1. Offline
    Prius42 New Member
    Start a Conversation
    Mar 20, 2010
    140
    39
    Maryland
    Your Vehicle Year:
    Well, I think I'm getting the hang of this car after 3 months. My mileage has been steadily increasing as the weather has gotten warmer and as I've adjusted my driving a bit. If I drive fairly normally i get about 55 mpg (HSI, ~52 mpg actual). If I'm more careful I get closer to 60 mpg HSI. If I'm really careful I get over 60. My last tank was 61.8 (HSI), and 59.6 mpg from the fillup (see attached). I put 10.13 gallons in the car for 604 miles. I call that 60 mpg, and I'm pretty pleased. This is for a week of normal commuting which includes lots of hills, about 1/3 surface streets, 1/3 state highway, and 1/3 interstates with occasional stop-and-go. It is pretty hot here these days so the AC runs constantly. I have only seen my mileage get better with time so I haven't seen it roll over as the weather has gotten really hot, but that may be that any affect is counteracted by my learning to drive this car.
    The car has the larger mudflaps front and rear, AC always on, and it is quite hot and humid here. None of this seems to have much affect. If it does then it will take some very careful analysis to figure it out. Things that I've found that do make a big difference is accelerating hard, using the friction brakes (obviously), and short trips. That warm-up cycle is deadly and it really kills my mileage for the first couple of miles of a trip.
    All of this is stuff you-all already know. I'm just pointing out that it is penetrating my thick head. Thanks all!
    2 people like this.
  2. Offline
    • Moderator
    27,669
    1,300
    Your Vehicle Year:
  3. Offline
    DetPrius Active Member
    Apr 24, 2009
    540
    84
    Southeast Michigan
    Your Vehicle Year:
    Very cool! I'm also on a new record tank with it at 61.2 and around 600 miles on the tank with 2 bars left. At one point this tank, I was as high as 63.5. Yes, the short trips with that warm up cycle just kill the MPG.
  4. Offline
    Codyroo Senior Member
    Oct 24, 2007
    1,694
    409
    Pleasanton, Ca
    Your Vehicle Year:
    Very nice indeed, especially with running the A/C (imagine that, 60 mpg AND comfort at the same time). Congrats!
  5. Offline
    • Moderator
    May 11, 2004
    14,020
    1,329
    Far-North Chicagoland
    Your Vehicle Year:
    Well, all I can say is: :rockon::cheer2::thumb:
  6. Offline
    • Moderator
    27,669
    1,300
    Your Vehicle Year:
    I think that's the strength of the new Prius. In the old one, I had to sacrifice A/C to get that kind of mileage.
  7. Offline
    Mark57 Active Member
    Aug 14, 2009
    1,043
    142
    OKC
    Your Vehicle Year:
    Very good! I just recently broke my own record. It takes time to learn but it can be done. I keep having to make high speed trips with the car loaded with 4 people with A/C so my mileage runs have to happen when i can find a week or so without those trips.;)
  8. Offline
    spiderman wretched
    Jul 5, 2009
    6,750
    1,174
    Alaska
    Your Vehicle Year:
    I see your average speed is fairly low which helps out immensely. What is your typical drive like (speed, elevations differences, etc)?
  9. Offline
    Downrange New Member
    Apr 15, 2010
    170
    27
    VA
    Your Vehicle Year:
    Congrats! These cars are fully capable of 60 MPG indicated - I've done it on my best tank, and may break it this tank, as I'm at 60 halfway through, and usually improve on the second half.
    I don't think the electric AC cuts much from the MPG, honestly, and it really works well!
    A couple of lessons learned: you don't have to drive with the ICE in ECO, and it's sometimes better to pulse up to speed and glide, even if you go well into the PWR area. Also, I never sit and idle in warm-up mode, but use the ICE to move the car along for the first couple of minutes - that seems to help. The HSI is definitely our friend, though.
