led headlight replacement lights?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Hussain, Aug 2, 2014.
  1. Hussain
    Hussain Junior Member
    Sacramento, CA
    I have a 2010 package v, with led headlights. I know leds have had huge improvements over the past couple of years so surely their have to be better led lights available compared to the 2010 lights. Are their better led lights that would be plug and play with factory led headlight housings? If so, how much better? I'm not planning any crazy experiments in the near future but just curious.
  2. JC91006
    16,463
    8,377
    The 2010 v led headlights lights up the entire Street, what improvement are you looking for?
  3. Hussain
    Sacramento, CA
    Just curious if their are improvements. Besides, you can never have too much light (as long as you have projectors with cut-offs to not blind other cars).
  4. JC91006
    16,463
    8,377
    are you having a problem seeing with the LED lights now? They are bright enough to light up the entire highway, and if you use your fog lights too, the car next to you can see even if they turn their lights out......that's a lot of light. Can't say there would be a need for any further improvements.
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Federal regulations set forward the maximum output allowed for any street legal headlamp, LED or otherwise.
  6. pauerbach
    pauerbach Member
    101
    34
    Ha, tell that to the countless goons with those crappy aftermarket HID kits that they stick in their Civics without projector lenses...
  7. xliderider
    xliderider Senior Member
    7,842
    3,099
    Honolulu, HI
    Over here Tacomas are much more prevalent and the lights are mounted higher up. Just perfect for making maximum glare. :rolleyes:
    SCH-I535
  8. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    There is some improvement. 2010-2011 use 3 LEDs per headlight. 2012-up use only 2 LEDs per headlight. There's no plug and play but if you're willing to take the headlight assembly apart, I'm sure you can replace the stock LEDs with some high power CREE LEDs. Since you're not replacing the lens, you'll have the cut off to reduce the glare.
