LED bulbs
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Superdrol, Apr 16, 2013.
  1. Superdrol
    Superdrol Member
    399
    32
    I am looking at replacing my interior bulbs with white LED bulbs and also the parking lights as well.
    Is there a reputable website that everyone here uses that you can purchase these bulbs from ?
    Also is there a list on the type of bulb for each of the areas (i.e. courtsey lights, trunk light, etc...?)
    Thanks.
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
  3. Superdrol
    Superdrol Member
    399
    32
    I've looked in the manual and the parking light bulb states wedge bulb. I've found a few different wedge bulbs and random eBay listings for types of bulbs. I was hoping I could get information that was less 'ambiguous'.
  4. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
  5. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    168 bulb replaces parking lights, plate lights, map lights, vanity lights and courtesy lights.
    Bullet Salvador and WE0H like this.
  6. SalixIncendium
    SalixIncendium Tree Hugging Environmentalist Wacko
    155
    68
    Dayton, OH
    And seat belt buckle lights...as it would appear.
    anonymous and pennsy22 like this.
  7. Sfcyclist
    1,621
    375
    SF, CA
    wow.. bulk pack of 168 will cover a lot.. including lighting up seat belt buckle.
    anonymous likes this.
  8. KK6PD
    4,003
    944
    118
  9. Superdrol
    Superdrol Member
    399
    32
    I've seen several on superbright, I found this site mentioned. I am guessing as long as they are not listed as 'oversized' then they will fit into the OEM housing ? There are several 168 bulbs but I am leery about buying then having them plug in but not fit into the housing
  10. burstaneurysm
    469
    144
    Chicago, IL
    All the cool kids have light up buckles. :D
    Superdrol, I wouldn't get anything larger than a 5SMD. Should be fine with those.
  11. SoCal65SS
    SoCal65SS Member
    72
    44
    Southern California
    I pieced mine together and spent ~$15 shipped for all of them. The wedge bulbs I just used the 5 SMD variety and they worked fine.
    However, if you want a kit all said and done try out this one:
    8 Lights Super Bright LED SMD Interior Light Kit For Toyota Prius 2010~2012
    My buddy got those and they're definitely whiter than the ones that I pieced together and not too much more $$$.
    WE0H likes this.
  12. Superdrol
    Superdrol Member
    399
    32
    What website did you order from ?
    Btw do you have HIDs as well ? They look like 6000k. If so where from ? Since I'm causing trouble I might as well get all my questions out. Ha
  13. burstaneurysm
    469
    144
    Chicago, IL
    I got mine off ebay. I've had fine experiences in the past with bulbs off ebay and they're certainly cheaper to try out.
    You can always test fit with cheap bulbs and upgrade as needed.
    No HID yet, they're in the mail. Those are the 5SMD LEDs in my headlights.
  14. Superdrol
    Superdrol Member
    399
    32
  15. KK6PD
    4,003
    944
    118
    You just plug the connector in where the bulb was, the plate is designed to sit in the housing! I have similar plates in my Gen II, bright as hell! Mine came with 4 adapters to allow it to be used in almost any car, if you plug it in backwards, no light. When plugged in correctly, light! This kit is already set for Prius, it should work fine!
    Remember, LED's have polarity, some DO NOT have protect diodes built in, so plugging them in backwards is bad, smoke etc! Some do, these are not a problem.
    I used a voltmeter to figure out what pin was +, marked it in RED Sharpie, the other pin is - now marked in Black.
    Red is + Positive, Black is - Negative!
    Simple!
  16. burstaneurysm
    469
    144
    Chicago, IL
    Yeah, dude. Just plug em in. You can't really do it wrong. If it doesn't light up, flip the bulb and try again.
  17. Superdrol
    Superdrol Member
    399
    32
  18. burstaneurysm
    469
    144
    Chicago, IL
    They'd fit, but if you need your reverse lights to actually illuminate the street/driveway, you'd be better off using a Cree projector LED. they're significantly brighter.
  19. Superdrol
    Superdrol Member
    399
    32
  20. wotcher
    wotcher Member
    403
    97
    16
    LA
    ouch. same thing happened to my friend.
    if memory serves me right, you can't swap out the reverse for leds unless you bake , open, and reseal the headlights. if you have extra money, then I recommend buying some specD or valentis tails for full leds. they're awesome and will dramatically change your 2010.