  10. Offline
    Judgeless Senior Member
    Jun 30, 2009
    1,831
    223
    Cleveland, OH
    Your Vehicle Year:
    Well done. My last few tanks have been over 60 MPG also. My new goal is to get 700 miles out of a tank.
    I drive normal with the A/C on all the time. I always use ECO mode, cruise control and try real hard never to go over 60 MPH.
  11. Offline
    jwads New Member
    Aug 3, 2009
    63
    Los Angeles CA
    Your Vehicle Year:
    If I could get 500 Miles and 50 MPG indicated I would be in heaven. Stupid Socal traffic and all the stop and goes...
  12. Offline
    nahtanoj New Member
    Mar 7, 2010
    36
    san diego
    Your Vehicle Year:
    well, i've managed 500 miles on a tank. now after seeing this i'm gonna have to shoot for 600 miles. well done.
  13. Offline
    Aug 14, 2009
    1,043
    142
    OKC
    Your Vehicle Year:
    OK, guys you've motivated me to try and break my previous mpg record. I'll start a new thread with the gory details so as not to hijack this one.
    Prius42, keep up the good work.
  14. Offline
    Prius42 New Member
    Mar 20, 2010
    140
    39
    Maryland
    Your Vehicle Year:
    Well, it is hard to describe my typical commute, but I'll try. I commute from the western shore (of the Chesapeake) in rural Maryland to the DC suburbs and back. The trip is lots of small hills and is a mix of surface streets, rural state highways and interstates with occasional stop-and-go. I set out today to log it, and I've graphed some of the relevant parameters below.
    A few observations on the following graph:
    1. It is my "typical" one-way morning commute.
    2. I made one crucial mistake at about 900 seconds. I dropped the kids off at daycare and thought I would be clever (big mistake) and left the car on (with AC on) since I was just going to run the kids in and run back out and the logger would just keep logging. I got stuck for 10 minutes and drained the traction battery down until the ICE kicked on. You can see that in the Batt Charge graph.
    3. The total distance was 38.6 miles
    4. The ICE torque is an interesting graph. The spikes to -100 ft/lbs are MC1 spinning up the ICE for ignition when coming out of stealth. Also if you are really gliding then the ICE torque is zero. However you have to apply a little accelerator to do this, as noted by many people. Otherwise with your foot off the petal the ICE torque is usually -10 ft/lbs, i.e. the spinning ICE without fuel does induce a small amount of drag (of course). If you are below the speed cutoff for stealth, then the ICE torque is, of course, zero since it isn't spinning.
    5. The instantaneous fuel economy graph is always very busy. The integrated fuel economy was about 60 mpg on the HSI.
    6. You can see the hills on the altitude graph. I've also included a graph of speed which was governed by traffic lights, and traffic.
    Anyway, for what it is worth, here is my commute:
    [IMG]
  15. Offline
    Manc New Member
    Apr 20, 2010
    Manchester England
    Prius 42, please get a life:D
  16. Online
    bwilson4web 03 and 10 Prius
    9,720
    2,460
    Huntsville AL with 2003 Prius
    Your Vehicle Year:
    Are you using a Techstream-Lite?
  17. Offline
    spiderman wretched
    Jul 5, 2009
    6,750
    1,174
    Alaska
    Your Vehicle Year:
    Very nice, now we are talking data! One other important factor... speed. Did you capture that variable? If not, an average speed for the route will do.
    In all though, looks like you have a very hospitable route for the Prius. For the rest of us, we just have to make do. :)
  18. Offline
    Jun 30, 2009
    1,831
    223
    Cleveland, OH
    Your Vehicle Year:
    What tools did you use to capture that?
  19. Offline
    Jun 30, 2009
    1,831
    223
    Cleveland, OH
    Your Vehicle Year:
    Spiderman, Speed is the first one on his list.
  20. Offline
    spiderman wretched
    Jul 5, 2009
    6,750
    1,174
    Alaska
    Your Vehicle Year:
    Thanks, I just noticed that. Man my eyes are getting bad. :eek:
Share This Page
