The only trouble I saw was Fridays in August, when a) there's high air conditioning demand and b) lots of people are on long road trips for vacation. (Yes, travel distance really is that seasonal). There have been several, more careful studies that have said more-or-less the same thing plus-or-minus the August-Friday thing.
    So for the near term at least, this is a non-issue. As others have pointed out. It would take a lot of cars to fill the existing nighttime load trough.
    More to the point, by loading the grid evenly over the daily cycle, you get a) cheaper average cost per KWH and b) lower average pollutant per KWH. In the short run it's a win-win.
    So the point is well taken that you'd eventually have to accommodate the extra electrical demand from EV/PHEV, but if the vehicle recharge load is restricted largely to nighttime, this will not be an issue for decades yet.
  11. hill
    8,068
    And what would be wrong with just using the fossel fuel that got wasted in making hydrogen, as fuel, in the first place. Maybe you don't realize that if the bright minds at GM finally gave up on it (when GM & Toyota could have simply continued to have lobiests beg for more hydrogen research dollars if they believed there was a snowball's chance of any thing ever coming from it) then it really really really IS a looser.
  12. hill
    8,068
    whoops, double post ... the board's running slow again
  13. hill
    8,068
    To further chogan2 's point, about ONE THIRD of electricity goes to produce / refine, transport fossel fuel. Put THAT back onto the grid, rather than buying more terrorist oil, and you don't have the honking "electircity deficit" that the "grid gloom & doom'ers" predict.
  14. clett
    clett New Member
    537
    Scotland
    Nope, batteries are an excellent choice for the haulage industry, and for garbage trucks/construction etc.
    The most successful EV businesses here in Europe (Tanfield and Modec) are not producing passenger vehicles but trucks.
    At the moment they are only producing vehicles up to 7.5 tonnes, but the potential for scaling is certainly there as the bigger the vehicle, the better the case for batteries.
    Why start with truck EVs first and not passenger cars? Because for a haulage or delivery business FUEL is by far the biggest cost of the business (>70% in some cases, vs only 20% for a passenger car).
    For example, the fuel bill for a delivery truck doing 50,000 miles per year at 10 mpg would cost about £25,000 here in the UK, while it would cost only £5,000 if those miles were done on electric power. Those are huge savings for any haulier which is why the sales of EV trucks are taking off so well here.
    Battery-electric heavy goods vehicles: Feasibility analysis
  15. richard schumacher
    7,663
    1,038
    United States
  16. Fibb222
    Fibb222 New Member
    1,499
    99
    That's awesome. Medium to large diesel trucks are so loud smelly I look forward to seeing EV trucks replace them. I'm really glad to hear that it is possible. It can't happen soon enough for me.
  17. Tideland Prius
    16,066
    Indeed. I mean instant torque is good for heavy trucks. That's why they use diesels right?
    Purlator has a few hybrid delivery trucks here. Are there any over on your side?
  18. Fibb222
    Fibb222 New Member
    1,499
    99
    Haven't seen any yet. I hope to soon. What make or size are they?
  19. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    And the $0.50/gallon of OUR tax money paid to people who produce ethanol in the U.S.
    And the tax credits to GM for every 'flex-fuel' vehicle made. Just put parts that aren't sensitive to alcohol in ALL vehicles. No need to have 'flex-fuel' parts and 'regular rubber' parts. Maybe we should tax them double their credit for every flex-fuel vehicle they sell where there is no E85 available to the public.
    As usual, GM is using the laws as written, not as envisioned to further their goals. Clearly no congress (wo)man had something like the H2 in mind when they set the definition of 'commercial' on weight alone for EPA CAFE exclusion and commercial vehicle tax credits.
  20. bruceha_2000
    3,054
    301
    Northwest VT
    2018 Prius Prime
    And if we consider that people will finally have to get off their "I NEED MORE POWER" horse, the amount of energy needed to drive those miles will decrease.
    Arnold's conversion of an H2 to run on H2 isn't "green". It is still a hog that uses WAY more energy to drive a mile than is necessary or reasonable.
    Whether a 2 seat commuter or a 'I have a family of 6' vehicle, any Plug-in will be designed to use as little energy as possible and still get from here to there in reasonable fashion.
