Locking the doors with power on
Discussion in 'Gen 4 Prius Main Forum' started by Gen 2 Tom, Jul 25, 2016.
  1. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    I had the car on, cooling the car with the air conditioning on. I had to get out for a few minutes. So I left the car on, took the keys and tried to lock the doors after I got out. It wouldn't lock the doors.
    Have you found this to be the case? Anyway around this?
    48,970
    reach in thru the drivers window and press the lock button, then roll the window up.
    Coast Cruiser likes this.
  3. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Does the 2016 have a mechanical lock on the door?
  4. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    bisco is right. I just tried it. But then slight panic when I couldn't unlock the door with the Fob. How come?
    I had to use the small emergency key. (turn it to the right.)
  5. bisco
    48,970
    did you try touching the handle, and pressing the fob unlock button? neither worked? how about the window down button?
  6. Coast Cruiser
    2,267
    2,571
    Tried touching the handle. No go.
    Tried the "unlock" button on the Fob. No go.
    The window was all the way up.
  7. bisco
    48,970
    doesn't gen 4 have a windows down fob feature?
  8. Coast Cruiser
    2,267
    2,571
    Mine don't.
    krmcg likes this.
  9. krmcg
    2,592
    2,388
    Whittier, CA
    Yes
  10. Coast Cruiser
    2,267
    2,571
    It might if you have it re-prorammed somehow?
  11. krmcg
    2,592
    2,388
    Whittier, CA
    It can with Carista. I can help a brother.
  12. Coast Cruiser
    2,267
    2,571
    I wonder why the Fob wouldn't unlock the door? And the door handle touch sensor quit working, too.
    Be right back. Gotta go run another test.
  13. Gen 2 Tom
    333
    286
    Lincoln Park NJ
    I don't think I can operate the windows from the FOB. What package is that feature in?
    Do we have a mechanical key in the GEN 4, like my Gen 2 had? I didn't see it on the door or FOB
  14. krmcg
    2,592
    2,388
    Whittier, CA
    The Windows can only be operated with the fob with additional programming. Like Carista
  15. krmcg
    2,592
    2,388
    Whittier, CA
    The mechanical key is inside the fob.
  16. Gen 2 Tom
    333
    286
    Lincoln Park NJ
    Ha Thanks I'll take a look for it
  17. Coast Cruiser
    2,267
    2,571
    Ok, 2nd test:
    Power on.
    All windows rolled up.
    Exited car.
    Closed door. (Heard a few beeps.)
    Locked door with the small mechanical key. (One turn to the left.) No need to go thru open window and hit lock button. :)
    Waited a few minutes. tried to re-enter car, but door handle touch-sensor still didn't work. And pressing unlock button on the Fob didn't work. Had to use small key again to unlock driver's door (One turn to the right.)
    That's ok. No problem. Now I know how to leave the power on (with AC on too, if I want) and leave the car. Thanks bisco and Kevin.
    alanclarkeau and krmcg like this.
  18. Coast Cruiser
    2,267
    2,571
    There's a tiny release switch, and the key is attached to that little key ring.
    krmcg likes this.
  19. alanclarkeau
    alanclarkeau Senior Member
    7,041
    7,580
    near Brisbane, Australia
    yes, - but not by default. It was something I asked them to do before I bought the car.
  20. fuzzy1
    10,043
    Occupant safety? Domestic violence protection, so an angry partner outside cannot extract a target inside for a direct assault? Logic lockout?
    The car is not designed to be running and locked without an occupant and fob inside. Disabling the door unlocking function from external fobs is thus a logical and reasonable step.
