Listing of 3rd Gen TSBs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Critic, Oct 10, 2011.
  1. compac
    compac PSU, Metallic Blue Ribbon
    52
    VA, Blue Ridge mtns
    Engine Knock is more an internal timing issue of when the spark fires vs the position of the pistons inside the ICE... cold can effect it but the fix would not have to do w/ engine mounts.
    IANAM, I am not a mechanic.:rolleyes:
    [ame="http://en.wikipedia.org/wiki/Engine_knocking"]Engine knocking - Wikipedia, the free encyclopedia[/ame]
  2. RRxing
    RRxing Senior Member
    2,516
    1,789
    NEPA
    shawn.ne, telmo744, Jin and 3 others like this.
  3. Kore971
    Kore971 PEDD-CESC
    106
    58
    Downey
    I work for Toyota..., trust me when I say that there will be another tsb coming out to resolve that specific issue...
    ScottHz, Martyelzz3 and jdcollins5 like this.
  4. johalareewi
    johalareewi Member
    393
    44
    uk
  5. Kore971
    Kore971 PEDD-CESC
    106
    58
    Downey
    OK guys, its official, the TSB is out for the engine knock in the morning..., the problem is the intake manifold..., the issue is when, condensation builds up in the egr it gets sucked into the engine in the morning causing a misfire, the new manifold was revised in order to address this condition..., a brief knocking after cold startup.... TSB number:0010-12
    ScottHz likes this.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Here is a copy of the TSB that Seilerts posted this morning. This will keep copies of the actual TSB's in this thread.
  7. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    Is this allot of work to execute the TSB?
    I know I am not going to bring it in until the dealer has plenty of experience under their belt and I want to hear from peoples experiences first.
    ScottHz likes this.
  8. jdcollins5
    5,131
    1,338
    Wilmington, NC
    I do not think it is a lot of work to execute this TSB or the other one on the Engine Vibration.
    I agree with you though I am going to wait a while and let them practice on other cars :) I only have 40k miles so have plenty of time.
    ScottHz likes this.
  9. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Howdy All,
    I did not see it here, I could have missed it, does anyone have a copy of T-SB-0063-11?
  10. jdcollins5
    5,131
    1,338
    Wilmington, NC
    Do you have a description for this one?
  11. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    JD this is all I got from this thread. iPod USB to be fixed on the 2011? - Page 4 - PriusChat Forums
  12. jdcollins5
    5,131
    1,338
    Wilmington, NC
  13. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    I have problems with mine if you recall from this thread, http://priuschat.com/forums/showthread.php?t=100550 my service adviser knows I just want to have all the information that I can when I bring it in for troubleshooting. Do you have Toyota TIS access?
    Posted from my iPhone via the Tapatalk app.
  14. jdcollins5
    5,131
    1,338
    Wilmington, NC
    I can get TIS access. IIRC you cannot get it from HI. I am getting ready to go out of town for a few days but when I get back I will be glad to get a temporary access and check it out for you.
  15. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    I can't get access here? I don't know I have not tried yet. It's up to you if you want to check it is not that urgent, for you to pay just to check for me. I appreciate the offer though.
  16. The Critic
    The Critic Resident Critic
    3,193
    2,315
    CA
  17. daveprius09
    daveprius09 Junior Member
    Ivyland, Bensalem, Pennsylvania
    Just a question & a thought about the Knocking upon start up in the newer engines. How many miles is this this typically happening? Who is doing the oil changes? The owner or the dealer? Is the oil filter cartridge being changed at every oil change? How do you realy know if not doing filter yourself? Its hidden inside the cap/cover. Many dealers around here give 2 years & 25k mile oil changes for "Free" so we don't usualy see the cars until they are past the 25k or 2 year mark. I own a repair facility & we do change them everytime. I have noticed that usually the first oil/filter change I do, the filters are usually very dirty & even some sludge inside that I don't usually see in my repeat customers cars when changing.
    ScottHz and Kayak Tom like this.
  18. rrg
    rrg Active Member
    458
    120
    East coast - NJ
    The engine knocking is more common in the cold weather time frame. So my new 2011 bought in Aug. did not experience this until that following winter with low miles 6.5K miles before my first dealer oil change. I was able to reproduce it when cold by not allowing a full warm up the night before. Next day knocking.
    By the way I decided not to use the dealer and change my oil every 5-7k miles, with filters every time.
    ScottHz likes this.
  19. mtlewis
    mtlewis Tinkerer
    47
    Mississippi
    I noticed on the one about warped engine undercover that Toyota uses several different size fasteners. Wouldn't color coded fasteners be much easier to return to the proper locations?
    ScottHz likes this.
  20. bwilson4web
    15,372
    Sorry for the bounce but the cold weather is approaching and my request for the knocking TIS failed to get any action last Spring from the Toyota service center. So I have a couple of quick questions:
    • How to reproduce? :: Keep it 'cold' and do a partial warm-up; let it cool over night (40F?), and; next start?
    • Do we have a diagnosis? :: Ignition timing? Valve timing? Abnormal fuel collection intake manifold?
    • What does the TIS actually repair? :: I understand the intake manifold is replaced but what changed?
    Thanks,
