Key turned to off and out of ignition, car still on?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MissLorieO, Oct 30, 2014.
  1. MissLorieO
    MissLorieO Junior Member
    Thread moved to proper forum.
    #1 MissLorieO, Oct 30, 2014
  2. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    Do you put a key in with the Prius C? If so, you may get help in the Prius C forum.
    This is a Gen 3 (liftback) sub forum and stopping or starting the car does not involve putting a key in.
  3. MissLorieO
    Thanks, I will. I thought I was in the right forum, but clicked the wrong tab. :/
  4. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    did you try to re insert the key and do it again? how do you know its still on? the lights and display are still on?
  5. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Our C has a smart key, like all our other Toyota and Lexus vehicles. Key in pocket, car goes. Just press the power button on your way out.
    There have been reports of the car acting twitchy on shutdown if the 12v battery is low, or if the vehicle speed sensor is wrong, or if the shifter is not going back to a neutral no-connect state. But in all cases, the car will turn off if you press and hold the power button. If that works, but gently poking it does not, you do have a problem somewhere and it shouldn't be too hard to track down.
  6. kingnba6
    1,018
    242
    NY
    not all the model Cs have smart key. the C1 and C2 have the regular key.
  7. bisco
    48,984
    do you actually turn the engine over like a gasser?
  8. kingnba6
    1,018
    242
    NY
    you dont have to crank the car. but the key has ACC, On and then "crank" position. the key moves similar to a gas car
  9. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    I do remember that now. One of the reasons why we laughed off the C1 and bought the C4.
  10. bisco
    48,984
    reminds me of my base miata with roll up windows, manual door locks, no power steering, cruise or a/c. but hey, for $12,500., i was happy.:cool:
