1. Offline
    Max Turner New Member
    Start a Conversation
    May 13, 2009
    Carmel, IN
    Your Vehicle Year:
    Tried the hack to shut off the seat belt beep, but it didn't work on my new '09. Can you help? I wear seat belts, but not while backing out of he drive or at the bank machine.
    I want my wallet without being yelled at by the car.
  2. Offline
    ekestler New Member
    May 23, 2009
    Washington DC metro
    Your Vehicle Year:
    Just bought '09 Prius w/Pkg 4. Successfully applied reverse-beep hack, and driver and passenger seat belt hack.
    Question: When I go into Reverse, I experience a delay of between 1 and 2 seconds before the backup camera displays the view.
    Is there a hack to have it come on instantly, or at least a shorter delay?
    TIA.
  3. Offline
    darkdragon1976 New Member
    May 24, 2009
    Las Vegas, Nevada
    Your Vehicle Year:
    thanks for posting this sticky thread. It already answered a few questions for me. :D
  4. Offline
    Erik New Member
    May 14, 2009
    Your Vehicle Year:
    I would be interested to know of any hacks for the 2010.
  5. Offline
    rubdr New Member
    Jun 7, 2009
    midwest US
    Your Vehicle Year:
    Does anyone know how to turn off the flashing seat belt lamp after defeating the alarm? Thanks for your help!
  6. Offline
    rubdr New Member
    Jun 7, 2009
    midwest US
    Your Vehicle Year:
    Any way to turn off the annoying flashing seat belt reminder after disabling the beeping??? Thanks for your help!
  7. Offline
    Orpheus New Member
    Jun 21, 2009
    HUngary
    Your Vehicle Year:
    Thank you for your excellent compilation .
    Here is some I've found (unfortunately not tried yet since I'm just planning to by one (I'll get it in thursday)
    Keep on guys
    Here is some I've found on the net:
    With best regards:
    Clear the Oil Change Code:
    1. Press the power switch to the Toyota Pruis to the "On" position and press the odometer trip reset button located on the instrument panel by the odometer until it reads the actual mileage of the car. In other words, do not have it displaying "Trip" mode.
    2. Press the power switch to "Off" mode while the actual odometer reading is showing.
    3. Press the power switch twice to activate the "IG-ON" mode in the Prius while simultaneously holding down the odometer trip reset button for 5 seconds. You will see a series of 6 dashes that will count down by eliminating one dash until they all disappear and the odometer will display 000000. This resets the engine oil life of the Prius and the
    Activate EV Mode
    1. Take off the bottom portion of the steering wheel cover on your Prius. Remove the flasher plug.
    2. Remove one to three of the connector pins after opening up the plug. Put the steering wheel cover back together
    3. Detach portions of the dash board, including the vents, to allow you to remove the lower portion of the glove compartment. Find the HV ECU plugs and remove the lower one. These plugs are gray in color.
    4. Solder the wire to the connector pin then plug it into ECU plug #27. Splice the EV button ground wire to the ECU plug ground wire #1. Stick the ECU plug back into the ECU.
    5. Run the wire behind the dash board to the dimmer switch. Secure the switch to the cover then solder the wires. Put the dash back together then try it out and see if your Prius works with the EV mode button activated.
    Philips screwdriver Jeweler's flat head screwdriver 22 gauge speaker wire, 6 feet in length Soldering Iron
    Solder Power drill with 1/2-inch drill bit Electrical tape Momentary switch
    Change which doors unlock when you touch a locked door on cars equipped with a Smart Key System. The car's default is set so that the car unlocks all of the doors when the person holding the fob opens the front passenger door.
    1. Know your default setting. Opening the front passenger door unlocks all of the doors. Touching the hatch handle also opens all of the doors, including the hatch.
    2. Understand the way to change your unlock settings. You do this by pushing the door lock button and then the panic button on the fob for about 5 seconds.
    3. Wait for the first beep. After that beep, let go of the buttons. Now the driver's handle unlocks all of the doors.
    4.Hold both of the buttons down until you hear the second beep to force the driver, passenger and hatch handles to unlock individually.
