1. Offline
    PriusLove New Member
    Apr 27, 2006
    31
    Office of Defects Investigation
    Technical Service Bulletins - Search Results
    Report Date : April 26, 2007 at 12:54 PM
    Service Bulletin Num : 05806 Date of Bulletin: OCT 23, 2006
    NHTSA Item Number: 10020564
    Component: ELECTRICAL SYSTEM: INSTRUMENT PANEL
    Summary:
    MASTER, HYBRID, AND M.I.L. "ON" DTC P0A94, INFORMATION CODE 588. *KB
    Make : TOYOTA Model : PRIUS Year : 2004
    Manufacturer : TOYOTA MOTOR CORPORATION
    Service Bulletin Num : 00406 Date of Bulletin: APR 28, 2006
    NHTSA Item Number: 10019992
    Summary:
    AUTOMATIC HEADLIGHT LEVELING SYSTEM WARNING LIGHT ON OR FLASHING. *TT
    Service Bulletin Num : 06003 Date of Bulletin: MAR 28, 2006
    NHTSA Item Number: 10019699
    Component: AIR BAGS
    Summary:
    SPECIAL SERVICE CAMPAIGN (SSC) - 60B (SAFETY RECALL) (SUPPLEMENTAL RESTRAINT SYSTEM (SRS) AIRBAG REPLACEMENT). DUE TO IMPROPER ASSEMBLY OF THE AIRBAG INFLATOR, WHICH IS INCORPORATED INTO THE SRS AIRBAG ASSEMBLY (SIDE AIRBAG, CURTAIN SIDE AIRBAG OR DRIVER KNEE AIRBAG), SOME INFLATORS WERE PRODUCED WITH AN INSUFFICIENT AMOUNT OF THE HEATING AGENTS NECESSARY FOR PROPER AIRBAG DEPLOYMENT. *TT
    Manufacturer : TOYOTA MOTOR NORTH AMERICA, INC.
    Service Bulletin Num : 06305 Date of Bulletin: DEC 16, 2005
    NHTSA Item Number: 10018851
    Component: ENGINE AND ENGINE COOLING:ENGINE
    Summary:
    M.I.L. ON DTC P0300, P0301, P0302, P0303, OR P0304. *TT
    Service Bulletin Num : 0522 Date of Bulletin: OCT 01, 2005
    NHTSA Item Number: 10017678
    Summary:
    SPECIAL SERVICE CAMPAIGN (SSC) - 50P TO REPROGRAM THE ECM SYSTEM WHICH MAY CAUSE SOME OR ALL OF THE WARNING LIGHTS TO ILLUMINATE: MASTER, HYBRID SYSTEM, ENGINE, VEHICLE STABILITY CONTROL, AND BRAKE. *TT
    Service Bulletin Num : 4495 Date of Bulletin: JUN 13, 2005
    NHTSA Item Number: 10015479
    Summary:
    REPAIR INSTRUCTIONS AND DIAGNOSTICS FOR THE SFI SYSTEM. REPAIR MANUAL CORRECTION. 00400-RM107-5U1. *TT
    Service Bulletin Num : 5108 Date of Bulletin: JUN 10, 2005
    NHTSA Item Number: 10015598
    Summary:
    DIAGNOSTICS FOR THE HYBRID CONTROL SYSTEM. REPAIR MANUAL CORRECTION. 00400-RM107-5U1. *TT
    Service Bulletin Num : 5080B Date of Bulletin: MAY 31, 2005
    NHTSA Item Number: 10016189
    Summary:
    ENGINE MECHANICAL - ENGINE (1NZ-FXE). 00400-RM107-5U2. 00400-RM113-0U2. 00400-RM110-5U2. *TT
    Service Bulletin Num : 5090B Date of Bulletin: MAY 25, 2005
    NHTSA Item Number: 10016188
    Component: FUEL SYSTEM, OTHER
    Summary:
    FUEL - FUEL SYSTEM (1NZ-FXE). REPAIR MANUAL CORRECTION. 00400-RM113-0U2. 00400-RM107-5U2. *TT
    Service Bulletin Num : 02505 Date of Bulletin: MAY 24, 2005
    NHTSA Item Number: 10015880
    Summary:
    MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0A60, P0A63, P0A72, P0A78, OR P0A7A. *TT
    Service Bulletin Num : 02405 Date of Bulletin: MAY 19, 2005
    NHTSA Item Number: 10015960
    Summary:
    MIL ON DTC P1121. *SC
    Service Bulletin Num : 02205 Date of Bulletin: MAY 17, 2005
    NHTSA Item Number: 10015823
    Summary:
    MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P1151. *TT
    Service Bulletin Num : 4586 Date of Bulletin: MAY 02, 2005
    NHTSA Item Number: 10016175
    Summary:
    DIAGNOSTICS - HYBRID CONTROL SYSTEM. REPAIR MANUAL CORRECTION. 2005 PRIUS.
