Looking for rims
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Johnsk93, Sep 10, 2014.
  1. Johnsk93
    Johnsk93 Senior Member
    212
    1,055
    San Jose, CA
    Hey guys I am new here and was wondering where can I purchase FRS wheels or OEM 2014 Corolla S wheels?
  2. Jay Flores
    Jay Flores Junior Member
    27
    Carson, CA
    Ebay or Craigslist
  3. jamessicat408
    jamessicat408 Active Member
    110
    175
    San Jose, CA
  4. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
  5. jamessicat408
    110
    175
    San Jose, CA
    Keep in mind if you decide on getting the FRS wheels you will need to buy 3 additional things: spacers, hub centric rings, and acorn-style lugnuts.
  6. PearlBlizzard
    PearlBlizzard Member
    75
    30
    So Cal
    I wanted to share some specifics:
    For about $10 shipped, you can get a set of 4 CR1053 (56.1mm to 54.1mm) Spigot Rings / Hub Centric Rings and not worry. Slide them onto the wheels before mounting. The 1mm thickness is too fragile if you put it on the cars hub first. Spigot Rings Hub Centric Rings Full Set of 4 Four Size to Choose from 200 | eBay [​IMG]
    3mm spacer ring with a 54.1 opening is optimal (about $40 for 4). Others have ground the brake down, but the center caps no longer fit without taking a hole saw and removing the inside 3mm of plastic and tape for the 2 front ones. If you go too deep, just use the center cap logos noted below to cover up the marks under the plastic. Wheels are 5x100 with 12x1.5 acorn lug nuts.
    Toyota logo center cap covers for $11 a set will enhance the wheels further. 47mm is the best fit and just stick on the scion center caps. Black or carbon fiber for that extra .01 hp;-) Just use a suction cup to pop the cap off without having to remove the wheel. TOYOTA 3d car stickers for wheel center caps СARBON LOOK ― Online shop 3D wheel center cap (3dcarstickers dot com)
    Also, the factory tire pressure sensors will fit the FRS wheels.
    #6 PearlBlizzard, Sep 11, 2014
