jump terminals on a 2013 prius c (under the hood) There or Not
Discussion in 'Prius c Main Forum' started by john roman, Apr 9, 2013.
  1. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    They are supposed to shut off after 30 mins... I believe.
  2. HotDogWater
    HotDogWater Junior Member
    70
    17
    5/13 production date and i've got the +terminal as well
  3. robertmaria
    robertmaria Member
    202
    please DELETE this account
    2014 Prius c
    My 2014 c1 has that same totally impossible to use tiny flat metal tab jump terminal under an orange plastic 12v cover buried in between the fuses. I can't imagine huge jaws of jumper cables not shorting out the entire system there. It seems like it would be easier to have the dealer tow it and put in a newly charged under seat battery when that inevitable dead battery day comes. Too bad we can't push start it instead.
  4. jroman33
    jroman33 Junior Member
  5. Mendel Leisk
    38,247
    Invest in a light-duty set of cables, keep them in the car? I'm thinking the heavy jumper cables are overkill anyway with the Prius, isn't the heavy lifting being done by the hybrid battery, the 12 volt just helps with electronics?
    Come to think of it, I should get something like these too:
    I just checked, with my old-school jumper cables: they fit on ok. That said, the weight of the clamp and the cable leading away seems to threaten the tab: seems if it where to get jerked something might break. Yeah, think I'm going to look for some light weight cables.
    #85 Mendel Leisk, Feb 6, 2015
    robertmaria likes this.
  6. Mendel Leisk
    38,247
    Just a thought: you shouldn't jump start another vehicle with the Prius. It's battery is pretty small, and wouldn't be good to be using light gauge cables either.
    Prodigyplace likes this.
  7. atsang
    atsang Junior Member
    austin
    Toyotechwv, so did you ever do a swap and replace on the 2012 PC?
  8. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Holy thread revival, Batman... but I'm curious too. :D
  9. atsang
    austin
    Lol it's only because I now have a couple PC 2012s (I have a delivery business) with a dead battery, and it's a pain in the nice person to jump them from the back seat.
    ztanos and bisco like this.
  10. atsang
    austin
    Just got off the phone with the dealer service dept and they said it would require a ton of modifications to get the terminals in the 2012 into the hood. Probably $1000 of work. Guess I'll just look for some small jumper cables.
    iPhone ?
  11. Mendel Leisk
    38,247
    Maybe you can jury-rig: some short runs of heavy gauge cable with capped ends with some sort of terminator you can clamp to, in a more accessible spot.
  12. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    Can they explain a ton? According to the wiring diagrams, the cable running to the fuse panel is identical in both cars... the only thing missing is the fuse panel with the jump terminal. Maybe there's something inline that is different?
  13. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
  14. atsang
    austin
    They didn't explain it to me other than "$1000 or more" of labor. Has anyone done this themselves?
  15. Mendel Leisk
    38,247
    How hard is it to get at the battery itself. I think I would just try to get proficient at this. Maybe mod the cover so it's a little more quick-release?
  16. FlexinWitMyPriusTho
    FlexinWitMyPriusTho New Member
    Sorry for the revival here but was anyone able to do this swap into the 2012 model?
    I'm very curious and interested in doing it
  17. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    I was planning on it, but then I never once had to jump my car in the 7 years I had my first battery... after that, I didn't worry about it.
