ipad APP to # fillups? OBscan codes? where do i get these toys?
Discussion in 'Prius c Accessories and Modifications' started by robertmaria, Apr 30, 2014.
  1. robertmaria
    robertmaria Member
    202
    please DELETE this account
    2014 Prius c
    how do you hook into all those codes and stuff on your Prius? will it work over bluetooth on my ipadmini?
  2. W5JCK
    W5JCK Junior Member
    32
    Arlington, Texas
    The OBD scans would take a special cable or bluetooth sensor to plug into your Prius's data port. I doubt any cable would work with an iPad, but a BT sensor will. One option is BlueDriver by Lemur. See at this link http://www.lemurmonitors.com/BlueDriver.html. I have not tried it so I cannot comment on how it works.
    There are several fuel/mileage tracking apps available for the iPad. I don't know of any that can connect directly to your Prius. However if you use Fuelly on the internet, then GasTracker+ will connect directly to Fuelly and allow you to update it via your iPad or iPhone. I use it on my iPhone and add the fill up information while still at the gas pump.
  3. robertmaria
    robertmaria Member
    202
    2014 Prius c
    ohhh ok. thanks. i didnt know what that fuelly was. i wanted my c1 to have all the fun goodies too. i didnt want to drive around with some scan tool plugged into a data port and wires hanging out all over. i thought there was like a rpm app too to supplant mmy dash. water temp would by useful for instance. actual voltage(s) too
