1. Offline
    jelloslug It buffed right out!
    Jun 11, 2008
    807
    36
    Greenville, SC
    Your Vehicle Year:
    It works well. :D
    [IMG]
    2 people like this.
  2. Offline
    cicily New Member
    Jan 2, 2009
    Hampton, VA.
    Your Vehicle Year:
    looks good, but maybe i'm missing the point... what exactly does it do?
  3. Offline
    Jun 11, 2008
    807
    36
    Greenville, SC
    Your Vehicle Year:
    It make the drivers seat go up and down.
  4. Online
    Mar 8, 2008
    9,153
    1,793
    Your Vehicle Year:
    How did you make that happen?
  5. Offline
    Jun 11, 2008
    807
    36
    Greenville, SC
    Your Vehicle Year:
    1 part Corolla seat, 1 part Prius seat, and 1 part weekend. I have several pics of the install that I'll upload soon.
  6. Offline
    cicily New Member
    Jan 2, 2009
    Hampton, VA.
    Your Vehicle Year:
    please do, i'd love to see and also maybe try if it's not too difficult. I am not too handy but my husband is.
  7. Offline
    paprius4030 New Member
    Aug 12, 2004
    1,761
    60
    Pocono's, Pa.
    Your Vehicle Year:
    WOW I'd love to see that also? How much does it allow you to move the seat up and down?
  8. Offline
    Jun 11, 2008
    807
    36
    Greenville, SC
    Your Vehicle Year:
    At least 2 inches, maybe 3. It's does not just go straight up and down; when you lower it, the back goes down more than the front. I'm 6' 3" and it does wonders for me.
  9. Offline
    thepolarcrew New Member
    Jun 17, 2008
    4,426
    270
    North Dakota
    Your Vehicle Year:
    Is this the car that was repaired from an accident?
  10. Online
    Mar 8, 2008
    9,153
    1,793
    Your Vehicle Year:
    That's amazing, this promises to be more exciting than your instructions about how to bake a headlight! :D
  11. Offline
    Jun 11, 2008
    807
    36
    Greenville, SC
    Your Vehicle Year:
    Here we go. To start off this modification in not easy. I started out using the directions that have been posted here before. I acquired a used Corolla seat from a local junk yard for $50. Any corolla seat from 03-08 will work.
    [IMG]
    I removed the trim and handles from the Corolla seat.
    [IMG]
    I then removed the lower fabric and foam.
    [IMG]
  12. Offline
    Jun 11, 2008
    807
    36
    Greenville, SC
    Your Vehicle Year:
    Here are some important parts to keep:
    [IMG]
    Here is Corolla frame stripped down:
    [IMG]
    The other person that did this install used the Corolla frame with the Prius rail feet and the top section of the Prius seat frame. My Corolla frame was a rusty POS so I decided to go a different route.
  13. Offline
    Jun 11, 2008
    807
    36
    Greenville, SC
    Your Vehicle Year:
    Here is the vertical lift mechanism on the Corolla.
    [IMG]
    Here is the Prius seat frame. All the holes form the vertical lift mechanism are there.
    [IMG]
    I then started removing the lift parts. Everything was riveted together. I first drilled a small hole through each rivet and then removed the outer head. I then can drill and tap the small hole for a bolt and washer later.
    [IMG]
    [IMG]
    [IMG]
  14. Offline
    Jun 11, 2008
    807
    36
    Greenville, SC
    Your Vehicle Year:
    Here is the Prius frame with the lift mechanism.
    [IMG]
    Here is the Prius frame with the entire lift mechanism. I used high grade bolts to bolt all the previously riveted parts back in. I had to used countersunk screws for the ratchet mechanism for clearance.
    [IMG]
    Here is a shot from underneath.
    [IMG]
  15. Offline
    Jun 11, 2008
    807
    36
    Greenville, SC
    Your Vehicle Year:
    Here is the reassembled seat without the rack.
    [IMG]
    Now for the seat racks. The one on the left is the Prius seat frame, on the right is the Corolla seat frame. The basic shape and mechanism is the same but the mounting points for the seat frame and for the floor pan are totally different.
    [IMG]
    I removed the feet from the Prius rack (they are riveted and spot welded on) and mounted them with grade 8 bolts and welded them in place.
    [IMG]
    I also sandblasted the rusty parts and painted the rack.
    [IMG]
    Now with the reconfigured rack mouted to the rebuilt seat is a drop in seat.
    [IMG]
    1 people like this.
  16. Offline
    Jul 12, 2007
    10,558
    430
    Adelaide South Australia
    Your Vehicle Year:
    That's beautiful.
  17. Offline
    CharlesJ New Member
    Dec 13, 2008
    433
    Monterey
    Your Vehicle Year:
    Never too late to start:D
  18. Online
    Mar 8, 2008
    9,153
    1,793
    Your Vehicle Year:
    Amazing, and congratulations on an excellent job done.
    What is the procedure to remove the Prius seat cushion and seat back from the original seat? Did you have to worry about the side airbag triggering?
  19. Offline
    edthefox5 New Member
    Jul 25, 2007
    1,513
    198
    Clearwater, Florida
    Your Vehicle Year:
    Jelloslug cannot be stopped. Well done and a tip of the hat to you sir.
  20. Offline
    Jun 11, 2008
    807
    36
    Greenville, SC
    Your Vehicle Year:
    The seat bottom was very easy; just remove the plastic trim off the sides and the fabric just just clipped on with "J" channels all around the edges. The fabric and the foam comes off in one piece. The rear was a bit more complex. You have to remove 3 hog rings from the bottom edge and then peel the fabric up the seat removing a few more hog rings along the way. Also, at the airbag there is a sewn in strap that has to be unbolted. Once the fabric is off the foam just slides off and then you can unbolt the airbag. I had no problem with the airbag; it won't go off unless you apply power and it has a special connector that covers the pins when the mating connector is unhooked for safety.
Share This Page
