LED headlight aiming?
Discussion in 'Gen 3 Prius Technical Discussion' started by Ricklin11, Sep 8, 2010.
  1. Ricklin11
    Ricklin11 Junior Member
    65
    N. Oregon Coast
    Well took my first night drive tonight, I like the LED lights, however they need to be raised. I just can't see far enough on low beam. Plenty white, plenty bright. The cutoff is very sharp but they need to come up to see farther down the road.
    Not looking to sear other drivers retinas, we have lots of deer and elk here, I need to see farther.
    Thanks in advance.
  2. pixelmixer
    pixelmixer New Member
    102
    Seal Beach CA
    I would like to know as well. :D
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    They suppose to auto level but so far I have yet to see it level.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
  5. Ricklin11
    65
    N. Oregon Coast
    Thanks Tumbleweed, easy peasy!! I'll check em out on my way to the airport way too early tomorrow morning.
    Too bad they don't detail this in the owners manual.
  6. Legendaryjarl
    Legendaryjarl New Member
    Michigan
    I have a Prius V too, and I tried turning on the headlight but don't see it dip down then up, what about u?
  7. tumbleweed
    4,067
    687
    Eastern Oregon
    I have never noticed mine do that, why do we think they should?
    Auto leveling measures the distance between the rear axle beam and the car body, it adjusts the headlights up or down to compensate for heavy loads. I didn't know it was suppose to dip when you turned the lights on?
    If there is a problem with the auto leveling system the headlight symbol on the far right of the dash board should flash on and off when the lights are on.
  8. Thai
    Thai Prius Neophyte
    1,197
    89
    Tumble...on my previous BMW M3, it does the dance (as described above) when you turn on the headlights.
  9. tumbleweed
    4,067
    687
    Eastern Oregon
    I had an '05 330i with factory xenon lights it may have done the same thing but I'm not sure.
    I double checked my Prius this morning and it definitely does not dip the lights when you turn them on. As I recall my gen2 prius, which had xenon lights and an auto leveler, did not either.
