1. Offline
    austingreen Senior Member
    Start a Conversation
    Nov 3, 2009
    6,836
    949
    Austin, TX, USA
    Your Vehicle Year:
    I see, now it makes sense that it passed, I didn't know if things were old enough our state stopped inspecting them. I'm sure the O2 sensors, higher compression, ECU will help get it more efficient.
    For towing as heavy a load as you will be an ecoboost or similar engine is the right tool for power and efficency. But it doesn't come in a vehicle you want. Maybe when this car is through it might look better, but don't check it out on our account.
    water injection acts like an octane boost, allowing you to run a leaner mixture in those cases without knock. You want to have it under control to inject at those high throttle or high rpm situations when you might knock. If the car doesn't need higher octane on the tune you have, then no need for the injectors. You mix the water with methanol so it doesn't corrode. I would not expect it to help much on your engine.
  2. Offline
    BigFatGuy Junior Member
    Mar 11, 2011
    Oklahoma City
    Your Vehicle Year:
    Is kickdown an issue? I've got a $30 kit from B&M (B&M 70237) in my '91 Formula. It does allow higher speed cruising in overdrive....
    You'll like the synthetics. Last summer I converted my wife's '04 Mustang GT to Royal Purple & Amsoil in engine, trans and diff. She picked up 2 mpg just from that.
  3. Offline
    icarus Senior Member
    Apr 12, 2007
    4,710
    907
    earth
    Your Vehicle Year:
    If you a stuck on this Detroit iron, cast off the engine and drive train and install either a modern GM or MB Sprinter drive train. A 10,000 lbs sprinter will get 20 mpg, will tow a pretty good load. 3 liter turbo diesel, and it will move down the road quite well. Mine does 75 all day long at 20 mpg at nearly 10k gross.
    A small Cat or Cummins conversion might do fine too. Problem is you really have to do the the tranny if you wish to get any kind of performance. You could probably find an old GMC/Chevy diesel 5.8 and convert it really easily, but those were pretty shitty engines.
    Icarus
  4. Offline
    TxMan Hearse driver
    Jun 12, 2012
    50
    The Matrix
    Your Vehicle Year:
    wow, what a day...I got rear ended (thread) and was just a difficult day at work...lots of driving back and forth. these leather seats make it okay though, lol
    still need to fix the radio problem (all tweet, no sub)
    fix suspension
    get tach
    get backup cams.
    so I didn't average my mileage today, so I'm going to the gas station now...ladies and gentelmen, place your bets-what do you think I am getting now?
  5. Offline
    Nov 3, 2009
    6,836
    949
    Austin, TX, USA
    Your Vehicle Year:
    9 city, 15 hwy:) I hope I'm wrong and you are doing much better.
  6. Offline
    TxMan Hearse driver
    Jun 12, 2012
    50
    The Matrix
    Your Vehicle Year:
    52,575-52,274=301
    45-30.1=14.9
    301/14.9=20.2 MPG
    I think I screwed up, but I have no idea how...20 MPG out of an 8.2 liter V8 is a tad excessive...
    this is better then what my friend with the ecoboost says he gets with standard driving...what. da. eff...
  7. Offline
    2,393
    296
    Your Vehicle Year:
    What about the 6.2 Detroit diesel GM offered in some trucks, and military Humvee?
  8. Offline
    TxMan Hearse driver
    Jun 12, 2012
    50
    The Matrix
    Your Vehicle Year:
    have over a grand in the 500 motor, I'm stuck with it. plus, by my friends math, its more efficient than an ecoboost-
    ecoboost-3.7 liters, 411 HP, 23 hwy
    caddy-8.2 liters, 550 HP, 20 hwy
    (guess on my horsepower, its probably more)
    ecoboost: 411/23=17.8 horsepower/gallon
    Cadillac: 550/20=27.5 horsepower/gallon
    lol...not a perfect science, but still funny...also, this thing looks like it eats puppies for breakfast and is lubricated on orphans tears
    [IMG]
    not my actual car, not even same model, but its the chassis that the hearse is built on, so its the same thing.
