Is my 12v dying?
Discussion in 'Generation 1 Prius Discussion' started by Johnmo, Dec 17, 2014.
  1. Johnmo
    Johnmo Junior Member
    29
    2003 Prius
    I
    I turn my key, lights come on, then dim, the the ready light comes on a few seconds later. Sometimes, the ready light won't come on and I have to wait a minute, and try again.
  2. usnavystgc
    3,159
    988
    Tucson, AZ
    Yes, Definitely
  3. bwilson4web
    15,400
    Do get the throttle plate and area cleaned. When I had a 'sticky' throttle plate that was one of the symptoms along with the check engine light.
  4. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    Sure. Right AFTER you get the battery replaced.
    Did your sticky throttle plate cause the dash lights to dim, Bob ?? ;)
  5. bwilson4web
    15,400
    Well it might have the flames shooting out of my eyes and the smoke from my ears.
    usnavystgc likes this.
  6. tochatihu
    tochatihu Senior Member
    8,995
    3,507
    Kunming Yunnan China
    2001 Prius
    Weak 12 v batteries cause many gremlins. Replacement (or at least cleaning up the connections) should always be high on lists of responses.
    I could see the throttle-plate motor sucking amps to get into "flaps up" mode and dimming dash lights.
    :whistle:
    Nah, no I couldn't. That was a lie.
  7. Johnmo
    29
    2003 Prius
    I
    Confirmed, it was the battery