    1 people like this.
  8. Offline
    Pdub Junior Member
    Dec 14, 2009
    Phoenix, AZ
    Your Vehicle Year:
    I, too, would be interested in a solution for this.
  9. Offline
    mrshow555 New Member
    Nov 20, 2009
    42
    LA
    Your Vehicle Year:
    Do any of these hacks allow you to view the message (MSG) button on the radio station menu while driving? I don't have the sat/nav system but want to allow the MSG button to work while moving. Thanks!
  10. Offline
    Politburo New Member
    Feb 15, 2009
    968
    207
    Your Vehicle Year:
    The "nav system speed override" should allow you to view radio MSG while moving. The fact that you don't have the nav system doesn't matter, as the hack is at the back of the MFD.
  11. Offline
    Nov 20, 2009
    42
    LA
    Your Vehicle Year:
    is that the one below where you have to redo it every time you restart the car? Because this one doesn't work on my 2005 Prius because I don't see a MENU button or a soft volume button?
  12. Offline
    Watdawg New Member
    Jan 22, 2010
    Daphne, AL
    Your Vehicle Year:
    Disabling reverse beep and seat belt beep worked on first time in my 2006.
    Thank you Thank you.
  13. Offline
    smittylube New Member
    Dec 7, 2007
    Silicon Valley
    Your Vehicle Year:
    Is there a way to stop the beep when pushing the display buttons? the steering wheel buttons don't beep, but the display does.
    The beep becomes much louder when you do stereo mods.
  14. Offline
    Feb 15, 2009
    968
    207
    Your Vehicle Year:
    I think if you hit display, there is a "beep off" button that appears at the top of the MFD.
    It's either under display or info.. for some reason, Toyota decided that having MFD preferences in two places was a good idea.
  15. Offline
    Feb 15, 2009
    968
    207
    Your Vehicle Year:
    Sorry, I never saw this reply until now. I was referring to the physical hack where you mess with wires behind the MFD, not the touchscreen method.
  16. Offline
    unixrocks New Member
    Jul 24, 2010
    Atlanta Ga
    Your Vehicle Year:
    The beep disable for seatbelts and reverse worked first try for 2008 Prius. :rockon:
    What is the difference of the key being "ON" vs "LOCK"?
  17. Offline
    Jul 24, 2010
    Atlanta Ga
    Your Vehicle Year:
    I have two keys that came with my 2008 Prius.
    Both are SKS keys and the backup key appears to be orgional (not worn at all and they metal key unlocks the door)
    Weird thing is my backup key will not work with the smart entry thingy - I dont care but what I do care about is I cant get it to remotely lock or unlock the car.
    I got all of the modes "add" "confirm" to work but the prius "locks and unlocks" the car twice when I try to add my spare key. When I try to add my master it locks/unlocks once confirming it is in the system.
    When I go to confirm mode it tells me two keys are registered with the Prius.
    The backup key works fine when I put it in the key slot and I can even enter the key programming modes with that key but the remote still fails to activate the locks.
    It is so bizarre.
    This should work - toyota said it is not the original key and I need to order a new one but that seems odd to me - if the Prius has it as a registered key then why is it not allowing it to lock/unlock the car?
  18. Offline
    Lou brock New Member
    Sep 8, 2010
    New York
    Your Vehicle Year:
    Hello Guys and Gals
    I have a 09 gen2 with navi and jbl I see the sat button but i have no sat is there a lock out for that or do i have to change the radio to get sat radio? T salesman told me i had it but it seams i dont lol what do you expect from them guys lol i went back he offered me a cheap after market one i have one of those already can anyone help with this dilemma?
  19. Offline
    rayhertford New Member
    Feb 19, 2010
    England
    Your Vehicle Year:
    errr ... yes it is possible!
    Had mine turned off last week, no more irritating continous bleeps when you put the car into reverse, just get one beep when I put it into reverse now.
    Ray
    England
  20. Offline
    svitale75 Prius Addict
    Oct 11, 2010
    39
    Your Vehicle Year:
Share This Page
