1. Offline
    windstrings Certified Prius Breeder
    Sep 11, 2005
    Message Count:
    5,644
    129
    Central Texas
    Your Vehicle Year:
    Unless I'm imagining it, I swear when I let off the brake its like I'm free coasting and feel more like I will roll forever if I don't apply the brakes.
    Is it the fact that the prius GenIII now weighs more, or did they slack off on regen to use kinetic energy for travel instead?.. "or both".
    I've always said that the simulated transmission drag from regen was a waste and braking regen should be all that we have.
    Maybe they compromised?
    I've always surmised that they felt they had to incorporate the transmission drag for fear drivers would miscalculate their rolling distances when letting off the gas...maybe they feel we can handle more free rolling now?
    In the past with the GenII, it was always a challenge to find that magic dead zone where you were not making regen nor using electricity for propulsion, but "truly coasting" as most hyper milers and serious prius drivers realize that is one of the most efficient states you can be in for max gas mileage.
    Does anyone else seem to feel they coast better and farther now?
    I do see regen happening when coasting but maybe with the added weight we get to have our cake and eat it too?
  2. Online
    tumbleweed New Member
    Oct 3, 2005
    Message Count:
    3,797
    551
    Eastern Oregon
    Your Vehicle Year:
    I think based on my very limited experience with the Gen3, 7 days and 1000 miles, that using the HSI indicator makes it a lot easier to find the magic zone we call stealth or warp stealth. If my observations are correct that must occur when there is no bar showing and it is right between the lower half and regen. So if that is correct it is a lot easier to keep in that zone, especially in ECO Mode, than it is to keep all the arrows off in a Gen2.
    I think what you have noticed may be the software changes, the added weight doesn't seem enough to be noticeable. It's only another 110 lbs curb weight and I can add more luggage and junk than that and not really notice the difference.
  3. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    It's there, I don't think you are imagining it, but it may be the cumulative effect of several things, greater inertia from the weight, slightly lower CD, lower rolling resistance tires? not sure about the tires, just guessing there. Possibly programming as well.
    Oh yeah, weight is evil, inertia works both ways.
  4. Offline
    Sep 11, 2005
    Message Count:
    5,644
    129
    Central Texas
    Your Vehicle Year:
    No doubt.. my experience is limited too!
    For some reason I thought the GenIII was much more difference than that?... well thats good to know.
    A few other tidbits I found.
  5. Online
    Oct 3, 2005
    Message Count:
    3,797
    551
    Eastern Oregon
    Your Vehicle Year:
  6. Offline
    ALS New Member
    Jul 15, 2009
    Message Count:
    336
    57
    Pittsburgh
    Your Vehicle Year:
    You should try neutral. OMG this car coasts forever compared to my old car.
  7. Offline
    esoniat New Member
    Aug 13, 2009
    Message Count:
    79
    Marietta
    Your Vehicle Year:
    I'll try neutral more but I have to be careful not to put into drive to fast, if I just jog it up there it seems to miss it. I have to hold it just a little longer than comes naturally.
    I really don't like the way the car "creeps". That is if I let of the brake it starts going right away.
    I've been driving manual transmissions, I traded in a rare 5 speed manual 1993 Lexus es300, so I am complete acclimated to clutch in coasting and disengaged transmission at lights.
  8. Offline
    gazz New Member
    Mar 16, 2007
    Message Count:
    216
    Coventry, UK
    Your Vehicle Year:
    You do have to hold it a second, that's the way it works.
  9. Offline
    bestmapman "Dream" Prius
    Apr 8, 2007
    Message Count:
    1,107
    127
    Kentucky near Cincinnati, OH
    Your Vehicle Year:
    There is definately less drag in the Gen III then in the Gen II.
  10. Offline
    a priori Canonus Curiosus
    Aug 14, 2007
    Message Count:
    2,668
    313
    Chicagoland (West)
    Your Vehicle Year:
    I really hadn't noticed a difference. It is probably too late for me to do a comparison (even in my mind!), because I've now had my 2010 for MORE THAN 3 MONTHS!!:D
    Perhaps the gains you see are wiped out by my big fat tires? There has got to be a pretty significant difference between the old 185s and my new 215s.
  11. Offline
    cpatch New Member
    Jul 23, 2009
    Message Count:
    383
    79
    Carlsbad, CA
    Your Vehicle Year:
    Is this your first automatic? Any car with an automatic transmission will do this (assuming you're not in park).
  12. Offline
    a64pilot New Member
    Aug 3, 2008
    Message Count:
    771
    56
    Albany Ga.
    Your Vehicle Year:
    I don't like the creep either, or the automatic regen upon lifting the throttle as I see them as un-necessary. It would be nice to simply lift the throttle and automatically be in "glide". I'm sure it was to make the hybrid transition for the driver as transparent as possible
  13. Offline
    qbee42 My other car is a boat
    Mar 2, 2006
    Message Count:
    17,752
    2,804
    Northern Michigan
    Your Vehicle Year:
    Exactly.
  14. Offline
    hampdenwireless New Member
    Aug 21, 2005
    Message Count:
    1,102
    81
    Baltimore MD
    Your Vehicle Year:
    You have 4 factors to better coast on the gen3:
    Lower engine friction if its turning (despite the fact that it is bigger)
    Better gearing due to bigger engine so engine would have to turn slower
    Lower drag
    Greater weight (stored kinetic energy)
    I can not think of any factors that would make the gen2 coast better then the gen3 except the greater weight on the tires of the gen3 (increasing ever so slightly the rolling resistance).
Share This Page