  9. Offline
    bwilson4web 03 and 10 Prius
    9,715
    2,457
    Huntsville AL with 2003 Prius
    Your Vehicle Year:
    You can measure the applied HP by doing a timed, maximum acceleration test to say 45 mph to stay out of significant aerodynamic drag. But you'll need to get the weight with driver (and any other load) to calculate the HP. If you had an iPad or iPhone, there are apps that automate the whole process including measuring the acceleration.
    Given the dusty conditions in Texas (I grew up in Oklahoma,) you might consider doing an early engine and transmission oil and filter change before running the benchmark.
  10. Offline
    Nov 3, 2009
    6,836
    949
    Austin, TX, USA
    Your Vehicle Year:
    The peak hp of that model engine was 400 gross bhp in 1970 with 10:1 compression - that was measured in the old way without pollution control, tail pipe, other loads. Th ecoboost is net hp. My guess is your net hp is less than 400, but definitely check it out. Congratulations on getting 20 mpg hwy, that's a huge improvement.
    hp/mpg = hp*gallons/mile which is a pretty meaningless measure. hp/lb and hp/cdA (hp divided by drag) are much more meaningful.
    I think you need to paint - "fear the reaper" on your car.
  11. Offline
    TxMan Hearse driver
    Jun 12, 2012
    50
    The Matrix
    Your Vehicle Year:
    the peak was in 1970, but remember, this is a stage 2 motor now. cam, injectors, ECU, head job, fluids, headers, dual 4-inch straight pipes, and a dual-quadrajet style intake-its far from a stock '70 motor (although this block is a '76)
    the friend that supplied the Cadillac engine parts (so I didn't have to order them) owns a machine shop, and I think me might have a dyno. I will have to talk to him. next time I think of it, I will have it weighed at a truck stop or something...its probably close to 6,500 lbs.
    as far as customization, I would love a stage 3 race motor, (forced induction of some kind) DL80E trans, and some transfer case small enough so that it fits, but strong enough to take the abuse, and have a 900+horsepower 4 wheel drive completely custom work-hearse that can do the quarter faster than you can sneeze.
    I found a video on youtube of a '68, this has a stage 2 472 (7.7 liter) engine, a de-stroked 500. I like the matte paint and slammed look, might do something similar...rat rods have always clicked with me.
    friend at salvage yard has a few air-leveling lincolns around, and says I can have the systems if I go pull them. would need to fabricate custom mounts and make/buy a controller, but thats still WAY cheaper than airbags. also, everyone telling me to make an airdam, slamming it to the pavement would do basically the same thing, and with no risk of screwing up the body kit on a speed bump.
  12. Offline
    Nov 3, 2009
    6,836
    949
    Austin, TX, USA
    Your Vehicle Year:
    Yeah, '76 was measured the same way we do today, and was down under 200 ponies. That 400 gross bhp was not measured with any exhaust. I forgot that you got your injectors up, and didn't know about the intake manifold. That should push it passed that '70s one.
    I'm curious to see what it will do on a dyno. I don't think that stage 3 motor will help you on mpg if you are going 4wd:)
  13. Offline
    TxMan Hearse driver
    Jun 12, 2012
    50
    The Matrix
    Your Vehicle Year:
    ^going the full III probably won't be good on MPGs...but I already have 2 turbos and a box of regulators, coolers, and misc. parts...plus that weiland supercharger I could get-
    whose up for a dualcharged monster hearse? slammed, matte paint-I think a style like this-
    [IMG]
  14. Offline
    2,393
    296
    Your Vehicle Year:
    It's actually better, since you have reduced the total frontal area along with reducing airflow underneath. I didn't think of it because all the ones I see on the road are done half ass with the wheels off camber. Unless that's on purpose, which is just dumb. As long as won't effect the towing or getting where you need to go, do it.
  15. Offline
    Nov 3, 2009
    6,836
    949
    Austin, TX, USA
    Your Vehicle Year:
    lol. If you turbo charge it for efficiency, you probably end up with around 750hp:) Which I thought might be a problem feeding air into those turbos. Removing the hood and putting a big scoop up there definitely solves that problem, but looks like it would hurt your aerodymaics at 80mph.
