1. Offline
    Jeffrimerman Junior Member
    Start a Conversation
    Aug 10, 2011
    84
    Pasadena
    Your Vehicle Year:
    I've read bluetooth is in the nav. I'm still not sure if I can swap the head unit and use aftermarket unit with jbl amp. If I can, so I only swap the head unit, will my bluetooth still function? My JVC hu has hd, and ipod control.
  2. Offline
    Aug 14, 2006
    18,173
    3,459
    Sacramento, CA.
    Your Vehicle Year:
    If you are swapping to an aftermarket stereo that has bluetooth and Nav then you lose nothing but steering wheel controls and even those can be retained with the right adapter module. Yes you can integrate an aftermarket head unit with the JBL amp system.
  3. Offline
    Aug 10, 2011
    84
    Pasadena
    Your Vehicle Year:
    So if I swap with a head unit that doesn't have blue tooth or Nav I'll also lose Bluetooth and Nav :( I read bluetooth was within the Nav system, but I assumed the Nav was in a cpu somewhere outside the head unit. I really like bluetooth and already have a decent head unit, but it doesn't have nav or bluetooth :eek:
    Ok, I found which bluetooth adapter module I can use with my JVC so I should be ok, but will I lose Nav? I don't use it, but curious.
  4. Offline
    jelloslug It buffed right out!
    Jun 11, 2008
    807
    36
    Greenville, SC
    Your Vehicle Year:
    The blutooth is apart of the MFD and communicates directly with the JBL amp under the passenger seat.
    1 people like this.
  5. Offline
    Aug 10, 2011
    84
    Pasadena
    Your Vehicle Year:
    So if I swap out the head unit the Nav should still be working right? But is the blue tooth part of the mfd also or is it within the head unit? Or does it matter? If I swap the head unit will it disable the nav anyways? Thanks:rockon:
  6. Offline
    Aug 10, 2011
    84
    Pasadena
    Your Vehicle Year:
    Ok, I've made up my mind to do the stealth install I saw on your video. Awesome job and thank you for making a video about it. Just one question about the wire harness. I see it for sale with what appears to be just two female connectors, but in the video you had 3 where two plugged into the male and one of the 3 plugged into the stereo and then another stock connector back into the stereo. Or does the picture on ebay just not show the 3rd connector? Thanks again.
    Ok, I found another post of yours mentioning the BHO-1761. Thanks again. I'm gonna order them asap. I'm excited =)
  7. Offline
    Jun 11, 2008
    807
    36
    Greenville, SC
    Your Vehicle Year:
    The MFD controls the Nav and the blutooth and the blutooth module is physically inside the MFD. Now the real question is will the Nav and blutooth audio still function with the head unit removed. They should work since neither the wiring or the network communication rely on the headunit for the connection between the JBL amp (and the speakers) and the MFD. They only way to know is to unhook the headunit, insert the proper resistor in the network loop for the missing headunit and try it out.
    1 people like this.
  8. Offline
    Aug 10, 2011
    84
    Pasadena
    Your Vehicle Year:
    Ok great. I've look at F8L's video install of the HU under factory and he plugs a couple wires back into the factory radio and says we don't need resistor if we do it that way so I'm going to order the harness and just do it. That would be awesome if the blue tooth works. I don't care about the nav. My android has the best nav I've ever used.
  9. Offline
    Aug 14, 2006
    18,173
    3,459
    Sacramento, CA.
    Your Vehicle Year:
    I apologize for not knowing anything about the NAV and bluetooth portion of the Prius. I don't know how they are wired.
    With my install method, the factory stereo will still power up but you are changing some of the wiring around. One way to test if the NAV and bluetooth sound will still work when the factory stereo is effectively removed from the picture is to disconnect the speaker wire plug (the smaller of the two that go in the back of the stereo) and see if the sound still works. With my setup you will still have the factory stereo in-line with the Canbus system so you don't have to use resistors but you will not be using the stereo for anything else. The speaker wires that normally plug into the factory stereo will not be plugged into the new aftermarket stereo wiring harness.
    To answer your question, you need to purchase two wiring harnesses. There is the standard "aftermarket to factory" (Best Kits - BHA1761) stereo wiring harness and there is a "factory" (Best Kits - BHO1761) style harness which normally is not used in the installation of an aftermarket stereo but in this case we need it to power up the factory stereo so we don't have to use resistors. I wish I had the camera angled better when I did the wiring part but I didn't notice I was out of the screen until long after the video was shot.
    Wiring:
    1. Connect the red wires from each harness (BHA and BHO) together in one side of a crimp connector. Leave the other end open.
    2. Connect the yellow wires from each harness (BHA and BHO) together in one side of a crimp connector. Leave the other end open.
    3. Connect the black wires from each harness (BHA and BHO) together in one side of a crimp connector. Leave the other end open.
    4. Connect the red wires from the aftermarket stereo harness into the open end of the crimp connector containing the red wires from step #1.
    5. Do the same for the yellow and back wires.
    6. Connect the remaining wires on the aftermarket stereo harness to the corresponding wires locate on the BHA wiring harness (this includes illumination, speaker wires etc.).
    7. Once all of the wires are connected you simply plug the aftermarket stereo harness into your aftermarket stereo. The BHA harness into your factory wiring harness that comes out of the dash. The BHO harness into your factory stereo.
    *Note- Sometimes the AC error will pop up or the MFD will go blank. This is fixed by simply unplugging the wiring harnesses and plugging them back in. Please check for this condition before putting your dashboard back together. ;)
    I will do my best to get to the stereo shop and actually take pictures of the harnesses all wired up to make this more clear. It is actually VERY easy to do but difficult to explain. I'll also go in and update my original thread.
  10. Offline
    Aug 14, 2006
    18,173
    3,459
    Sacramento, CA.
    Your Vehicle Year:
    Ok, I have a buddy at the shop who is going to take a picture of the wired up harnesses for me hopefully today. Stay tuned!
  11. Offline
    Aug 10, 2011
    84
    Pasadena
    Your Vehicle Year:
    Awesome, thank you so much. I ordered both of the harnesses so I'll get them in a week. I've done many radio installs so now that I know it uses a male harness to keep the factory radio in line, I totally understand the set up. I'll bug you if I have more questions:D.
Share This Page
