1. Offline
    RaZa Member
    Start a Conversation
    Nov 7, 2011
    357
    48
    Your Vehicle Year:
    I've been using the ac in the florida sun here, and still easily get in the low 50's
  2. Offline
    Sporin Prius Noob
    Dec 10, 2010
    326
    64
    Windsor, VT USA
    Your Vehicle Year:
    The AC runs when you are in Defrost mode, even if the AC button isn't lit, even if you have the temp set warm. That's how pretty much every car build since the late 90's has been. AC dehumidifies, that's why car manufacturers link the AC and Defrost.
  3. Offline
    skwcrj Member
    Nov 25, 2011
    204
    34
    Gig Harbor, WA
    Your Vehicle Year:
    I don't use the "Front" Defog/Defrost. I can do the same with just outside air, heat (increase temp using the selector knob), and air outlet selection (windshield). Maybe the hatchback is different in this respect... other than the "Front" Defog/Defrost button, I can enable or disable the A/C separately by pressing the switch.
  4. Online
    Aug 14, 2006
    18,177
    3,460
    Sacramento, CA.
    Your Vehicle Year:
    Using the AC in the California sun drops me into the low 60s. :)
  5. Offline
    Xaran Junior Member
    Jul 16, 2012
    97
    17
    Your Vehicle Year:
    A little over 5 weeks of owning my Prius, I played with most of the techniques to get the most mpg for the first few weeks. But I found that for my drive, 135 miles r/t 5 or 6 times a week for work commute on So Ca freeways it was not a lot of fun so Ive taken to driving the car like a normal car and probably even accelerating harder in it than my other cars since it has much less power than what Ive been driving for the past 7 years.
    Im still getting an average of 45 mpg, 85 mph, accelerating with the pedal to the floor in Power Mode and the A/ C on at 74 degrees. Thats 2 twice what I used to get and Im using Regular gas.
    So Im happy , this car will save me over $ 3,500 per year
  6. Online
    Aug 14, 2006
    18,177
    3,460
    Sacramento, CA.
    Your Vehicle Year:
    Hypermiling with 17s is more difficult than it is with 15s and the results are less impressive. When I would run 17s I would give up on hypermiling and I would just drive. Obviously my mpg would drop but the car was simply more fun to drive. I can totally understand why you gave up trying.
  7. Offline
    Sporin Prius Noob
    Dec 10, 2010
    326
    64
    Windsor, VT USA
    Your Vehicle Year:
    Interesting, I can't get nearly enough airflow onto the windshield without using the Front Defrost button. Then again, maybe I'm a heavy breather. ;)
Share This Page
