Is your grill unblocked yet?
Discussion in 'Gen 3 Prius Technical Discussion' started by cyclopathic, Mar 15, 2012.
  1. NargilFenris
    NargilFenris Junior Member
    75
    Wherever Uncle Sam sends me
    Mine disappeared sometime last week. They either were stolen or were ripped out by the wind. I am thinking stolen because they were wedged in there good.
  2. royvogel
    royvogel TanzMan
    Smyrna, GA
    It's been in the 80's here in Georgia and I forgot to unblock my grill, but I have been checking my ScanGauge and water temp never gets over 195f. I got 60 mpg driving to Nashville from Atlanta and back last week!
  3. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    I think you misunderstanding what we are saying ...
    For some of us this makes a difference and maybe it doesnt for you .... but saying "it doesn't really help you warm up the cooling system too much faster as the coolant is controlled by the thermostat. If you live in Canada or somewhere cold" is just factually inaccurate and NOT the whole reason anyway.
    And top of that all the other points actually "worth" for some (including me but looks like a lot of others) to be bothered with this because I know I do save a few gallons per winter ...
  4. szgabor
    993
    175
    Oceanside NY
    Thanks .. this is the kind of real life data we need ...
    I have very similar experience ..
    What I was always saying is that this is just another possible technique someone can use to further reduce MPG .... that is it .
    All this could be totally useless if your driving situation is different ....
  5. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    Uh ... that's not exactly what happens .... just the opposite as a matter of fact ...
    REV
  6. cossie1600
    cossie1600 Active Member
    898
    92
    CT
    Coolant doesn't really start circulating the engine before it reaches operating temperature (I think around 180F on the Prius). When you block the grill, you help coolant heat up faster, not the engine itself. You are basically just heat soaking the engine.
  7. szgabor
    993
    175
    Oceanside NY
    Right I was thinking gas use (lower the amount of money I have to part with) which is of course inverse to MPG ....
  8. szgabor
    993
    175
    Oceanside NY
    Come on the coolant is circulating ...what you may try to say not circulating THROUGH the radiator ....
    But even you are saying that blocking the grill will not only stop the RADIATOR to cooling the coolant but clearly reducing the air going through the engine compartment which reduces the engine (and the coolant around it) cooling down ... and with the prius this is significant because the engine stops while you glide/or stop at the red light etc. ... hence produces NO heat during those 0 RPM times and the engine temp will drop (winter time this drop COULD be very significant ...) but that of course will depend on your OWN driving and commute ... so I have no doubt that for you this may be not worth it ... but in general grill blocking in colder areas worth considering ....
