Leaving town without the Prius
Discussion in 'Gen 2 Prius Main Forum' started by exmetrodriver, Sep 10, 2014.
  1. exmetrodriver
    exmetrodriver Member
    124
    16
    Puget sound, Wa.
    I'm leaving town for about 11 days. Will I have 12V battery problems when I return and try to start it? I have a brand new 12V battery. Would it be OK to disconnect it?
    48,988
    you shouldn't have any problem, but if you want to be sure, put a smart charger on it or disconnect the negative 12v cable. if you don't want to go to the trouble, turning off the sks switch below the steering wheel is a big help. all the best!(y)
  3. exmetrodriver
    124
    16
    Puget sound, Wa.
    Ok, thanks. I have a dumb key :(
    48,988
    gotcha, i leave mine every winter for 5 weeks in an unheated garage, no prolemo. ymmv.;)
  5. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    One thing I seem to notice is when the Prius sits for a week or so, if I just drive off the HV battery seems to go to purple kind of fast especially if A/C on. I am going try to remember to let the car warm up a few minutes before I just pull out after it sits a spell.
  6. Cadenza
    Cadenza Member
    110
    28
    LALA Land
    Another option is to disconnect the 12v battery to prevent slow drain.... and lock the doors manually.
    BTW, dumb keys are harder to lose. Smart keys can make the owner look stupid sometimes.
