I've been Prius v Accessory Junkie :)
Discussion in 'Prius v Accessories and Modifications' started by Cactus Hybrid, Jan 6, 2012.
  1. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    Can you take pics of the interior lit by those lights as well?
  2. syscon
    syscon Member
    329
    42
    Edm. Alberta
    Today I've seen BMW with LED on License Plate lights, they were very bright and standing out.
    I don't think LED for License plate are available for Prius v.
  3. Keiichi
    808
    79
    Goleta
    I was more referring to how the interior looks with it. The shots off the site are rather difficult to tell.
  4. Osteoblast
    Osteoblast Junior Member
    55
    NC
  5. Keiichi
    808
    79
    Goleta
    Now I just might have to consider getting that for my car as well.
  6. Wanderer
    Wanderer Hybrid neophyte
    366
    39
    Cold country
  7. DAVEJAN
    DAVEJAN Junior Member
    31
    Windsor Colorado
    how good is the reception compared with the standard antenna?
  8. Cactus Hybrid
    Cactus Hybrid Member
    129
    46
    Paradise Valley, Arizona
    The reception has been great with my antenna. I have not noticed a difference in my area (Phoenix).
    I love my shark fin Antenna..:rockon:
  9. mynewpriusv
    mynewpriusv New Member
    29
    irvine
    Re: I've been a Prius v Accessory Junkie :)
  10. Keiichi
    808
    79
    Goleta
    Cactus has, I believe. Which reminds me, how do you replace the lights with the LEDs? I can't figure out how to take the bulbs out of the sockets.
    Edit -
    Nevermind, managed to pull them out... Those things stick in darn tight that it was a pain in the rear to pull out the bulbs for the map lights and door lights. I'm still having problems figuring out how to open the cargo light and the passenger dome light still.
  11. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
  12. Cactus Hybrid
    129
    46
    The cargo light is the most difficult one in my opinion..Here is how. You have to use a very small flat screwdriver. Pry it in between the plastic frame and light housing. Then GENTLY push/slide to the LEFT (towards the rear of the car) AS you pull out on the light housing.
    The trick is to slide the whole lens/light to the LEFT as you pry it out.
    The Passenger Dome light comes out fairly easy. Again, stick your small screwdriver between the lens and the plastic frame (on the switch side) and GENTLY Push towards the rear of the car and pry out the lens.
    Hope this helps..let me know if you need more info..
    Rosie Benitez likes this.
  13. Cactus Hybrid
    129
    46
  14. Keiichi
    808
    79
    Goleta
    I could probably use pics on the pry points... I was having problems trying to see where the pry points were for those two.
  15. mynewpriusv
    29
    irvine
    Super Bright LED Car Interior Lights | Toyota Prius SMD LED Car Lights
    • 2 pieces SMD bulbs for front map lights
    • 2 pieces SMD bulbs for dome and cargo area lights
    • 2 pieces SMD bulbs for side door courtesy lights
    Hi CactusHybrid,
    I am interested in buying the same 6 Lights Wide Angle Shine Deluxe SMD LED Interior/Complete Package for 2010 and up Toyota Prius for my 2012 Toyota Prius V.
    However, I wanted to ask a few questions before buying.
    Does this include all the bulbs for the interior?
    iJDMToy is selling a total of 6 bulbs, when I think I need 8 bulbs. 2 for front map, 2 for the dome and cargo, 2 for the door courtesy and 2 for the vanity (mirror) lights, no? it's included in the pictures, but I don't see where it's included.
    I have emailed them, but haven't got a response yet. Can you please clarify? Thanks!
  16. Keiichi
    808
    79
    Goleta
    They will get back to you. The lights are only for the doors, the map lights above you, the one rear passenger light and the cargo area light on the left. I shot them an email to make sure what I was ordering, since they did not have a make for the Prius v and they pointed me to the 2010-2012 up section.
    Rosie Benitez and mynewpriusv like this.
  17. mynewpriusv
    29
    irvine
    Thanks Keiichi. Unfortunately, the picutres on ijdmtoy.com show otherwise. You see both map and vanity lights. That's confusing and why wouldn't you want an entire set vs. all int. lights but vanity lights.
  18. Keiichi
    808
    79
    Goleta
    How often you use the vanity lights is like... Literally non-existent. However, the Map Lights, the rear passenger lights and the courtesy door lights tend to be more often used. So they probably felt you don't need to have them. Their stock photos are pretty much for the Prius and sometimes they don't bother with specifics. I mean, when you look at their support site - Nothing for how to install lights for the Prius, most of them are generic.
  19. Mac Prius
    Mac Prius Mod Junkie
    213
    50
    San Diego
    Osteo - if you are referring to the small amber ones in the head lights I did replace those with LEDs at the same time I had the HIDs put in. Lucky for me DDM is in San Diego so I just popped the amber ones out, took them over to DDM, and they gave me the right LEDs for it. They cost about $6. Easy fix. But just like with the interior lights, make sure they are plugged in right and if not just flip them the other way.
  20. tanasit
    tanasit Member
    399
    60
    Philadelphia
