Dismiss Notice
The Prius Prime may be the best Prius ever. Find out why in PriusChat's first drive review from Japan.
KSC-SW1 Powered Subwoofer
Discussion in 'Private Sales' started by Prizzle, Jan 25, 2012.
  1. Prizzle
    Prizzle New Member
    123
    Withdrawn
  2. Plus IV
    Plus IV Active Member
    356
    225
    Ladera Ranch, Ca
    Four Touring
    How does this connect to the JBL system?
  3. Prizzle
    Prizzle New Member
    123
    You connect to battery and ground in the rear, attach two pairs of wires to existing speaker wires on either side ( I attached to the rear speaker wires running up the B post), attach one wire to an electical on/off point ( I used cigaretter lighter) and run the controller to an easy to reach spot ( in my G2 I put it in the hidden drawer in the front of the center console). Easy. All these wires are included.
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,795
    144
    just my .02 but doesn't it require a low pass filter (whatever it is) and rca input since the stock prius amps will clip off if you pass the wires strait into speaker level input? (that's what i had to do anyway)
  5. Prizzle
    Prizzle New Member
    123
    hadn't thought about that. Always thought it was plug and play, but my wife never used it so I really wasn't thinking.
    Anyone else know about this?
  6. V8Cobrakid
    3,795
    144
    the crossover unit isn't expensive. (5-20 bucks) i have two in my car. one new in package and one plugged in that's rather used (the crossover dials are so worn down i have to use creativity to get them to turn)... at this point i no longer adjust it.
    my system is rather rigged at the moment. i'm using a torn apart house amp powered by my inverter. this requires me to turn it on and off by hand. (there is a unit i can buy that would monitor the voltage on the 12v line and kill feed when it drops below a given number eg 12.8 v since resting is lower and the car on is higher. it was mentioned in another audio thread) back to topic...
