Is my dealership ripping me off?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jonasd, Nov 11, 2009.
  1. jonasd
    jonasd New Member
    Orange County
    Ok, long story short my wife signed up for a 4 oil change package on our first oil change at Power Toyota Irvine. The first time they changed the oil, the invoice showed the oil part number as:
    00920-1QT0W-01
    Which a quick google search shows as being fully synthetic.
    Now, we just had our second oil change, and the invoice shows part number as:
    00279-0WQTE-01
    A google search comes up with nothing on this part number, but a similar 00279 part shows 5w-20 non-synthetic.
    Any experts no what's going on here? Did they put non-synthetic oil in my car?
  2. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Apparently so, and if so your not the first, but you are smarter than most, you looked it up.
    On edit, and if they are like my dealer, they will fix it by lining out the wrong oil and writing in the correct on on the repair invoice. I haven't been back.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    That's why I bring my own oil, filter and gasket when I have the grease monkeys do a change. I also insist that they return the empty bottles. I also print up a list of what I expect to have serviced, what pressure the tires should be when I drive away, and I do check them before I drive away.
    So far I have had NO problems. The Service Manager actually complimented me on being so clear as to what needed to be done. They copy my list right onto the service work order!!!
    It's worth the extra prep time, and if something is wrong, try to spot it before you drive off the lot!!!
    Makes life much simpler!!!
  4. biphnest
    biphnest Junior Member
    Interesting, whenever someone starts a post by asking "Is my dealership ripping me off?" the answer, in so many words, is usually "yes".
  5. bps
    bps Active Member
    304
    119
    This is just another example of why I now change my own oil...
    Bryan
  6. JasonReno
    JasonReno New Member
    Reno
    No, they are not "ripping you off" 00279-owqte
    is a full synthetic Toyota specialized motor oil.
    I'm holding a bottle of it in my hand.
    a reputable dealership is not out to "rip" people
    off.
  7. rumpledoll
    rumpledoll Member
    179
    46
    New Jersey, USA
    What is the weight of this oil? 0W-20 or 5W-20?
    Rumple
  8. JasonReno
    Reno
    Yes it is a 0w 20
    I took a picture of it but they won't
    let me link to it bacause I have under
    5 posts :p
  9. boppo
    boppo Active Member
    799
    138
    Owego, NY
    keep posting:)
  10. JasonReno
    Reno
    Hey boppo, nice kitty
  11. JasonReno
    Reno
    ok here's the pic
  12. boppo
    boppo Active Member
    799
    138
    Owego, NY
    Thanks, she is a great cat to have around and like to sit on the prius airbox when the hood is up.
  13. rumpledoll
    rumpledoll Member
    179
    46
    New Jersey, USA
    Thanks! That looks exactly like one of the 5 quarts of Toyota 0W-20 I bought for my next change.
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Interesting, the quart I saw at the dealer was red/gray. They told me that it was full synthetic.
  15. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    You are correct. We were getting the Toyota 0w20 Synthetic in red bottles. The latest shipments are now the black bottles pictured above.
  16. F512M
    F512M Member
    415
    Laguna
    If the seconnd part number is 0w-20 synthetic then what weight is the first part number?
  17. Blue Sunfish
    Blue Sunfish New Member
    OC, CA
    I learn that you can buy two types of 0W-20 synthetic oil from Toyota Dealership. Red labeled oil says “full synthetic” (No.00920) and green labeled oil (No. 00279) is only “Synthetic”. I paid $7.76 and $6.75 respectively. I don’t know if No. 00279 oil could be a blend.
    BTW, A Tustin Toyota parts department guy has just told me that 10000 mile oil change is now official, as Prius engine doesn’t work as hard as other regular engines and I will get a revised notice on this from Toyota soon.
  18. Blue Sunfish
    OC, CA
    The parts guy also confirmed that we don't need to change oil filter cartridge at 5K miles, but we have to rotate tires at 5K miles.
  19. ROKTOY829
    ROKTOY829 New Member
    ALABAMA
    Thats the same memo we got. going to 10,000 miles on the o&f if the customer likes that but nobody should agrue with a customer wanting it done sooner.
  20. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Nobody should argue with a customer period. Express your opinion & the reason. If you don't want to do what the customer wants then suggest they would be happier getting their car serviced elsewhere.
