1. Offline
    ibcs New Member
    Aug 26, 2005
    351
    31
    Englewood , Ohio
    Your Vehicle Year:
    Does anyone know how to make Scanguage show the correct mileage when using the Hymotion. When in EV mode the MPG does not show 9999 like it should. Sometimes it will show 200, 2300 or something else random.
    Love the Hymotion, but I have no idea what the actual mileage is at this point.
    ---Kent
  2. Offline
    TheForce Ron Paul 2012
    May 30, 2005
    3,428
    434
    Wheelersburg, Ohio
    Your Vehicle Year:
    I have the same problem. We are pretty much out of luck unless the guys that make the SG update the firmware to fix the issue.
    I cant wait to see some of your results.
  3. Offline
    ibcs New Member
    Aug 26, 2005
    351
    31
    Englewood , Ohio
    Your Vehicle Year:
    Have you contacted Scanguage to discuss the problem? If not, I'd be glad to give them a call. So far, I have driven 200 miles and lost the first gas bar. I know you have it tied to your computer, but the display shows 53.1 and scanguage is showing 74.1.
    ---Kent
  4. Offline
    boxer93 Psyched for PHEV
    May 9, 2008
    155
    22
    Southern NH
    Your Vehicle Year:
    Kent,
    I'm not using the SGII as my final MPG numbers. I will use my fillups. Which will be averaged over many fillups but will also take a while since I don't put a lot of miles on the car daily. I actually just filled up today 10/12(previous was 8/26). 957.2 miles 9.114 gallons That calculates to 105MPG. My MFD showed 98.8 at fillup. Other than the Hymotion, the only mods done to the car are 44/44PSI tires, reverse beep disabled, disconnected EV Switch.
    Chris
  5. Offline
    PeakOilGarage Nothing less than 99.9
    Oct 3, 2008
    334
    Pacific Northwest
    Your Vehicle Year:
    boxer93,
    are you considering the engine block heater with the Hymotion system?
    If not, why?
    Thanks
  6. Offline
    ibcs New Member
    Aug 26, 2005
    351
    31
    Englewood , Ohio
    Your Vehicle Year:
    I'm sitting at 305 Miles on this tank with three bars gone on the gas gauge. It will be interesting to see what numbers that I come up. I think my display does not show correctly when over 99.9 MPG.
  7. Offline
    May 9, 2008
    155
    22
    Southern NH
    Your Vehicle Year:
    I already purchased the EBH and I connected up my timer this past weekend. I needed to get better ramps to put the car up (borrowed them from my brother). I have been having thoughts as the cost benefits. Currently (warmer weather) I use .08 to .09 gallons of gasoline on my morning commute. At $3.02 a gallon that's .24-.27cents for the trip. By pluging in the the EBH for 3 hours @ $ .16/kWh that is ~.20 cents per day. With the hills, traffic lights and speed I doubt that I will only use .01-.02 gallons for the trip. I do believe that the cabin would be warmer faster as the days get colder. I hope to get it in next weekend. I also wanted to get my first full tank in before doing other mods so that I have something to compare it to.
    Chris
  8. Offline
    Oct 3, 2008
    334
    Pacific Northwest
    Your Vehicle Year:
    How much electricity does the EBH pull when it is on? Does it really need to be on 3 hours to get the engine at the optimal temp?
    I have no experience with EBHs. I am waiting for the Prius EBH that I ordered last week. That is why I am asking these questions.
  9. Offline
    Arthur New Member
    Oct 10, 2008
    78
    Corning, NY
    Your Vehicle Year:
    I've gone 229 miles since my last gas fill-up and my fuel gauge is still displaying ALL the bars! I don't have a ScanGauge, but my Prius display says that I am averaging about 78 mpg. If that's true, I should have used almost three gallons by now. So, my actual milage may be a little higher.
    Arthur
  10. Offline
    Oct 3, 2008
    334
    Pacific Northwest
    Your Vehicle Year:
    Does anyone else get the feeling that the fuel display becomes very inaccurate with a Hymotion battery installed? That is my first impression.
  11. Offline
    Codyroo New Member
    Oct 24, 2007
    1,192
    199
    Pleasanton, Ca
    Your Vehicle Year:
    I asked a similar question a few months ago. Was told that the EBH draws about 300 Watts.
  12. Offline
    Oct 3, 2008
    334
    Pacific Northwest
    Your Vehicle Year:
    That would mean it is drawing about 3 amps from a 110/120 volt outlet.
    If that is accurate, then if your electric rate is 10 cents per kwh (USA ave), you likely are only being charged about 3 cents per hour to run the engine block heater.
    So the only variable left to calculate is length of time. How long does the EBH need to be allowed to run to get the Prius engine to the optimal temp? Then put the EBH on a progammable timer and set it to preheat the engine that amount of time before you typically leave in the morning.
  13. Offline
    May 9, 2008
    155
    22
    Southern NH
    Your Vehicle Year:
    In reading through the EBH threads the consensus seems to be around 3 hours. Also forged into the end of the heating element is 400W. I am pretty sure that this is not a precision element and it will vary. I have been using 400W as my estimate. I do hope that many of you only have to pay $ .10 /kWh (or less) for your charges. Our base rate is .095 but once you factor all the other costs on the electric bill ours is .16 /kWh.
    Chris
  14. Offline
    Oct 3, 2008
    334
    Pacific Northwest
    Your Vehicle Year:
    My local electric rate is 0.08 per kwh. After 600 kwhs, it is about 0.09 per kwh. 70% Hydroelectric in the Pacific Northwest. :)
    But even using 400 watts per hour X 3 hours = 1.2 kwhs.
    High cost electricity: 1.2 kwhs X 0.16 per kwh = about 19 cents per day to preheat your engine.
    Low cost electricity: 1.2 kwhs X 0.09 per kwh = about 11 cents per day to preheat your engine
    So with gasoline at $3.00 per gallon, does it make sense to use an engine block heater? $4.00 per gallon?
    If you goal is to merely save money, it likely didn't make sense to install the Hymotion system to begin with. :)
Share This Page
