interesting oil study by Infineum
Discussion in 'Fred's House of Pancakes' started by Former Member 68813, May 22, 2015.
  1. Former Member 68813
    3,524
    981
    US
  2. wjtracy
    wjtracy Senior Member
    11,313
    3,588
    Northern VA (NoVA)
    Good data but I hoping Infineum would interpret it more.
    Are we talking synthetic or dino oil here for the Prius: ILSAC GF-4 SAE 5W-30
    What are they saying about CAMRY MPG? If I undertsand, they tried a really low viscosity oil, and the dashboard MFD read-out did not show a MPG benefit, but the data logger showed a huge MPG benefit? Are we saying the data logger is the true data?
  3. alekska
    alekska Active Member
    435
    138
    Atl
    Not a very scientific study. A single-car sample. All kind of outliers possible - what if something was wrong with 400-K miles Prius PCV or breather tube? Or spark plugs? Or thermostat? That would explain the varnishing.
    Still, thanks for posting. I think it shows current level of understanding of how oil works in hybrids :)
    - Alex
    #3 alekska, May 22, 2015
  4. Former Member 68813
    3,524
    981
    US
    you are right, it was not a scientific study. sorry if i misled you.
    i did find it interesting how the prius insides looked after 400,000 miles of driving.
  5. qdllc
    qdllc Senior Member
    1,358
    396
    Doesn't speak of what brand of oil used either. I'm presuming they used the average OTC synthetic motor oil recommended for the engine and not some of the brands that do a better job at cleaning out gum and varnish accumulation.
  6. Den49
    Den49 Member
    498
    267
    Maryland
    Scientific or not, it makes sense that a hybrid engine, or any automobile engine with start/stop technology, will be more prone to accumulate deposits due more time run at less than full operating temperature. Thanks for posting this information.
  7. alekska
    435
    138
    Atl
    To me your statement is not obvious. I have read multiple studies that show increased sludge and deposits forming in "hot" engines. Thickening polymers, used in multi- viscosity oils, are unstable at high temperatures. To me it makes sence that cooler, part time engine would have less deposits when all else is equal.
    Alex
  8. qdllc
    qdllc Senior Member
    1,358
    396
    All engines have this problem. That's why oils often have detergents added.
    Not to start an "oil war," but that's why I use AMSOIL. It's designed to use engine heat to clean the engine of gum and varnish, and when I did a valve clearance check on my motorcycle, it was SPOTLESS on the inside. Not sure if the Prius engine gets enough use to get the same cleaning effect, but if I ever have to have an ICE compartment opened where oil flows, I'm going to want to take a look to see how clean it is.
  9. CR94
    CR94 Senior Member
    2,642
    1,134
    Northwestern S.C.
    There's some truth in both sides of that argument; both too hot AND too cool (like short winter trips) are hard on oil.
  10. Frank M
    Frank M Junior Member
    36
    NH
    You will find that anything AMSOIL has all the other brand name oils have as well.
    Price and availability is better also..
  11. Former Member 68813
    3,524
    981
    US
    why was it moved to FHOP? this about oil in hybrid cars!
  12. bwilson4web
    15,392
    Sugar. <rim-shot>
    Actually there are technical issues with oil discussions that sad to say too often strays from empirical to opinion. If folks start with oil analysis and some sort of metrics, it is relatively safe. The problem is too often brands make claims not necessarily verified by experiments.
    It costs ~$20-25 do to an oil analysis. My interest has been in the transmission because it is a relatively benign and controlled environment. Furthermore, sources from other Prius have helped us form a reasonable understanding of what is going on. I just don't see that degree of disciplined investigation of engine oil. It is what I call a 'hard problem' because I can't figure out a reasonable approach that would work.
    #12 bwilson4web, May 31, 2015
  13. Former Member 68813
    3,524
    981
    US
    Admin: can we move it to a forum where it belongs?