    00400-RM113-0U1. 2004 PRIUS 00400-RM107-5U1. *TT
    Service Bulletin Num : 01705 Date of Bulletin: APR 20, 2005
    NHTSA Item Number: 10015810
    Summary:
    INTERNATIONAL INVERTER COOLANT LEAK RESULTING IN MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P3009 AND INFORMATION CODES 526 AND 614 (INVERTER/CONVERTER ASSEMBLY). *TT
    NHTSA Item Number: 10018850
    Summary:
    MALFUNCTION INDICATOR LAMP (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) P0AA6 OR P3009, INFORMATION CODES 526 & 614. *TT
    Service Bulletin Num : 0040010751 Date of Bulletin: MAR 20, 2005
    NHTSA Item Number: 10015968
    Component: EQUIPMENT:OTHER:OWNERS/SERVICE/OTHER MANUAL
    Summary:
    REPAIR MANUAL CORRECTION. *SC
    Service Bulletin Num : 4496B Date of Bulletin: FEB 08, 2005
    NHTSA Item Number: 10015561
    Summary:
    REPAIR MANUAL CORRECTION FOR THE ENGINE CONTROL SYSTEM - SFI SYSTEM (1NZ-FXE). 00400-RM107-5U2. *TT
    Service Bulletin Num : 4497C Date of Bulletin: FEB 08, 2005
    NHTSA Item Number: 10015562
    Component: SERVICE BRAKES, HYDRAULIC:ANTILOCK:CONTROL UNIT/MODULE
    Summary:
    REPAIR MANUAL CORRECTION FOR THE SIDE CONTROL ECU ASSEMBLY (BRAKE). 00400-RM107-5U3. *TT
    Service Bulletin Num : 05004 Date of Bulletin: DEC 20, 2004
    NHTSA Item Number: 10015979
    Summary:
    ENGINE OIL SPECIFICATIONS. *TT
    Service Bulletin Num : 4416B Date of Bulletin: NOV 19, 2004
    NHTSA Item Number: 10016059
    Summary:
    COMBINATION METER REPAIR MANUAL CORRECTION FOR THE 2004 TOYOTA PRIUS. 00400-RM107-5U2. *TT
    Service Bulletin Num : 02704 Date of Bulletin: OCT 18, 2004
    NHTSA Item Number: 10010308
    Summary:
    MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P3191, P3190 AND/OR P0A0F. *TT THIS BULLETIN SUPERCEDES EG027-04 DATED 07/14/04. *TT
    Service Bulletin Num : 04704 Date of Bulletin: OCT 18, 2004
    NHTSA Item Number: 10011812
    Summary:
    MALFUNCTION INDICATOR LIGHT AND MASTER WARNING LIGHT ON CONDITION THAT MAY OCCUR AFTER SLOWING DOWN AND STOPPING AND WHEN ATTEMPTING TO RESTART. *NM
    Service Bulletin Num : 01803 Date of Bulletin: SEP 03, 2004
    NHTSA Item Number: 10005833
    Summary:
    MALFUNCTION INDICATOR LAMP ON CONDITION WITH DIAGNOSTIC TROUBLE CODE (DTC) P0136 AND/OR P0138. *TT *MJ THIS BULLETIN IS REPLACING PREVIOUS BULLETIN 01803R 12/02/2003. *NM
    Service Bulletin Num : 01004 Date of Bulletin: AUG 24, 2004
    NHTSA Item Number: 10009401
    Summary:
    FUEL GAUGE INACCURACY. *TT *TT
    Service Bulletin Num : 01704 Date of Bulletin: AUG 12, 2004
    NHTSA Item Number: 10009411
    Component: STRUCTURE:BODY:DOOR
    Summary:
    REAR DOOR FRAME BLACKOUT TAPE WRINKLED. *TT
    Service Bulletin Num : 00904 Date of Bulletin: AUG 10, 2004
    NHTSA Item Number: 10009415
    Component: EQUIPMENT:ELECTRICAL
    Summary:
    POWER WINDOW / ROOF INITIALIZATION PROCEDURES.
    *TT
    Service Bulletin Num : 04012 Date of Bulletin: JUL 16, 2004
    NHTSA Item Number: 10010322
    Summary:
    LIMITED SERVICE CAMPAIGN (LSC) - 40E. TO INSPECT AND INSTALL AN ENGINE COMPARTMENT SEAL ON THE UNDERSIDE OF THE HOOD TO KEEP RAIN OR CARWASH WATER FROM SEEPING INTO THE ENGINE COMPARTMENT FROM THE AREA AT THE TOP OF THE HOOD NEAR THE COWL. *TT
    Service Bulletin Num : 00804 Date of Bulletin: JUN 29, 2004
    NHTSA Item Number: 10008388
    Summary:
    REPAIR MANUAL SUPPLEMENT: SMART KEY REGISTRATION. *MJ
    Service Bulletin Num : 02304 Date of Bulletin: JUN 28, 2004
    NHTSA Item Number: 10008387
    Summary:
    MALFUNCTION INDICATOR LAMP (MIL) ON HV BATTERY DIAGNOSTIC TROUBLE CODES (DTCS) P3000, P3056 AND/OR OTHER DIAGNOSTIC TROUBLE CODES (DTCS). *MJ
    Service Bulletin Num : 40D Date of Bulletin: JUN 24, 2004
    NHTSA Item Number: 10008413
    Summary:
    HYBRID VEHICLE ON-BOARD DIAGNOSTIC. SPECIAL SERVICE CAMPAIGN 40D. *TT
    Service Bulletin Num : 04009 Date of Bulletin: MAY 13, 2004
    NHTSA Item Number: 10007672
    Summary:
    SPECIAL SERVICE CAMPAIGN 40D TO REPROGRAM THE ELECTRONIC CONTROL UNITS (ECU). *TT
    Service Bulletin Num : 00204 Date of Bulletin: APR 05, 2004
    NHTSA Item Number: 10007124
    Component: OTHER
    Summary:
    EMERGENCY RESPONSE GUIDE LOCATION. *TT
    Service Bulletin Num : 3296 Date of Bulletin: MAR 29, 2004
    NHTSA Item Number: 10006508
    Component: ELECTRICAL SYSTEM:WIRING
    Summary:
    ELECTRICAL WIRING DIAGRAM REPAIR MANUAL CORRECTION. *TT
    Service Bulletin Num : 00204 Date of Bulletin: FEB 19, 2004
    NHTSA Item Number: 10006227
    Summary:
    HV ECU SOFTWARE UPDATE
    .*MR
    Service Bulletin Num : 04002 Date of Bulletin: JAN 13, 2004
    NHTSA Item Number: 10005805
    Summary:
    SPECIAL SERVICE CAMPAIGN ELECTRONIC CONTROL UNIT. *JB
    Service Bulletin Num : 00603R Date of Bulletin: OCT 17, 2003
    NHTSA Item Number: 10005824
    Component: POWER TRAIN:AUTOMATIC TRANSMISSION
    Summary:
    INTRODUCTION OF NEW AUTOMATIC TRANSMISSION FLUID. TOYOTA LANDCRUISER 2004 ALSO INCUDED. REVISED. *TT
    Service Bulletin Num : 016 Date of Bulletin: OCT 17, 2003
    NHTSA Item Number: 10010089
    Component: OTHER
    Summary:
    2004 MY PRIUS PRE-DELIVERY SERVICE. *JB
    Service Bulletin Num : 00101 Date of Bulletin: OCT 09, 2003
    NHTSA Item Number: 10004424
    Component: ELECTRICAL SYSTEM:BATTERY
    Summary:
    MAINTENANCE FOR HV AND AUXILIARY BATTERIES AT PORT AND DEALERS. REVISED. *TT
    Service Bulletin Num : 01003 Date of Bulletin: SEP 26, 2003
    NHTSA Item Number: 10008408
    Summary:
    PRE-DELIVERY SERVICE INFORMATION FOR PRIUS. *MJ
    1 people like this.
Share This Page
