LED Daytime Running Lights
Discussion in 'Gen 3 Prius Technical Discussion' started by WinstonTheodore, Mar 25, 2012.
  1. WinstonTheodore
    WinstonTheodore New Member
    OC, California
    Does anyone know why the DRL's turn off when the headlights turn on? Is there anyway to make it so they stay on at the same time as the headlights? I noticed that the Audi's, etc. all stay on during night driving with the headlights so i'm unsure why my 2012 doesn't.
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    3,885
    803
    115
    Los Angeles
    2014 Nissan LEAF
    You don't really need DRL's when on when the headlights are on. I would assume it's a power saving thing! You can always get a copy of the electrical schematic, find out where the relay is that controls DRL's and modify it to your needs! Sounds like a lot of work, but it is probably not that bad. If I had a copy I would point it out and send it to you. I run a Gen II, so I never got Gen III prints!
  3. 32kcolors
    32kcolors Senior Member
    5,728
    937
    124
    Redondo Beach, CA
    Probably a carryover from Canadian and European laws prohibiting DRLs while headlights are on.
    You're in California and can have up to 4 lamps lighted at any one time, so maybe do a mod to have them stay on at all time.
  4. sw20td06
    sw20td06 Junior Member
    I would like to now the same thing too. I have a 2012 and the LED's would look great on with my low beam HID. If anyone figures out a simple mod to do this that would be great.
  5. Cvk14
    Cvk14 Junior Member
    37
    New York, NY
    There must be a way to get a tap off of the switch to the ECU and have it also switch on the DRL. I'd love to do this as well.
  6. pauln64
    pauln64 Junior Member
    77
    Macon, GA
    It would be nice. But if taking the literal version of it, DRL is for during the daytime only. Once you have the headlights on, DRL is no longer needed. Although it would be nice if they just put the LED's in the headlights and use the "dots" running across the headlights. I think someone here had done this mod before.
  7. PaJa
    PaJa Senior member
    677
    111
    92
    Czech republic
    On EU market the switching DRL off when head lights on is a must due to the UN/ECE directive. But it is not followed by all automakers, f.e. Audi, Skoda and etc. There is a document for the reference purposes link, DRL specification is in 6.19 paragraph.
  8. jerrydelrey
    jerrydelrey Junior Member
    92
    Honolulu Hawaii
    Yeah I really wish Toyota put LED's in those dots.
  9. pauln64
    77
    Macon, GA
    on a side note...notice only 4 LEDs lights and it looks like there's a fifth LED that is not on? If I have time, I'm going under the car and take a close look at the DRLs
  10. fuzzy1
    2,549
    85
    The 2012 still has the same nonfunctional decorative dots as your 2010. But I was pleasantly surprised to find real LED DRL's on the 2012, mounted where the fog light knockouts were placed on the 2010.
    Look closer from the front. It has 6 lenses, one of which is partially obscured. But look really close, only the top 4 lenses have LEDs (yellowish component) behind them. The bottom 2 show only white plastic, no LEDs.
    Electrically, I bet these are driven as two in a series string, with two paralleled strings. A single fifth LED would not fit the driver pattern
  11. scooter4n
    scooter4n Junior Member
    27
    I was looking in to doing that for few months, here is what I found:
    DRL relay is under the hood marked DRL, I was going to jump relay coil from head lights to turn relay ON when headlight are one, but NO NO, when headlights are ON all power to that relay is OFF even HOT leg, so even if you turn relay coil ON there still no power to that relay to send i to the lights.
    I dont know why Toyota made it complete shut off, but it has something to do with headlights relay and that relay no where to be found, at list under the hood.
    Did I clear the mud a little? :)
  12. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,147
    365
    Whereabouts Unknown
    I didn't know we were limited to 4 lights on at a time in California. I suppose that prevents single car parades from blinding other drivers. This must crimp the style of overpaid athletes and gangster celebrities.
  13. sw20td06
    I didn't know the light rule either.
  14. ES44AC
    ES44AC C.A.U.S
    225
    33
    I removed my posting as the information I gave wasn't applicable to the question asked. Sorry for the confusion! :D
  15. sun4i
    sun4i Junior Member
    Costa Mesa CA
    Has anyone figured out how to do this mod?
  16. markabele
    markabele Senior Member
    3,720
    867
    Nebraska
    2013 Prius Plug-in
    I've always wondered why there is a switch for the DRL's on the blinker stalk and then also a thing on the settings screen about turning DRL's on or off.
  17. pghjerry
    pghjerry Junior Member
    58
    Dodge City, KS, USA
    2015 Prius c
    I agree completely...Ive tried turning the setting on and off on the radio and it makes no difference, you can override it with the switch on the blinker.
