interior light won't turn off ...
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by raja, Jul 17, 2014.
  1. raja
    raja Junior Member
    Australia
    2013 Prius v wagon
    Wth.. the front interior light will not turn off, no matter which switch position it is in.. (yes I have put it in the off position)
    Even when I lock the car or put it in gear, it still doesn't turn off.
    The back row light turns off fine.
    The open door signal is not on. I've gone around and pushed all the door close switches to no avail.
    How long can the light stay on before the battery drains assuming it was full.
  2. Air_Boss
    Air_Boss Senior Member
    3,910
    1,065
    New Yawk
    Are you referring to one of the map lights or the dome light?
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    The map lights are also a push-switch. Push on the light to turn it off.
  4. raja
    raja Junior Member
    Australia
    2013 Prius v wagon
    Its the dome light, the one next to the rear vision mirror. Anyhow, I've pulled fuse 32. I'll take my car in tomorrow and see if the service department can sort it out.
  5. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    Each map light has an additional internal switch so either map lite can be turned on independent of all the other interior lights. Push up on the outboard edge of the clear light lens to operate this switch. push up once , it's on, push up again and it turns off.
    neuf150 and RCO like this.
  6. raja
    raja Junior Member
    Australia
    2013 Prius v wagon
    Ha! You rock, thanks. I must have pushed both because they were both on.
    I didn't even know about that function. I guess I read the wrong part of the manual last night.
    RCO likes this.
  7. Air_Boss
    3,910
    1,065
    New Yawk
    There ya go! It's good to RTFM...
    raja likes this.
  8. emokidsloveme
    emokidsloveme New Member
    United States
    This just happened to me and Priuschat saved me from a dead battery. Thank you'
    RCO likes this.
