1. Offline
    PeteinPG Junior Member
    Start a Conversation
    Apr 15, 2012
    Pacific Grove, CA
    Your Vehicle Year:
    My "normal" schedule is to do them every 4K since I drive about 8K a year, but I wanted to get the first one done at a 1,000 or about just after break-in. I'll do the next at 4K and then each 4K after that.
    Bought ramps instead of using jack stands which I've typically used in the past. I bought the oil from Walmart which seemed to have it cheaper than anywhere else. $26.48 for 5 qts. Our trash pick up folks also pick up used motor oil and filters so that makes it very convenient.
    The cover under the car is a pia to deal with. I understand from a design perspective why it's toward the front of the car, but that makes accessing the drain plug and filter than much more difficult. In the end though, it's still very easy.
    The total time including clean up was about 45 minutes.
  2. Offline
    Dec 27, 2010
    1,282
    304
    Waianae, HI (Oahu)
    Your Vehicle Year:
    Glad everything worked out for you, I also did mine early at 1073 miles.
    What oil did you use, brand and viscosity? Was it individual quarts or a 5 qt. jug?
  3. Offline
    tumbleweed Senior Member
    Oct 3, 2005
    3,985
    619
    Eastern Oregon
    Your Vehicle Year:
    If you drive 8K per year a once a year oil change interval using 0W20 should be sufficient.
  4. Offline
    schorert Member
    Apr 18, 2012
    125
    48
    mass
    Your Vehicle Year:
    sounds like a plan, over 160k mi you'll do 41 oil changes instead of the recommended 16, you'll waste about $750, and generate over 30 gallons of waste oil(plus energy wasted producing, shipping, picking up and then recycling that oil).
    How exactly do you decide on an oil change interval?
  5. Offline
    jdcollins5 Senior Member
    Aug 30, 2009
    3,346
    669
    Wilmington, NC
    Your Vehicle Year:
    Just to be sure you get both sides of the oil change interval argument, I fully agree with your twice per year oil change strategy. I do this also for the main reason that it gives me a good reason to get under the car and inspect the under side of the engine for early signs of fluid leaks, inspect the CV joints for cracks, etc.
    Some may classify this as a waste of oil but I call it a very cheap insurance policy. 4 quarts of oil is wasting oil. Give me a break. I take mine to Advance Auto who recycle it and I would think your trash collector would also.
    As you will find there are many varying opinions on this topic :) Do what gives you the best peace of mind and ignore the others.
    2 people like this.
  6. Offline
    eliteconcept 700 Mile on 1 tank club member
    Aug 18, 2010
    17
    Indiana
    Your Vehicle Year:
    its your car do what you want. But i agree with schorert in that it seems wasteful, esp since with toyota recommended intervals being 10k. I could see doing it a bit early at 8k, but not even half the recommended interval seems too soon to me. You cal always take 20 mins jack the car up and do a quick inspection every few months. That wouldn't cost a thing and techincally is a better insurance policy than actually doing the oil change because the payoff is better, zero cost and 20 minutes every 3 months for a quick system overview.
    But like you said do what makes you comfortable. Since you drive only 8k a year you'r probably thinking every 4k or 6 months which i can see making sense.
  7. Offline
    schorert Member
    Apr 18, 2012
    125
    48
    mass
    Your Vehicle Year:
    But see, just like swapping tires out at 10kmi, it's just wasteful in terms of dollars and the environment. Recycling the oil doesn't negate the carbon expense of manufacturing, packaging(in bottles and boxes) trasnporting, and in your case reversing this process back to a recycler...to recycle oil that was well within it's service life. Your 5 quarts of oil is then added to the 5 quarts of oil of 100 users convinced to change their oil early based on what they read here.
    You can own the prius and be "green" or "thrifty" or both! It is then absolute folly on both counts to do superfluous oil changes! An insurance policy limits your risk in the event of a loss. There's no evidence at all that a 5kmi oil change lowers your risk of engine failure in any way.(in 106k threads, and 1.5million posts, I can't find an engine seizing following the recomm. maint. schedule....I did find one seized after being driven after the filter/cap fell off.)
    I'll ask the same question I do on all of these posts..."What is the documented benefit of changing the oil prior to 10kmi?" and my favorite followup...Since the oil change is completely arbitrary and unecessary, how do you determine the appropriate interval? how is 1kmi better than 500mi? How is 4kmi better than 3k? I'm guessing the rationale is "if 10k is good, 5k is better". There's really no reason NOT to change oil every thousand miles when you think about it. (I've found the term for this practice is Recreational Oil Changing)
    I don't really care either way, but I think new users come here and base a decision to change oil on what's written here and would assume that 10kmi is too long, with the only supporting data being the "feeling" of a small sample size of owners.
    stop changing your oil: Stop Changing Your Oil - Edmunds.com
  8. Offline
    Big Steve ramblin wreck
    Mar 5, 2012
    388
    36
    Richmond VA
    Your Vehicle Year:
    A good quote from that article is:
    "Chris Risdon, a product education specialist for Toyota agreed, adding that oil technology advances that permit fewer changes are a tool to protect the environment. "If you're doing it half as much, that's 5 quarts of oil times 1.7 million vehicles a year — that's a tremendous amount of waste oil that's not being circulated into the environment."
    1 people like this.
  9. Offline
    Aug 30, 2009
    3,346
    669
    Wilmington, NC
    Your Vehicle Year:
    My answer to your question was given in my original post, I prefer to inspect the under side of my car more often than once per year. By the time I take off the engine under cover I might as well take the 30 minutes to change my oil. It really has nothing to do with oil longevity.
