1. Offline
    randy_m New Member
    Sep 8, 2009
    Message Count:
    34
    Your Vehicle Year:
    Driving around in my new Gen III today, and the a/c seemed to be blowing outside temperature air. I thought "Geez, going to have to go back to the dealer".
    Good thing I read the manual. I didn't realize that when you are in ECO mode the a/c doesn't cool very well. (I also didn't realize I was in ECO mode at the time).
    As soon as I turned that mode off, it was nice and cool again. Whew!
  2. Offline
    TheSpoils New Member
    Jul 30, 2009
    Message Count:
    290
    35
    New Jersey
    Your Vehicle Year:
    I have not experienced what you described. While in ECO mode the a/c operates at a slower fan speed, I am not sure that the cooling is reduced. If you use auto A/C mode, the re-circulate feature activates to compensate for the lower fan speed.
    Then again it all matter how hot it is where you live.
  3. Offline
    Mark57 New Member
    Aug 14, 2009
    Message Count:
    1,033
    134
    OKC
    Your Vehicle Year:
    It's been in the 90's here and the humidity has been very high lately. I run in ECO mode 100% of the time and use the A/C in Auto mode with recirc only and it's surprisingly cool with the temp set at 78 - 80. My vehicle is in the sun all day when I'm at work.
  4. Offline
    randy_m New Member
    Sep 8, 2009
    Message Count:
    34
    Your Vehicle Year:
    Wow, then maybe there is something wrong with mine. It definitely was not blowing cool when I had ECO on. Otherwise it worked perfectly.
  5. Offline
    Jul 30, 2009
    Message Count:
    290
    35
    New Jersey
    Your Vehicle Year:
    This is silly but did happen to me, if you manually disengaged the A/C button it will remain off until you manually press it again regardless if you hit auto ac or not. Try it out.
  6. Offline
    Mark57 New Member
    Aug 14, 2009
    Message Count:
    1,033
    134
    OKC
    Your Vehicle Year:
    I did that a couple of times myself until I got used to the vehicle.
  7. Offline
    bluemonday New Member
    Aug 31, 2009
    Message Count:
    152
    25
    St. Louis
    Your Vehicle Year:
    I run in ECO and haven't had a problem or noticed this at all. We haven't had a truly very hot day yet (nothing over 85 or 90) but then again I am a person who definitely likes his A/C so I've definitely had the A/C going and think I would have noticed less-than-cool air.
  8. Offline
    jburns Senior Senior Member
    Oct 13, 2005
    Message Count:
    828
    104
    Archdale, NC
    Your Vehicle Year:
    I see you are in Minn. It's September now. What was the outside temp and the temp in the Prius when you noticed this? I've already noticed on the one cool morning we have had here that the air flow went to the floor vents and the cabin felt a bit stuffy. I just lowered the temp setting 2 degrees and everything felt fine. Later in the day when things heated up outside I returned the temp to its original setting.
  9. Offline
    jay_man2 jay_man_also
    Jun 11, 2009
    Message Count:
    1,246
    138
    Manassas, VA
    Your Vehicle Year:
    Same here. When it was 59 outside today 74 felt stuffy, but lowering the temp to 72 caused cool air to be emitted.
  10. Offline
    zonie911 New Member
    Apr 16, 2009
    Message Count:
    578
    17
    Nashville, Tennessee
    Your Vehicle Year:
    That's the way I roll, also, Jay_man.
    zonie
    :roll:
  11. Offline
    randy_m New Member
    Sep 8, 2009
    Message Count:
    34
    Your Vehicle Year:
    It actually got up to 86 today, and is supposed to be the same tomorrow. It's unusual here but it does happen. I'm in the Twin Cities.
  12. Offline
    randy_m New Member
    Sep 8, 2009
    Message Count:
    34
    Your Vehicle Year:
    Finally figured out that was my exact problem. Am I a doofus, or what :confused:
  13. Offline
    Mark57 New Member
    Aug 14, 2009
    Message Count:
    1,033
    134
    OKC
    Your Vehicle Year:
    No, you are not a doofus. Learning new stuff is fun. Just grin and enjoy your great vehicle and mileage.
    PS, if you're a doofus then that makes a doofus out of several of us that have done this at least once.:D And I'm NOT a doofus. ;)
  14. Offline
    edmcm2000 New Member
    Aug 13, 2009
    Message Count:
    Arizona
    Your Vehicle Year:
    You say, altho you've now figured it out, that you were not able to drive in eco and have the AC work. So what mode did you drive in to use the AC during that period of time? Power? Or is there something I don't know about. Edmcm (always in eco)
  15. Offline
    Bobsprius BobPrius
    Jul 23, 2009
    Message Count:
    679
    79
    Buffalo
    Your Vehicle Year:
    If I am reading right, I don't believe the posters issue was ECO or anything to do with that, but he did not have the A/C button pressed when in Auto or other control thus he did not engage the A/C unit. If you use auto to set the temp A/C is something you still have to press from all I have read in the posts....
  16. Offline
    DaveShepherd New Member
    Nov 13, 2004
    Message Count:
    139
    Washington, DC (VA Suburbs)
    Your Vehicle Year:
    Hello. My name's Dave, and I'm a doofus.
    ("Hello, Dave.")
    Same thing has happened to me 3-4 times in the three and a half weeks I've had my Gen III. The A/C interface is just different on the new cars than it was on the Gen II. I'm sure I'll get used to it very soon.
    I actually like being able to blow just plain air without A/C sometimes, like on a crispy cool day. On my 2005 I had to punch a bunch of buttons on the MFD to get there. Now I just have to touch the A/C button--simple!
  17. Offline
    randy_m New Member
    Sep 8, 2009
    Message Count:
    34
    Your Vehicle Year:
    The a/c does run a little slower in ECO (that's in the manual), but it works quite well if the a/c button is pressed.:redface:
  18. Offline
    Holbrook22 New Member
    Jul 11, 2009
    Message Count:
    65
    Holbrook, NY
    Your Vehicle Year:
    I've never had a problem with the a/c while driving in ECO mode, which is the mode I usually drive in. We had a few days with the temp at 90 and high humidity and the a/c worked fine as long as the system was set to recirculate cabin air and not fresh air in.
  19. Offline
    Aug 31, 2009
    Message Count:
    152
    25
    St. Louis
    Your Vehicle Year:
    I am a doofus about this and several other things. I have always driven what a month or two ago were suddenly clunkers worth $4,500. So things like the concept of setting a temp you want like a home thermostat instead of adjusting the A/C and fans to what you are currently feeling were foreign to me. Doing some of the stuff with the different trip odometers and other dash display stuff has also taken me awhile. So don't feel like too much of a doofus. Or at least know that you are in good company.
  20. Offline
    Tanabe USA New Member
    Sep 18, 2009
    Message Count:
    torrance
    Your Vehicle Year:
Share This Page
