1. Offline
    HarryK New Member
    Aug 9, 2009
    Message Count:
    NW-USA
    Your Vehicle Year:
    2002 Prius
    When I am parking at night I don't like my lights on (shines in my neighbors windows), but there seems to be no way to turn them off on the Gen 1 Prius.
    Is there a trick, or do I need to map the circuits and install a physical switch?
  2. Offline
    LeviSmith New Member
    Aug 19, 2009
    Message Count:
    62
    NY
    Your Vehicle Year:
    I agree, this would be really nice. But as far as I know, the only thing you can do is put the parking brake on. Then when you start the car, the headlights won't be on until you release the parking brake...
    (Short of installing a new relay/switch...)
    Levi
  3. Offline
    w2co New Member
    Dec 11, 2009
    Message Count:
    268
    33
    Longmont, CO.
    Your Vehicle Year:
    I looked into this a while back, and found out that even if you were to put in a switch (non-standard equipment) to shut off headlights, it will most probably cause a DTC (head lamp failure) originating from the body ecu. So other than the above mentioned parking brake method, I don't think one can shut off the head lights. I have an 03 genI prius with the running light option which has the head lights on at 50% all the time, and of course 100% when switched on all the way. You would think that with a vehicle that uses electricity, you would not want to run it down with the head lights on, however the head lights are powered by the 12V system not the HV battery, so the worst case would be in winter, in a traffic jam or stop n go very slow traffic and when the ICE shuts down, now the lights are running solely from the 12V battery. If the 12V battery is marginal then the current draw from the lights could run the voltage down below 11.7V at which point a whole pandoras box of all kinds of false DTC's could happen due to all system sensors now out of cal. at the lower system voltage. Now whenever I'm in that situation I switch the lightswitch to the middle position to at least keep the head lamps at 50% only, this could buy you more time to exit the situation. But hey it's still a nice car.
  4. Offline
    • Moderator
    HTMLSpinnr Gen III Forums Moderator
    Dec 8, 2003
    Message Count:
    4,983
    718
    Surprise, AZ (Phoenix)
    Your Vehicle Year:
    Sounds like you've got the DRL option - those will stay on once you release the parking brake after the car is in IG-ON or READY mode. They'll only turn off once the car is turned to ACC or OFF. One could turn off the car, slightly engage the e-brake (just enough to get the BRAKE light on), then turn on and drive if it's THAT big of a deal.
    On the plus side, the DRL's are at 70% brightness, so turning the lights down to the parking light setting should keep them dimmer while retaining your parking lights, clearance markers, etc.
    You may also be able to remove the DRL relay to permanently disable them (only legal in the US), but I'm not sure if there's a jumper that needs to replace it.
  5. Offline
    Aug 19, 2009
    Message Count:
    62
    NY
    Your Vehicle Year:
    I think you're misinformed on how the Hybrid system works...
    The ONLY time that the car is on ONLY 12V power(the little battery in the back) is if you are in ACC or IG-ON mode.
    As long as it says READY on the dash then your 12V side is powered by the HV side of things whether the engine is running or not.
    So no worries there.
    Levi
  6. Offline
    orange4boy New Member
    Oct 20, 2009
    Message Count:
    218
    23
    Vancouver BC
    Your Vehicle Year:
    2003 Prius
    There is a hack to shut off your DRLs without getting codes etc. I'm going to do this soon too. The instructions are not super clear but all the info is there.
    Prius DRL Hack
    Main site:PriusHybrid
  7. Offline
    w2co New Member
    Dec 11, 2009
    Message Count:
    268
    33
    Longmont, CO.
    Your Vehicle Year:
    "As long as it says READY on the dash then your 12V side is powered by the HV side of things whether the engine is running or not.
    So no worries there."
    Thanks Levi, that is a good point.
    Tom
Share This Page
