Is Starting the ICE at 50 MPH ok?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Rebound, Apr 28, 2012.
  1. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    If I drive to the freeway in EV mode, accelerate to 50 MPH and then switch to HV mode, will I cause any engine damage by starting up the cold engine at 50 MPH? What about in cold weather, and at what temperature could damage or excessive wear occur?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    It is certainly possible to have the ICE at idle speeds at 50 MPH.
    The ICE is pampered by a 'starter' that brings it up to idle speeeds aaand leets oil pressure build before applying spark.
  3. Rebound
    3,961
    2,609
    Portland, OR
    Let me re-phrase my question: I was always told that you should gradually warm up an engine. But if you get up in the morn and drive onto the freeway from EV mode, the engine goes from completely cold to 50+ MPH operation.
  4. iRun26.2
    iRun26.2 New Member
    683
    111
    United States
    I can't imagine that Toyota could have not thought about that possibility when they designed the software system. I'm sure this was an expected scenario.
    Whenever my ICE is first activated (at any speed) the EV system appears to still be the main source of power for the car. I see EV range drop as if the gas engine is just warming up slowly (which I believe is best for the engine).
  5. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    No matter what you do, the engine will always warm up gracefully. The system is very well thought out, always taking emissions & longevity into account.
    Watching a ScanGauge, it's easy to confirm that. I see the engine running at a lower than usual RPM while the coolant temperature is still low.
    Watching the EV capacity, you'll see it drop initially... dipping well into the HV capacity if EV is already depleted entirely to ensure the engine isn't worked too hard.
    So regardless of speed, power, or temperature, when the engine warms, it is protected from wear... much like it has been for startup itself for over a demand. The battery-pack is taken advantage, rather than putting stress on the engine.
  6. hill
    8,070
    Don't forget ... 'back-in-the-day' - oil was thicker too. 30w oil was the norm for decades. Now? 0w-20 goes in the Prius. Thin/light viscosity makes for easier going. That said, yes, the Prius is designed to take off 1st ... and warm up on the fly. Now if it's 20 below outside, you MAY simply wana do a start-up ahead of time so YOU'RE warm, once you're ready to jump into your ride. And collaterally, the Prius will be warmer too.
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    Not a problem. ICE will start and it'll actually slow down MG1 from revving from 7,600 to 4,000 rpm.
