1. Offline
    tony2654 New Member
    Jun 30, 2009
    Message Count:
    26
    Norway
    Your Vehicle Year:
    My dealer called me day before yesterday and told me that new Prius had finally arrived here, so yesterday I went to have a test drive. My impression from my 10 min drive:
    It is more modern and substantial than the previous gen which I test drove 2 months ago. It rides quite well, even on the dealer-fitted 17'' (215x45x17) wheels. However I did notice that there was a fair share of noise and the engine itself was on the coarse side. Otherwise the car was much as expected, loaded with gadgets (drove one with solarpanel, LED, HUD, leather, navi, pre-crash, adaptive radar, basically the American V model and more), but inline with a compact economy car as far as cabin quality goes.
    I was told that my car (has the same trim-level as the tested one) would be ready in 2 weeks, 2-3 weeks earlier than expected. Thus I need to decide soon which accessories I want to have. As mentioned the dealer had replaced the 15'' wheels with 17'' ones on the test car and he told me that they could do that on my car too, together with a set of 15'' winter wheels/tires, all for 'just' 25000kr or roughly 4000 dollars. As a set of aftermarket 17'' wheels/tires costs generally less than 10000 Kr here at a tire store, I am leaning towards doing that myself. I asked the dealer about the supposed difference in steering wheel ratio between the 15'' and the 17'' models, but the dealer was not aware of this. So I like to ask, particularly those who have received a euro-spec car, can I somply put a set of 17'' wheels on my car and not worry about issues like rubbing, steering wheel ratio or effects on ESP?
    Other accessories like chrome trim, cloth mat, rubber side molding, rear parking sensors (4000 kr) are also available, is moeny worth spent on those?
  2. Offline
    bwilson4web 03 and 10 Prius
    Message Count:
    7,495
    1,394
    Huntsville AL with 2003 Prius
    Your Vehicle Year:
    I think you pretty well covered what can be done in a 10 minute drive. I can't comment on the accessories but as far as the 15" vs 17" wheels, I suspect you'll find there were no other changes to the car.
    As for noise, I tend to hear more 'road noise' and wonder if it might have been the surface more than anything else. Just a thought.
    GOOD LUCK!
  3. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    The steering is different between factory 15" and 17" model. Putting 17s on a 15" model shouldn't rub (since the wheel well is identical).
    Btw, I'll have the packages up so you don't have the use the U.S. designation lol. What are your trim levels again?
  4. Offline
    tony2654 New Member
    Jun 30, 2009
    Message Count:
    26
    Norway
    Your Vehicle Year:
    Here in Norway the new Prius is packaged probably the same way as in other parts of Europe save UK. There are 4 trim levels(see link below), Comfort, Advance, Executive and Premium which has everything, in addition leather and sunroof can be added to Executive at extra cost. Due to the tax system here the prices don't differ as much as they might do elsewhere, starting at 274000Kr for Comfort and go all the up to 348400Kr for Premium, all but metallic are included. For this reason I chose Premium, but I probably should have gone for Executive + leather.
    http://www.toyota.no/e-brochures/slot082_tcm308-916306.zip/slot082/pdf/compleet.pdf
  5. Offline
    ggood ggood
    Jan 17, 2004
    Message Count:
    1,917
    276
    Houston, Texas
    Your Vehicle Year:
    I thought the "stops" (sorry, don't know the right lingo) were different on the Model V with 17s, which is why they have a larger turning radius. Has anyone confirmed no mechanical adjustments are needed if you add 17s to the model II, III or IV?
  6. Offline
    • Moderator
    Message Count:
    27,008
    1,175
    Your Vehicle Year:
    Hmm.... I don't remember.
    Alright, I get those up now and you can update your profile to reflect European packages. Note that "Model" only applies to the US
Share This Page
