Keep or Remove Plastic Wheel Covers?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Muhahahahaz, Jul 23, 2009.
  1. Muhahahahaz
    Muhahahahaz Member
    136
    CA
    Hi everyone! New owner here! :D
    So I just discovered how to remove the plastic wheel covers on my 2007 Prius. I suspect that I may like that look better, although currently the rims are dirty. Apparently the dealer didn't clean underneath the plastic covers when I bought it used recently, but that's fine. I'm gonna get it washed soon anyway for some pictures! :D
    Anyway, are there any down-sides to removing them? Will this expose the brakes/other wheel parts to possible damage, will MPG be negatively affected, etc? Which way should I go? (Total automotive newb here. I'm great with building computers though! :))
    Thanks in advance! :)
  2. Boo
    Boo Boola Boola Member
    5,051
    483
    97
    Flushing, NY
    Consider getting Chrome Wheel Skins covers for around $70 delivered:
    [imglink]http://priuschat.com/forums/attachments/gen-ii-prius-main-forum/14121d1239917381-chrome-wheel-skins-dsc00225.jpg[/imglink]
    [imglink]http://priuschat.com/forums/attachments/gen-ii-prius-main-forum/14122d1239917381-chrome-wheel-skins-dsc00222.jpg[/imglink]
    [imglink]http://priuschat.com/forums/members/boo-albums-prius-picture1558-chrome-plastic-wheel-skins.jpg[/imglink]
    [imglink]http://priuschat.com/forums/members/boo-albums-prius-picture1701-sunroof-chrome-wheel-skins.jpg[/imglink]
    [imglink]http://priuschat.com/forums/attachments/gen-ii-prius-main-forum/16475d1247144536-chrome-wheel-skins-chromeskins1.jpg[/imglink]
    [imglink]http://priuschat.com/forums/attachments/gen-ii-prius-main-forum/16476d1247144536-chrome-wheel-skins-chromeskins2.jpg[/imglink]
    Discussed in this thread: http://priuschat.com/forums/gen-ii-prius-main-forum/60560-chrome-wheel-skins.html
    Purchase for $70 delivered from here:
    2005-2009 TOYOTA PRIUS 15" CHROME WHEELSKINS HUBCAPS:eBay Motors (item 360171629682 end time Aug-16-09 09:35:17 PDT)
  3. Muhahahahaz
    Muhahahahaz Member
    136
    CA
    Oooh, those look nice. :)
    I'll see how I like them off first. ;)
  4. Doc Willie
    1,717
    142
    Out there, somewhere
    The trim rings do offer a small bit of protection to the alloy wheels if you scrape up against curbs.
  5. Muhahahahaz
    Muhahahahaz Member
    136
    CA
    Yeah, I did that to the plastic itself the other day... but I won't be doing that again now that I'm used to the car. ;)
    However, when I took all the rings off, I discovered that one of the alloys is already scraped anyway (since I got mine used), so I guess I'll leave them off. The wheels look so much better that way too. :D
  6. a_gray_prius
    2,927
    782
    IL
    I'm assuming you have a regular, non-touring prius in which case I don't think it makes too much of a difference. On the touring, the downside to taking them off is that the part normally covered by a center cap is exposed. Center caps are ~$10 if I recall correctly.
  7. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    A GRAY PRIUS - you're correct, but you can get the center caps from the stock 15's. they will fit.
    TOM - those chromies are beeeuuutiful! it doesn't even look like the stock rims. nice.
  8. The_Gunrunner
    The_Gunrunner New Member
    West Virginia
    There's one other reason to take the rings off. Dirt and other material get underneath the ring causing the tire to become unbalanced. Yes, even the smallest amount, an ounce or less, can cause a minor but no less annoying vibration. I had this problem and once I removed the rings and cleaned the rims well, it went away.
  9. mbarlow
    mbarlow Junior Member
    28
    Louisville
    Another Prius guy in my parking lot at work told me how much he liked my "new wheels" (without covers). I told him I knew where he could get a set for $10 and he could have them today. He laughed when I told him to remove the covers and contribute $10 to his favorite charity.
  10. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    OFF!!! Off with those ugly plastic rings! On with the full chrome caps if you have the few dollars to spend. :D
