Location of lever to open back door from inside
Discussion in 'Gen 3 Prius Main Forum' started by dabirk, Nov 14, 2010.
  1. dabirk
    dabirk New Member
    Boynton Beach FL
    where if there is one
  2. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    2 people like this.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    OMG, you mean it located in the Owner's Manual?
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    It would be easier to operate if it was located in the Owner's Manual.
    Tom
  5. RRxing
    2,518
    1,790
    NEPA
    You know, maybe I'll start a new thread that lists everything that's in the owner's manual - that way no one will ever have to read it. It would be like an... !!!Online Owner's Manual!!! :p
    AKMARK likes this.
  6. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    I think he is asking for the lever usually under the driver's seat to open the hatch or trunk, not the emergency hatch opener.
  7. qbee42
    18,058
    3,073
    Northern Michigan
    Well then, he should have asked that question. ;):p:D
    It would be a good question if the Prius had one.
    Tom
  8. macman408
    macman408 Electron Guidance Counselor
    1,179
    365
    Alternately, we could create an account whose only purpose is to quote the page number and post an image for every request that could have been answered if the asker had read the very fine manual. In a matter of months, it'd have more posts than everybody here! :rolleyes:
  9. greenewl
    greenewl New Member
    Ka'a'awa, HI
    saved me from asking the question!
  10. qbee42
    18,058
    3,073
    Northern Michigan
    The account name could be RTFM.
    Tom
  11. RRxing
    2,518
    1,790
    NEPA
    Great idea, but it sounds like it would be a full time job.
  12. MikeDS
    MikeDS Member
    298
    Los Angeles
    It would be great if there was a hatch release from the drivers seat...oh well!
  13. qbee42
    18,058
    3,073
    Northern Michigan
    You don't really need it, since there is a hatch release on the outside of the hatch. Driver's seat release levers are used to let someone into the hatch when there isn't any way to open it from the outside. In the case of the Prius, it's easy to open from the outside.
    Tom
  14. designeraccd
    designeraccd New Member
    23
    IN
    Perhaps too easy! I'm having trouble keeping it LOCKED after opening it, as unlike any other car I've had-it does NOT self lock upon closing.
    If I did it correctly....I pressed BOTH the lock button on the fob + the tiny "hidden" lock button on hatch at the SAME time. IF the fob is well away from the car it seems to STAY locked, but not so when I'm "within range" with the fob. Am I missing something??! DFO :eek:
  15. qbee42
    18,058
    3,073
    Northern Michigan
    All you need to do is press the lock button on the hatch. Alternately, you may use the fob button. There is no need to do both.
    Remember, with the SKS, if you test the hatch to see if it is locked, it will automatically unlock, assuming you have a fob in your presence. It can be a bit confusing at first.
    Tom
  16. designeraccd
    23
    IN
    Thanks! That is what I finally THOUGHT was happening. The salesman did his followup call this morning and said the same thing.
    Just not used to so many 0s and 1s RUNNING a car!! DFO ;)
  17. designeraccd
    23
    IN
    Back (pardon the ALMOST pun) to the inside opening of the rear hatch: I found the illustration in my owner's manual, but still couldn't tell WHERE this release was!
    Talked to the knowledable (far more than most I've encountered) salesman I got the car from about it this morning. He and the shop's best mechanic (Service Technician...) literally went into a Prius to find it as neither knew it was there. Here's why: it is hidden UNDER the big rear floor hatch and then under a small cover, too. Basically you need to drop rear seat back and either be a contortionist or limber 10 year old to get at it and actually USE it to pop the hatch. Basically an emergency release that could cause an older customer considerable-possibly-PAIN to TRY to access and use it. MINUS 1 for bad ergos! DFO :eek::eek:
  18. qbee42
    18,058
    3,073
    Northern Michigan
    It's an emergency release, which is required by law. It's not meant for routine use.
    Tom
  19. designeraccd
    23
    IN
    No doubt about being for emergency use, and hopefully it is a very SLOW emergency! However, emergency or not...still POOR ERGONOMICS to put it mildly. I've never designed anything to be that awkward/difficult to use...NEVER! DFO :eek:
  20. qbee42
    18,058
    3,073
    Northern Michigan
    My take on it is that the release is a legal requirement. I think Toyota met the letter of the law in the cheapest possible way. It's certainly not useful.
    Tom