    I really do not care what others do with their personal vehicles either but just want someone like this poster, that has already announced his intentions of his change interval, to get some support for his decision rather than others just telling him he is totally wrong.
  10. Online
    The Critic Resident Critic
    Oct 28, 2005
    1,972
    360
    Near Mazda Raceway Laguna Seca
    Your Vehicle Year:
    Glad to see another local on here. The $26 jug is probably Mobil 1 0w20.
    2 people like this.
  11. Offline
    ny_rob Active Member
    Feb 28, 2012
    960
    286
    L.I.- NY
    Your Vehicle Year:
    Was that the change interval with your previous vehicles? Did they also use synthetic oil with a factory recommended change period of 10K mi under normal driving conditions?
    If your other vehicle(s) used conventional oil with a recommended change interval of 5K mi, then changing it 1K mi early isn't the worst thing you could do. However, Toyota (and other manufactures) have a proven track record of excellent results with 10K mi changes with synthetic oil. Many here also claim that due to the nature of the Prius Hybrid Synergy Drive system- it's internal combustion engine is very easy on it's lubricating oil.
    Even my 2003 Honda CR-V has a 10k mi oil change interval when using synthetic oil- and that engine is nowhere as easy on it's oil as the Prius.
    We all share the limited/finite resources here on the planet Earth- we need to conserve whatever we can and wherever we can. The day will come when the spigot runs dry...
    1 people like this.
  12. Offline
    Apr 15, 2012
    Pacific Grove, CA
    Your Vehicle Year:
    The oil I used was Mobil 1 0-20 wt. Walmart has the best price in our area - they sell 5qt containers for $26.48. I bought the oil filter at our local dealership.
    I've been doing my own oil changes along with other services since I was 16 which is now 40+ years ago. My first car was a 1960 VW beetle.
    My driving today has me doing a lot of short trips many of which are a mile or less. Some weeks I drive a total of 40 miles with numerous very short trips. I live one mile from my office and one mile from town where we do most of our regular grocery and other shopping. Of course I do some longer driving (all the way to Monterey and Salinas). Those short trips are pretty hard on engine oil. Also, our area rarely gets "warm" or hot temperatures. Our average summer time high temps here are only 65 or so.
    My other two cars are BMW's and they recommend oil changes at 15K under optimal driving conditions. I'm selling one of these vehicles to make room in my garage for the Prius btw. Engine oils have become much better over the last several decades; that's for sure. Toyota and all car manufacturers want to stretch out the oil changes as far as possible and their recommended mileage figures are not for 'severe conditions'. Short trips are don't get the engine up to temperature and moisture accumulates in the engine. Of course there are other conditions that are severe as well - lot's of dusty, dirty driving conditions, very hot conditions (I do wonder about the 20wt oil in the central valley in summer), short trips, towing, etc.
  13. Offline
    Feb 28, 2012
    960
    286
    L.I.- NY
    Your Vehicle Year:
    Pete- I wouldn't really consider your described driving patterns as 'severe conditions'... think NYC Taxi fleet as 'severe conditions' :eek:
    At any rate- take a look at your oil when you drain it next time (after 4K mi)... if it looks good (not thin and black) it may be time to reconsider your changing intervals for the Prius.
    My Five has 3400 mi on it now- still original original factory oil- I checked it yesterday- it was still almost as clear as new oil. When I used to use conventional oil in my 2003 CR-V it was very dirty (but not thin) at 3K miles. These new cars when used with synthetic oil are a whole new ballgame where oil's concerned... just saying- keep an open mind....
  14. Offline
    Dec 27, 2010
    1,282
    304
    Waianae, HI (Oahu)
    Your Vehicle Year:
    Or you can send in a sample for used oil analysis, it costs about as much as an oil change. Most users here myself included use Blackstone Laboratories but there are others. Blackstone Labs
  15. Offline
    Apr 15, 2012
    Pacific Grove, CA
    Your Vehicle Year:
    I appreciate each of your thoughts and opinions, but I'm comfortable doing the changes at the frequencies that I've chosen. I'm very well aware that many send in their oil for analysis, but I'll opt not to do that at this point.
    I may amend my oil change regimen if my driving habits change; however, it seems unlikely given where I live, work and shop.
  16. Offline
    Aug 30, 2009
    3,346
    669
    Wilmington, NC
    Your Vehicle Year:
    Here's to many happy miles in your new car :)
  17. Offline
    yeldogt Member
    Jan 20, 2012
    330
    25
    NE
    Your Vehicle Year:
    The extended change intervals is the result of improved engines, fuel and oil -- it is not some conspiracy on the manufacturers part to lower maintenance requirements ..... especially since many with even longer schedules have better warranties that Toyota. It is always a good idea to inspect the oil using the dipstick on a regular basis ..... owners will find the oil so clean that the thought of changing it will go away..... mine now at 6k is so clean I had to dip it twice to be sure. Also -- the fuel in the gas was a carb/ early fuel injection situation that no longer is a problem with short trips. As a car collector I and many others have countless cars that travel short distances using synthetic oil on a two year change interval without issues ..........for over 20 years in my case.
  18. Offline
    Apr 15, 2012
    Pacific Grove, CA
    Your Vehicle Year:
    It's the water in the crankcase that builds up from short trips that's a problem and that issue doesn't go away with fuel injection.
    When an engine reaches its operating temperature that water turns to vapor and is expunged, either out the tailpipe or the crankcase ventilation system. On short trips, however, that water stays inside your car's engine and exhaust.
    A further complication of condensation and water is that it dilutes your oil, which then does a poorer job of lubricating the engine and collecting and removing dirt and contaminants. That excess water can cause and accelerate sludge formation which has been a noted problem for many car manufacturers including Toyota.
Share This Page
