1. Offline
    aaskew New Member
    Start a Conversation
    Feb 27, 2006
    I have just purchased a 2006 Prius (Package IV) that was supposed to include mp3/wma disc playback, but so far I have been unable to play my mp3 discs. When I put them into the CD player, the Prius thinks for a minute and then simply gives a one line response: "No music file." Then it sends me out of the audio screen back to the energy screen.
    The discs I'm trying were burned from Windows XP using Sonic DLA. I have tried with folders and without folders on the discs and I know the discs are okay because I have a cd player in my home that plays mp3 discs and they play fine.
    Am I missing something obvious? Do I have to burn these discs with any particular tools? Or perhaps I just did not get the CD player I was supposed to get?!
    If you have any ideas or suggestions, I would greatly appreciate them.
    Regards,
    Alan
    Vassalboro, Maine
  2. Offline
    ttabbal New Member
    Jan 16, 2006
    I don't know about Sonic software, but I just made a playlist in iTunes and told it to burn a data disc. It works just fine. One thing you might try, select the files you want to burn, right click, and select "Send To" then select your CD burner. That will use the Windows XP burning utility to make a standard data disc. That should work. Try just one file as well to make sure it's not a directory structure thing.
    Also, make sure you are sending non-encrypted MP3 or WMA files, no DRM stuff. I know you said it works in your other player, but just to be sure...
  3. Offline
    walt New Member
    Jan 14, 2006
    195
    Bel Air, MD, USA -=- Blair, Merlin, Merka
    Your Vehicle Year:
    Try a different brand of CDs. If you are using ones with the blueish bottom, try the silver-colored ones. My 2006 plays mp3 just fine, and I use silver-bottomed CDs.
  4. Offline
    AlphaTeam New Member
    Jul 17, 2004
    643
    Earth
    Your Vehicle Year:
    I'd also lean on the side of bad media.
    What kind of files you using?
    What bit rate?
    How is the file named AND tagged?
  5. Offline
    HokieHybrid New Member
    Dec 16, 2005
    200
    Your Vehicle Year:
    ttabbal, any luck with getting iTunes to convert songs you've purchased from iTunes into MP3 for your Prius?? I have other music that was already MP3 that worked just fine, but I couldn't get iTunes to do it yesterday. And of course all my new music is what I want in my car....any help would be appreciated, and save me frustration when I find time to try again (at this rate, it will be mid-March).
  6. Offline
    aaskew New Member
    Feb 27, 2006
    Thank you for your responses. I ended up trying ttabbal's suggestion and I burned the disc using Windows Media Player and it seems to work fine. Somehow Sonic had been installed as the default on my computer, but I'm all set now.
    Thanks again!
    -Alan
  7. Offline
    vortx21 New Member
    Dec 9, 2005
    23
    Burlington, VT
    DLA is generally a bad idea if you'll be taking the disc to another system than it was burned on. Same with InCD or DirectCD, they're all the same idea.
  8. Offline
    ttabbal New Member
    Jan 16, 2006
    iTunes is specificly designed to not allow that. Complain to the RIAA about it if you don't like it, Apple can't do anything about it. The only option is to burn them to audio CD them re-rip into MP3. But that kills the quality of the music and you lose all tagging information. There used to be a way to decrypt them, so you would get to keep the tags at least, but I don't know if it still works. Google for "Hymn".
    That is the biggest reason I have never bought anything from iTunes Music Store. I own a dozen things that can play MP3, I own 2 that can play encrypted AAC (iPod and Computer, and both of those can play MP3 just fine as well). So I get my music on CD for the most part. Used CD places have decent prices most of the time. And there's always P2P and places like AllOfMP3.com as well. Personally, if you bought it from iTunes, I wouldn't hesitate to get it from another source as MP3 so you can actually use it. After all, you paid your license fee for it. But that's just my take on it.
    I guess the other option is to use an iPod and play the music through the Aux-In port on your Prius. I do that with audiobooks all the time. You didn't mention an iPod, so I'm assuming you don't have one.
  9. Offline
    Armature New Member
    Mar 31, 2005
    55
    Scottsdale AZ
    Your Vehicle Year:
    Have iTunes burn your purchased tracks to a regular audio CD (a rewritable will work if you don't want a bunch of audio CDs lying around). Anything, including iTunes, will convert an audio CD to MP3. Then build your data CD using the MP3s.
    David
  10. Offline
    kdmorse New Member
    Oct 15, 2005
    201
    Germantown, MD
    Your Vehicle Year:
    Windows XP using Sonic DLA....
    All these application use the UDF file format (also called Packet Writing), which is specifically listed as incompatible with the Prius's MP3/CD player. In fact, they're generally incompatible with nearly everything. As a general rule, if the application makes the CD drive look like a big floppy disk in your system, that's bad, and the disk is unlikely to be universally readable.
    You want to use any application that will burn ISO or Joilet formatted disks. Anything that asks you what files you want to burn, and then has a big Burn button will do.
    -Ken
Share This Page
