Intermittent Brake, Brake warning, ABS, VSC
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Goughy, Sep 23, 2011.
  1. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Or put the car in ready, park, apply parking brake, and measure if there is significant voltage drop across the cables.
  2. Goughy
    Goughy Junior Member
    29
    Southern California
    I took the negative terminal cable off and thoroughly cleaned both ends, the bolt attaching it to the fender well and the battery terminal. The resistance across the cable is now 0.1-0.2 ohms.
    The warning lights are now permanently lit. I took it in to a local independent shop who pulled the code. It showed C1300 which they said was either an ABS ECU malfunction or possibly a 12V battery problem. They couldn't find any other codes and were not able to reset it.
    They are not hybrid/Prius experts but were of the opinion that it was probably the ABS ECU module as I'd just replaced the battery.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Their tool may not have been able to reset the ABS light. Please try resetting the light using the procedure in post #7.
    http://priuschat.com/forums/gen-ii-prius-main-forum/73075-how-do-you-reset-abs-light-yellow.html
    You can see a diagram of the data link connector here: http://priuschat.com/forums/gen-ii-prius-technical-discussion/30354d1305558989-2004-prius-abs-light-abs2
    I still suspect some sort of wiring problem but the possibility of a bad ECU is increasing. The next step if it will not reset is to get a junkyard ECU.
  4. Goughy
    29
    Southern California
    No luck. Tried a reset but the lights still come on.
    Thanks for your help.
  5. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    C1300 is the result of a failure of the internal self test of the skid control ECU. I think your only option is replacement. The only external influence that might effect this test result is if a power supply voltage going to the ECU is low. That could cause strange problems. Assuming you tried to reset the ECU with the following proecdure, and it still is on, the problem is persistatnt.
    CLEAR DTC (When not Using Intelligent Tester)​
    (a) Using shorting wire, connect terminals TC and CG of the
    DLC3. (pine 4 and 19 of the OBDII connector)​
    (b) Turn the power switch ON (READY).
    Then check ECU pins:
    Tester Connection Condition Specified Condition
    S8-7 (IG1) - Body
    ground
    Power switch ON
    (READY)
    10 to 14 V
    S10-5 (IG2) - Body
    ground
    Power switch ON
    (READY)
    10 to 14 V
    S8-3 (+BI1) - Body
    ground
    Always 10 to 14 V
    S9-5 (+BI2) - Body
    ground
    Always 10 to 14 V
    Measure the resistance of the connectors.
    Standard resistance
    CHECK AUXILIARY BATTERY VOLTAGE
    CHARGE OR REPLACE AUXILIARY
    BATTERY
    CHECK BRAKE CONTROL POWER SUPPLY (IG VOLTAGE)
    IG
    B18
    F047500E01
    B18-5 (IG) - Body
    ground
    Power switch ON
    (READY)
    10 to 14 V
    REPLACE BRAKE CONTROL POWER
    SUPPLY
    CHECK SKID CONTROL ECU
    GND1
    IG1
    +BI1
    GND2
    GND3
    +BI2
    S7 S8 S9 S10
    GND6
    IG2
    GND5
    GND4
    F047485E54
    S8-7 (IG1) - Body
    ground
    Power switch ON
    (READY)
    10 to 14 V
    S10-5 (IG2) - Body
    ground
    Power switch ON
    (READY)
    10 to 14 V
    S8-3 (+BI1) - Body
    ground
    Always 10 to 14 V
    S9-5 (+BI2) - Body
    ground
    Always 10 to 14 V
    Tester Connection Specified Condition
    S7-1 (GND1) - Body ground Below 1
    Ω
    S8-2 (GND2) - Body ground Below 1
    Ω
    S8-1 (GND3) - Body ground Below 1
    Ω
    S9-2 (GND4) - Body ground Below 1
    Ω
    S9-1 (GND5) - Body ground Below 1
    Ω
    S10-4 (GND6) - Body ground Below 1 Ω
  6. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
  7. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    No problem. If you replace the ECU with salvage, it may require zero point programming with a scan tool. Good luck!
  8. wnnarce
    wnnarce Junior Member
    ks
    I also have been experiencing intermittent ABS VSC (!) lights. Happens only at startup and 90% of the time they go off in less than a min. I have replaced the 12v battery, checked resistance on ground, Voltage at acc, on and ready all are within recommended ranges. i have checked all 4 relays for ABS and they are good, checked IG1 relay and its good. had codes read today and they are;
    U0073 Control Module Com Bus off
    U0123 Lost Communication Yaw rate sensor
    U0124 Lost com lateral acceleration sensor
    U0126 Lost com steering angle sensor
    U0293 Lost com with Hybrid Vehicle control system
    Lights have not reappeared in 4 days since testing the IG1 relay (Coincidence?)
    cold under 50 degree or high humidity (raining) conditions seem to trigger lights.
    I'm hoping one of the experts in this forum can help me with my personal twist on this problem.
  9. Patrick Wong
    18,199
    6,464
    Has your car been in an accident or experienced flood damage? It appears that you have a wiring harness problem since your DTC all relate to failed sensors and communications with other devices. That problem is very hard to pin down unless you know that a particular area of the wiring harness was damaged, thus allowing you to focus on it for repair.
  10. wnnarce
    ks
    I've only had the car for a year and the car fax was clean but i think it was in a minor front end accident because i noticed a few weeks after buying it the front fenders and hood are slightly different color and i found some bondo on the bottom of one fender.
  11. priusro
    priusro Junior Member
    Bucharest, Romania
    Thought I should revive this topic, any positive outcomes for the above problems? Did the ECU replacement solve the problem?
    I also have a problem which I think tracks back to the skid control ECU: the steering angle sensor (SAS) continuously shows a 1150 degree of the steering wheel. If I reset the ECU and drive for 5 minutes to allow the ECU to store the steering zero point, the SAS shows correct readings until I restart the car.
    Could it be that the skid control ECU does not store the data after shutdown?
    No DTC stored, car is a 2006 Gen2, 100.000 miles.
  12. scott180
    scott180 Junior Member
    24
    De Pere, WI
    I"m having some similar issues. Any update on this? 2007 Touring trim package