    If you do forced induction, and want to do it right you definitely want turbo, not super charging. The super charger puts a parasitic load on engine, which increases with power. In other words the more you ask of it the more the vapire sucks life from your engine. Its advantage is power in low rpm ranges, ease of install, and lack of turbo lag. With that big block there is no reason to worry about power at low rpm or turbo lag. A supercharger can make that 3L engine feel like a 5L, but you already have a 7.7L monster. You already did a full head job, I'm sure you can handle adding the turbo chargers. You do need to run oil to cool the turbo charger, and need to go low or let the engine idle before shutting down. The biggest efficiency hit with a turbo is high rpm mode. When getting in that high rpm range, the mixture needs to get rich to avoid detonation and that wastes gas. It also leaves efficiency up to the driver, drive at low rpms and the engine is efficient with more power, and high rpms you get monster power and low efficiency.
  16. Offline
    TxMan Hearse driver
    Jun 12, 2012
    50
    The Matrix
    Your Vehicle Year:
    the weiland is off of a dedicated strip car, it takes 120 horsepoewer to turn with the sproket on it. I would put a larger sproket, gearing it for top end power. I talked to the kid that chose my cam and did the head job, he says they aren't set up for large amounts of boost. he also says that he could take the heads that came on it, the '76 ones, and port those and make them dedicated for forced induction, but if I'm not on boost, the engine won't have the power I am used to. he also says that the injectors can't keep up, the trans will need an overhaul, and more support for the rear axle (we think its off of a late '70s chevy school bus) is needed. this wouldn't be a 'slap on some parts for more power' this would be a complete overhaul, the bottom end is still stock-forged pistons, rods, crank and some serious bearings would be needed. custom headers, and a complete ECU reprogram, an oil cooler, lots of plumbing...its $5,000 to get started, this is in the distant future.
    he also e-mailed me a tune for the LS2 controller, to set it up for non-supercharged big-displacement engines-it no longer kicks 'airflow error' and 'supercharger not found' codes, and is significantly more powerful. I emailed him back a compete scan of the motor, and he emailed me another tune, limiting it to the limits of the bottom end.
    this kid is 16, in high school, drives a beat up station wagon, and washes dishes for a job...and he can do all of this with his spare time...he's going places.
    also, its the 500 (8.2 liter) not the 472 (7.7 liter) engine.
    this weekend we are going to poke around, see if everything is holding up, put the air suspension on it, and prepare it for serious mileage. the project will be considered done.
  17. Offline
    Nov 3, 2009
    6,836
    949
    Austin, TX, USA
    Your Vehicle Year:
    Hey you were doing things so much less expensively than I figured you might have some secret amount of cheap parts. The original head would give you proper compression for super or turbo charging, and either would need more fuel flow from the injectors. If you turbo charge it, there will be more torque, so the trans needing an overhaul is correct. Rods, pistons, crank may also need replacement. That makes it an expensive project. If you turbo charge it for torque, not hp you don't need to worry about being off boost, it will act great at low revs. I don't think supercharging it will get you where you want to go though.
    Tune is very important. Good job.
    Doh. I'm not used to thinking in cubic inches, they are so before my time. 8.,2 liters it is. That means you even need less boost if you are doing forced induction ;-)
  18. Offline
    tochatihu Senior Member
    Apr 10, 2004
    3,560
    478
    Kunming Yunnan China
    Your Vehicle Year:
    2001 Prius
    I have no useful technical advice to add to this thread. I only wish to comment that a non-prius driver has come here, spoken (faintly) ill of that car, and expressed a personal lack of concern for vehicle pollutant emissions. Despite all that, the discussions have been cordial and probably useful to TxMan.
    It supports my long-held idea that there are some fine folks here. I am not at all sure that the reception would have been as warm at many other car-affinity discussion sites.
    Anyway, I hope your hearse continues to improve and I think we would all enjoy seeing some pictures posted :)
  19. Offline
    FL_Prius_Driver Senior Member
    Jun 17, 2007
    3,246
    670
    Tampa Bay
    Your Vehicle Year:
    2001 Prius
    That's because when the need arises for a high horsepower hearse, we will have the inside track.
  20. Offline
    TxMan Hearse driver
    Jun 12, 2012
    50
    The Matrix
    Your Vehicle Year:
Share This Page
